Old 11-11-2018, 10:21 PM   #1219
zeal86
zeal86's Avatar
Drives:
The very forward part of the front section of the skirt will be molded. The normal transition from skirt to fender looks silly because of the drop off and because the skirt hangs lower than the lowest part of the inner front fender.
To fix the aforementioned... I'm going to add fiberglass to the inner front fender (pictured in previous post) to even it out and fiberglass filler to the drop off so the front of the skirt flows into the inner fender.
I'm hoping to get this done this week.
IG @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 11-16-2018, 11:03 PM   #1220
zeal86
zeal86's Avatar
Drives:
I made some more progress on the front section of my skirt...
It is now bonded and also I finished fiberglassing the short extention. Tomorrow I'll bondo the area and sand and shape it...
IG @zeal.eightsix
Old 11-17-2018, 01:11 AM   #1221
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
**nods approvingly**
Originally Posted by humfrz
I'm old and lazy
Old 11-17-2018, 03:21 PM   #1222
zeal86
zeal86's Avatar
Drives:
Three more from this morning...filler, sanding, and shaping up next...
IG @zeal.eightsix
Old 11-18-2018, 01:20 PM   #1223
zeal86
zeal86's Avatar
Drives:
Just need to square it up once the fender is on and fill the pinholes before I spray it with some high build primer.
IG @zeal.eightsix
Old 11-18-2018, 08:21 PM   #1224
zeal86
zeal86's Avatar
Drives:
I have it almost ready for primer... Since taking these pics I've added some more filler...I just have to sand, shape, and fill in any pinholes...
Btw, I had to add some filler because when I reset the skirt section prior to bonding...the position changed slightly after I reinstalled the 2 spacers. Instead of effing with the alignment during the cure process I just used bondo.
IG @zeal.eightsix
Old 11-23-2018, 08:48 PM   #1225
zeal86
zeal86's Avatar
Drives:
I may have my passenger side front fender done and primered by Sunday. I just need to finish up with my driver side garnish before I bond my passenger side garnish. Reason for that is that I want to make sure both garnishes are as identical as possible.
pics coming soon...
Also, got a nice BF deal on some Valenti Sequential Tail lights. Clear lens with black housing... should look great with my Morimoto headlights.
I'm going to have to figure out how I will install a reverse light since my current reverse lights are in my tail lights. I have some ideas floating around in my head already.
IG @zeal.eightsix
Old 11-24-2018, 08:51 PM   #1226
zeal86
zeal86's Avatar
Drives:
Ok... the fender is placed but not secured in these pics...once bolted down everything does lines up. I have some minor things to square up but this part is almost done.
I did get around to bondo-ing the driver side garnish... I just have to primer it and check it against the passenger side one. Once all is good... I'll bond and mold the passenger side garnish to the fender.
IG @zeal.eightsix
Old 11-25-2018, 09:49 PM   #1227
zeal86
zeal86's Avatar
Drives:
Here are some more progress pics...
Also, I fabricated the pictured garnish a short while ago. I finally got it bonded to the fender... I'll hopefully complete the molding process this week. I drew inspiration for the garnish from the Varis WB front fenders. Pics of completed fender coming soon.
IG @zeal.eightsix
Old 11-26-2018, 01:01 PM   #1228
arkanist
Drives: 2016 BRZ Limited, Stock
I think the formatting is off, just seeing the URLS for these
arkanist is offline   Reply With Quote
Old 11-26-2018, 01:04 PM   #1229
zeal86
zeal86's Avatar
Drives:
Thanks man... you were right... should be good now.
IG @zeal.eightsix
Old 11-26-2018, 01:18 PM   #1230
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Saw some of these on Instagram. Incredible work, you're amazing!
Old 11-30-2018, 07:26 AM   #1231
sqd
sqd's Avatar
Drives: '13 SWP GT86
Agreed, love your work But you know this already, haha
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 11-30-2018, 05:43 PM   #1232
zeal86
zeal86's Avatar
Drives:
Black Friday deal plus Military/Vet discount... just had to do it... lol Last part I'll order for a while...
Will look good with my Morimoto headlights!
IG @zeal.eightsix
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 08:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 07:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
