#1331 |
Drives: Cosworth ('17 BRZ, '76 Vega)
I just went out and checked, and the end of the elbow is fully in contact with the throttle body; it can't go down any further. Also, I tried to see how many pieces of paper I could slide between the cold air pipe and the intake runner for cylinder 3(?), and it turned out that I couldn't even fit a single piece of paper down between them. It's down as far as it'll go, and there's no wiggle available.
#1332 |
Drives: 2016 Cosworth 2.2 BRZ
Not really Cosworth related but I put a catch can on the WRX today as well. We'll see how well these things work...
I checked the BRZ today. I've driven it with the can attached for about 100 miles so far. There is a little oil already collecting in the can. Not much, maybe a few drops. But it's enough to be able to swirl it around. So yes, the BRZ does have some blowby with the supercharger. |
#1333 | |
#1334 |
Yes, remove the other bolts. You want to attach the top bolt first. Don't tighten it down until you get the others started. Once you have the top bolt and the two on the side started, then you can tighten them up all the way.
#1335 | |
Drives: 2017 BRZ
I'm still working on P0172 too. Cleaning the MAF no longer fixes it. I'm hoping I find a vacuum leak when I go to install the catch can, though I always thought an intake leak would result in a lean condition not rich. I'm also confused at how unplugging and cleaning the MAF initially fixed the issue and now it doesn't. |
#1336 | |
#1337 | |
Drives: 2017 BRZ
The strangest thing about it all is that the initial ~400 miles were completely trouble free. Then it starts bogging a few days later, I unplug the MAF and clean it, that fixes it for a few miles, and then the rich/rough running comes back, and now MAF cleaning doesn't seem to help it. I'm going to take a better look at everything tomorrow when I install the catch can. |
#1338 |
I put in the top first(loosely), then worked the front one in a little and managed to force the middle one in on its own, as the threads wouldn't even reach the intake runner with the gdi box and the spacer in place. With the top bolt in place the end of the pipe lines up with the air box much better, but the mounting flange on the side is quite separated from the intake runner. With the top bolt out, things bolt together nicely. With it in, nothing really wants to line up easily; it's like the jig that held things together while fabricating the part was messed up.
#1339 |
Drives: 2017 BRZ
I think I used just one of the side bolts along with the top bolt due to similar alignment issues. I'll confirm tomorrow.
#1340 | |
pessimistic skeptic
Check MAF reading with an OBD-II device before and after. I had idle MAF reading of 3.4-3.5 g/s before fixing the air leaks. After fixing, MAF reading went down to 2.8-2.9 g/s. |
| The Following User Says Thank You to mrg666 For This Useful Post: | gtengr (12-03-2018) |
#1341 | |
| The Following User Says Thank You to sly For This Useful Post: | gtengr (12-03-2018) |
#1342 | ||
Drives: 2017 BRZ
My MAF logs from when it idled acceptably was ~4.3 - 4.4 g/s. That was with a raised ~920 rpm idle. Quote:
| The Following User Says Thank You to gtengr For This Useful Post: | mrg666 (12-03-2018) |
#1343 | |
Drives: BRZ tS
I got this coupler: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 And this filter: https://www.ft86speedfactory.com/bli...17-brz-86.html Both have been working great. I did have to fanagle with the intake tube quite a bit to get the holes to line up, even then I can't get the spacer to fit with the longer hex bolt. I found out my cooling issue was a bad charge cooler, I'll have to post those pictures soon. |
| The Following 3 Users Say Thank You to BoostTheBrz For This Useful Post: |
#1344 |
Drives: 2017 BRZ
Here is the list I'm working through right now, any thoughts or additions?
1. Remove airbox, check for warped connection to hose coupler. Replace coupler with better fitting part. Cosworth coupler seems about an inch too short for solid fit between stock +2017 airbox and Cosworth intake tube. 2. Remove intake pipe. 3. Check/replace crankcase line. I had to add a splice here on original install, I'm going to remove the splice and use a single hose. 4. Add catch can to PVC line. 5. Check torque on main supercharger bolts to head. 6. Re-install everything. Idle test. 7. If idle test fails, replace brake booster line even though it's clamped on each end and appears fine. My research suggests 3/8" line from PCV to can, then 1/2" line from can to throttle body. Anyone know the line size on the crankcase line? I haven't found that in my search yet and want to make sure everything is on hand before I continue. |
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6041 | 11-28-2025 08:08 AM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| Phantom FTS Electric Supercharger Owners Thread | TM | Forced Induction | 1206 | 12-15-2019 02:33 PM |
| Supercharger Kits! Vortech/Cosworth | RallySport Direct | Forced Induction | 61 | 06-29-2015 11:26 AM |
