Old 11-30-2018, 07:17 AM   #15
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Originally Posted by FunnyGopher View Post
I have the same setup as you, and every few months I get a P000X code that I have to go in and clear. I've checked everything over, car doesn't idle or run strangely, nothing seems to be bad. It just happens in strange braking circumstances for me.
Use your EcuTek cable, dongle, and laptop. You can go to tools > something like 'detect vehicle' > then something along the lines of 'All DTC'. You can then 'Read DTCs'. It'll output a log of the codes it read, and from what computer it read them from. There's a computer for the A/C, the ECU, etc.
I always have an A/C code thrown. I found it was for a Toyota auto climate feature that isn't even possible in our cars because of a sensor we don't have, but is in a Lexus, so I don't worry about that. Then there's a C1201, which from my understanding is the code that throws when there's a code thrown. It just tells the car to keep the check engine light on. Then the code that caused my problem. In my case, it's always the P000X codes. Once you have your code, you can lookup what the code means on the internet, and you're on your merry way.
Happy hunting.
I see your mods. Whats your dyno on e85?
Dr. BRZ is offline   Reply With Quote
Old 11-30-2018, 08:20 AM   #16
FunnyGopher
Drives: 2015 BRZ Limited
Sadly, I haven't dyno'd the car with ethanol yet! I really need to. However, here's what it was able to do on AZ 91.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 11-30-2018, 08:27 AM   #17
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I got my first CEL a couple of month ago. Was stopped at an intersection, pressed the throttle and the CEL started flashing and the car went into limp mode. I pulled over, shut off the car, pulled out my OBD II reader which I always keep in the glove box, read the code (P2135), then did a search on the internet on my phone what it was. Car started up fine, continued driving to work and then did my research on it.
My point is, the first step to dealing with a CEL is having a code reader in your car. It's cheap and worthit.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
humfrz (12-01-2018)
Old 11-30-2018, 08:31 AM   #18
stlgrym3
Is this something my ecutek cable and laptop can do? I don’t work on my cars so I go to reputable shops get my work done and this was the first CEL I’ve encountered since I got that set up 3 months ago. Any good ODB2 readers to recommend?
stlgrym3 is offline   Reply With Quote
Old 11-30-2018, 08:41 AM   #19
FunnyGopher
You can use your cable and laptop, just like you used it to flash the tune, to also check your codes. Just follow the instructions I provided previously. No need to buy another ODB2 reader, unless you didn't want to carry your EcuTek stuff around in your car with you at all times.
The Following User Says Thank You to FunnyGopher For This Useful Post:
stlgrym3 (11-30-2018)
Old 12-01-2018, 01:02 AM   #20
shiumai
shiumai's Avatar
Or a laptop. I'm not in the habit of carrying my laptop with me.
Old 12-01-2018, 03:59 AM   #21
FunnyGopher
Also very true. I, however, am a software developer, and I do have the habit of carrying my laptop around with me. Lol. It would be nice to have like, an old netbook or something that I could leave in the glovebox. Something smaller.
shiumai (12-03-2018)
Old 12-01-2018, 12:26 PM   #22
I suggest a stocking stuffer from a loved one to you …
Old 12-02-2018, 08:08 PM   #23
FunnyGopher
Heyo! That's not half bad. Thanks!
humfrz (12-03-2018)
How to screw up your cars handling and ride - step by step! Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 401 02-12-2023 11:36 AM
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) runny_yolk Electronics | Audio | NAV | Infotainment 120 01-29-2021 06:18 PM
[StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:38 AM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:27 AM
