Old 11-30-2018, 08:50 PM   #20119
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
My black Friday splurge arrived today and is now on the car.
Corsa catback.
It sounds fantastic, better than in videos I've seen. Noise is there when you want it, and quiets right now to near stock when you are cruising not into the pedal.
Old 11-30-2018, 08:55 PM   #20120
jflogerzi
jflogerzi's Avatar
Corsa catback.
Do you have aftermarket headers? If so what kind?
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 11-30-2018, 09:51 PM   #20121
Krewcial5050
Krewcial5050's Avatar
Drives: 2015 Scion FR-s Release series 1.0
Oil & Filter Changed (AMSOIL XL 0W-20)
Krewcial5050 is offline   Reply With Quote
Old 11-30-2018, 10:27 PM   #20122
RToyo86
RToyo86's Avatar
I'm on a otherwise stock setup.
But I am looking at the FT86SF catted header. There is a sound clip on YouTube of that setup.
Old 12-04-2018, 02:16 AM   #20123
Enkrow
Enkrow's Avatar
Not really pic worthy, but I installed the steering rack limiters from the verus brake ducting kit over the weekend. Three spacers takes away the last half turn lock to lock.
I'm not rubbing anymore now, which is very nice.
While doing that, I found about five pounds of rocks from Streets of Willow Springs in the undertrays. Coincidentally, my high RPM rattles have all disappeared!
Enkrow is offline   Reply With Quote
Old 12-06-2018, 10:21 PM   #20124
Impureclient
Drives: 2015 FR-S
I installed a magic trunk button. Now I can turn the trunk light off or on manually when the trunk is open.
This is so when the trunk doesn't fully close, it doesn't completely drain the battery overnight., so I will keep it in the off
position until I actually want it on now.
Switch that fits exactly in the preexisting hole on that latch mechanism. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 12-06-2018, 10:25 PM   #20125
Ashikabi
Ashikabi's Avatar
Do you have closure issues often?
Old 12-06-2018, 10:25 PM   #20126
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
Nice Install. Have you had a problem with leaving your trunk open?
you could have just installed a led bulb and it should easily burn all night without draining the battery.
fx1mark is offline   Reply With Quote
Old 12-06-2018, 10:27 PM   #20127
Impureclient
Drives: 2015 FR-S
Yep. I've drained the battery 3 times dead now. I even removed the black trunk bumper things to make it easier to
close and still didn't shut it fully. This is a 100% fix for no more dead batteries from that light being left on.
Thank you. It's only visibly distinct from stock by those red and blue wires that I didn't fully tuck in. Doing that right now.
I also installed a LED strip light in there that is crazy bright so that might be why it fully drained the battery overnight.
Old 12-06-2018, 10:31 PM   #20128
Ashikabi
Ashikabi's Avatar
Just get a big wing. Solve that closure problem quick
Old 12-06-2018, 10:34 PM   #20129
Impureclient
Drives: 2015 FR-S
It was either install the $4 switch or get a full Rocketbunny kit with that massive wing or it would have looked out of place with just the wing.
Old 12-06-2018, 10:50 PM   #20130
Ashikabi
Ashikabi's Avatar
... and?
Old 12-06-2018, 11:22 PM   #20131
Impureclient
Drives: 2015 FR-S
... and?
I had the rocket bunny kit with wing, wider wheels and tires, etc. all in the cart online ready to buy to fix this trunk light problem but then I just bought the switch instead.
Old 12-06-2018, 11:29 PM   #20132
JD001
JD001's Avatar
Drives: Subaru BRZ
With a clip I hope...
