Old 12-07-2018, 03:22 PM   #239
Video of the mid-engine running at Sebring at night. Good recording of the engine sound..
[ame]https://www.youtube.com/watch?v=kfg71KgtxO4[/ame]
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
Gunman (12-07-2018), humfrz (12-07-2018), Tcoat (12-07-2018), Ultramaroon (12-07-2018)
Old 12-07-2018, 03:44 PM   #240
Sounds like a real close ratio transmission.
Dadhawk (12-07-2018)
Old 12-07-2018, 06:32 PM   #241
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
Yeah those 5 downshift corners have it sounding like a proper race car. It absolutely wails like a flat plane, too.
Horrid_Funk is offline   Reply With Quote
The Following User Says Thank You to Horrid_Funk For This Useful Post:
Old 12-07-2018, 09:36 PM   #242
I'm liking the profile better than I thought I would as well
Old 12-15-2018, 04:26 PM   #243
chipmunk
Drives: _
The first variant will be the LT2 (similar to LT1). I'm not sure what the delay is on the vehicle side, but powertrain side is all go!
Next, the flat-plane V8 with 5.5L naturally aspirated. Red line is 8600 rpm. I don't quite remember the power figures. Due to the flat plane, there are very very high vibrations horizontally. Drivers were complaining about fingers going numb after driving! I know Ford managed a flat-plane too, but their crank shaft is a lot heavier with the balancing counterweights. So they basically "cheated". But the LT6 has a much lighter crank.
Later on, the LT6 will be given twin-turbos, and renamed the LT7. This is a beast, with about 850 hp. I am not directly involved with the LT7, so I can't give any more info than that.
The LT6 has a lot of vibrations and exhaust overheating issues. It is benchmarked against the Ferrari 488. But no one has ever done a flat-plane engine with such high displacement (5.5L).
chipmunk is offline   Reply With Quote
Old 12-15-2018, 04:39 PM   #244
Why is that cheating?
Old 12-15-2018, 05:09 PM   #245
chipmunk
Drives: _
"Cheating" in the sense that, the benefits of using a flat-plane are negated by using a heavy crank, so there really isn't a point except to brag about it!
Old 12-15-2018, 05:13 PM   #246
chipmunk
Drives: _
And because of the high red line, there is a lot of oil starvation at the journals. As of May 2018, there was no solution to it. No clue what all they did since then to mitigate
Old 12-15-2018, 05:41 PM   #247
Take some out of the flywheel and call it good. First manage flutter. Then get what you can from it.
Old 12-15-2018, 06:43 PM   #248
chipmunk
Drives: _
It's a Tremec dual clutch. Not sure how much difference that would make.
With such high piston speeds and rotating/reciprocating con rods, pins, journals, etc., you benefit more from having a lighter crank than a lighter flywheel.
8600rpm from a 5.5L.... I should tip my hat to my ex-colleagues at GM!
Old 12-15-2018, 06:48 PM   #249
chipmunk
Drives: _
By the way, the flywheel mass actually helps dampen out the crank torsional vibrations. It helps a lot with the durability of the accessory drive system. In turn, a smooth accessory drive makes life a lot easier for the block, front cover & head, wherever they are bolted.
Lighter flywheels for road applications is just a fad.
Old 12-15-2018, 06:59 PM   #250
gymratter
Drives: BMW
Mid Engine Corvette Delayed Six Months Over Electrical Issue: Breaking
The mid engine Corvette will not debut next month at the 2019 North American International Auto Show in Detroit. That much you probably already know. But what you probably don’t know is why.
According to sources familiar with the matter speaking to GM Authority on the basis of anonymity, engineers have uncovered a major electrical issue with the future Corvette during the development process. From what we gather, the vehicle’s electrical system can’t carry the load necessary to support the necessary components.
To address the issue, engineers will need to re-engineer the vehicle’s electrical system. Naturally, changes made to the sports car will also need to be coordinated with suppliers involved in providing GM with the electrical components, as well as any associated equipment. The undertaking will delay the mid-engine Corvette project by six months.
Despite this, GM/Chevrolet should still be able to launch the mid engine Corvette for the 2020 model year, though a 2021 model year launch is not entirely off the table.
Stay tuned to GM Authority for more Corvette news and mid engine Corvette news.
http://gmauthority.com/blog/2018/12/...ssue-breaking/
gymratter is offline   Reply With Quote
Old 12-15-2018, 07:17 PM   #251
Then leave it there. I'm saying that based on your description of the differences between the two powerplants, I agree with Ford's choice of adding more mass to minimize the shaking forces. It's better for the longevity of the whole vehicle.
Old 12-15-2018, 07:30 PM   #252
chipmunk
Drives: _
Not quite sure what the delay with the LT2 is.
When I worked there, I worked almost solely on the LT6. By then, the development of the LT2 was already over and the Corvette mules were running around. So I'm not an expert with the LT2.
There is just way too much heat under the trunk for the MR layout, that much I know.
Chevy Camaro Mid-Engine anybody? Impureclient Other Vehicles & General Automotive Discussions 42 03-14-2020 09:19 PM
Chevy Bolt? What do you think? EAGLE5 Other Vehicles & General Automotive Discussions 41 09-02-2016 04:38 PM
Mid-Engine C8 Corvette Mule Spotted Sideways&Smiling FR-S / BRZ vs.... 16 01-09-2015 10:30 PM
BRZ vs Chevy SS Razz FR-S / BRZ vs.... 109 03-07-2013 09:09 PM
