Old 07-12-2012, 03:51 PM   #57
xcelir8brz
Drives: 2013 BRZ Limited
Originally Posted by zex View Post
Could you give a link? I cant seem to find it :P
http://www.autozone.com/autozone/acc...ntifier=343447
Comes in a two pack for I think $16 bux.
xcelir8brz is offline   Reply With Quote
Old 07-14-2012, 10:05 PM   #58
cto424
did you also get the bulb sockets at autozone? did a quick search and only get returns for the led bulb.
also are 1157 the stock brake light bulb size too?
cto424 is offline   Reply With Quote
Old 07-14-2012, 10:18 PM   #59
xcelir8brz
I picked up one socket and a two pack of 1157 bulbs at Autozone (in the store).
Old 07-15-2012, 08:18 PM   #60
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
How are you keeping the water out???
Lee358 is offline   Reply With Quote
Old 07-15-2012, 09:31 PM   #61
xcelir8brz
The stock reverse sockets seal pretty well without water entry.
When I did my project, I also put some hot black glue to help seal it. I also created a plastic piece to go below the wiring (above the exhaust) where the center bumper cutout is and tie wrapped it to make sure.
Furthermore, I pressure checked it. I also did the water test on the inside for leakage, and vacuumed it all out (including any condensation). It's bulletproof regarding moisture entry.
Bottom line, get a good socket, do a good job, and you won't have to go through and do all the testing I did.
The Following User Says Thank You to xcelir8brz For This Useful Post:
Dadhawk (07-16-2012)
Old 08-15-2012, 11:41 PM   #62
cto424
anybody who did this mod get condensation?
Old 08-16-2012, 07:27 AM   #63
xcelir8brz
No condensation.
Old 08-21-2012, 05:35 PM   #64
STORMSHADOW81
Drives: 2013 SCION FR-S FIRESTORM
nice
Originally Posted by Silverdub View Post
Hello everyone!
Did any warning lights come on after your installation was done? such as bulb out warnings .....ect
STORMSHADOW81 is offline   Reply With Quote
Old 08-21-2012, 05:47 PM   #65
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
no not at all!
Silverdub is offline   Reply With Quote
Old 08-22-2012, 07:14 PM   #66
Chris135
Originally Posted by RZ86 View Post
I'm a bit confused, what is the point in this DIY? Do your rear foglights not turn on in the states? We have a switch to turn them on when the headlights are on.
Actually US cars do not have a rear fog light. It is something that has appeared on imports here and has begun to receive recognition as a safety feature.
Also the FRS has no wiring for the rear fog light, I am not sure about the front.
Chris135 is offline   Reply With Quote
Old 08-23-2012, 06:09 PM   #67
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by Thongpocket View Post
Soldering>Crimping. Glad to see someone else doing it the good way.
If you really want it done right toss the electrical tape and use shrink tubing.
The Following User Says Thank You to wbradley For This Useful Post:
SkAsphalt (12-22-2012)
Old 08-23-2012, 07:47 PM   #68
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
I used a 194 t10 led, works and looks great
Name:  ImageUploadedByTapatalk HD1345762027.348553.jpg
Plxdjake89 is offline   Reply With Quote
The Following 2 Users Say Thank You to Plxdjake89 For This Useful Post:
calis5nest (12-29-2012), JFBRZ711 (01-29-2014)
Old 08-23-2012, 10:08 PM   #69
wbradley
Sarcastic SOB
wbradley's Avatar
Correct me if I'm wrong, but the bulb out warning is the issue people get installing LEDs on a Canbus enabled harness? Apparently Canbus standard is used in most all Euro (German) cars.
Old 08-29-2012, 10:29 PM   #70
xcelir8brz
Only on blinkers.
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 02:19 AM
rear seats? EJ20 BRZ First-Gen (2012+) — General Topics 67 11-12-2012 08:15 PM
Rear Bumper Foglight kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2012 01:47 AM
215/40-17 front, 225/40-17 rear? ZDan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-21-2012 03:08 PM
