#99 |
Drives: Legacy GT
The funny thing about the RPF1 is that the 8" wide +35 offset wheel has less brake clearance than the +45 version. It's because on the higher offset version the spokes kind of curve around and back in to the rim surface where they are more concave on the lower offset wheels.
The 18x8 +45 RPF1 I think will fit those brakes but I'm not positive. |
#100 | |
Drives: Scion FRS. Silver with black badges
Sent from my SM-G955U using Tapatalk |
#101 |
Drives: Toyota 86
Looks like there is pad overhang issue from one of the install video on youtube. Any of u experiencing it and if it will pose a problem in the long run particularly safety?
#102 |
Drives: WRB Limited BRZ
I been trying to grab those calipers for a while but they're always out of stock. Apparently there are new part numbers now.
https://m.facebook.com/ctsvbrakeswap...98882210394953 https://www.facebook.com/ctsvbrakesw...98882210394953 NEW PART NUMBERS: Driver Caliper- AC Delco- 172-2777 GM- 84089034 Passenger Caliper- AC Delco- 172-2768 GM- 84089035 OLD PART NUMBERS: Driver Caliper- AC Delco- 172-2586 GM- 22760030 Passenger Caliper- AC Delco- 172-2587 GM- 22760031 Last edited by Alltezza; 05-12-2018 at 10:47 PM. |
| The Following User Says Thank You to Alltezza For This Useful Post: | Teseo (12-13-2018) |
#103 |
Drives: 2018 BRZ premium
sorry for the bump but are these different then say these???
https://www.amazon.com/dp/B0010G0HP6 https://www.amazon.com/dp/B000S2OR86 |
#104 | |
JDM Spirit of the '90s
Drives: 2015 FR-S Turbo
#105 | |
Drives: 2016 Subaru BRZ
#106 |
Can someone confirm these are pins and brackets that will work with this kit?
ACDelco 18K1971X Professional Front Disc Brake Caliper Hardware Kit with Clips and Pins Link Also what Brake lines are needed? Do i need lines made for these brakes or can I get Steel braided lines made for the FRS/BRZ?
2013 Series 10 FRS #553
#107 | |
You can find all you need to know here: [ame]https://www.youtube.com/watch?v=0Ofn9qgdFsU[/ame] He also links all the products in his video description.
| The Following User Says Thank You to Raven86Project For This Useful Post: | jflogerzi (12-13-2018) |
#108 |
BTW, I have them in my car as well
#109 |
Humm Your looking at 700$ with new Front Brake lines and thats without pads... at current prices.
#110 |
Well shit I hate you guys. You are bad examples!! All parts ordered but pads and new brake fluid.
I picked up some EBC yellow. Seems to be a very good street and light track pad for a decent saving on Amazon. I don't plan to change rear calipers but I will do new pads. What would everyone recommend for rear pads to help with the more forward brake basis with this kit? Should I just go with Yellows all around and match same compound?
RCE T2's, SPC LCAs -4/2.6 camber JDL 4-2-1 EL, FP and OP, Tuned by Zach@CSG on e85 RR Wilwood Front/Rear Sport BBK, Motul 600 Fluid ARC-8 17x9 SX2 GTs 245s/Koing 17x8 v730's 225's Last edited by jflogerzi; 12-13-2018 at 03:09 AM. |
#111 |
Drives: 13 BRZ SSM
#112 |
Look what came in
![]() Link to that color above that looks really nice ![]() Sent from my ONEPLUS A5010 using Tapatalk
| The Following User Says Thank You to jflogerzi For This Useful Post: | turbocat (12-14-2018) |
| Tags |
| ats, brakes, brembo |
| STi Brembos, rotors, and brake lines | jwbrocloud | Brakes, Suspension, Chassis | 5 | 01-09-2015 09:55 PM |
| 04 STI Brembos, Hawk pads, 5x100 front rotors | Philly758 | Brakes, Suspension, Chassis | 7 | 12-06-2013 07:55 AM |
| FS: 2004 STi Gold Brembos(5x100) w/Hawk Pads, Rotors, lines!~~MINTTT~~ | nemesisdrift | Brakes, Suspension, Chassis | 25 | 11-22-2013 12:25 AM |
| 2005 STI Brembos Powder Coated, Hawk HPS Pads, Stoptech Rotors and Braided Brake Line | Jamifra | Brakes, Suspension, Chassis | 10 | 10-29-2013 10:31 AM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
