, dpfarr
Old 11-21-2018, 03:17 PM   #2899
Chris3007
Drives: 2013 BRZ Limited 6MT
Hello everyone, I finished installing my supercharger and thought I would share some feedback here:
The Install:
Overall a very smooth install. It took me about 10 hrs total working by myself (minus a buddy helping set the blower on the manifold) over the course of a few days. I also installed the radium dual catch can kit during this time. No major hang ups or challenges, instructions are very clear and concise.
I purchased the kit used and had to buy some new consumables (gaskets, crush washers, and a few missing hoses). Support from superchargers online was very good and was able to get everything in ~ 2 weeks time.
I would highly recommend quality hose clamp pliers. I bought them specifically for this project and used them a lot. I too, like others suggested connected the coolant hoses to the back of the heat exchanger before placing on the manifold, this was a big help.
Driving Impressions:
I went from OFT stage 2 with EL headers and 3" cat back so the change was not as drastic as going from stock. I also am currently only using the Edelbrock CARB tune because winter is here in NY and only had a few days to drive before putting away for the winter. I plan to get the Delicious tune in the spring (I feel there is a lot more to be had with a better tune).
Overall very happy with the new power band, when it cracks 4k RMPs it really goes. The best I can liken it to from past driving experiences is my stage 1+ Audi TT 1.8T. Highway on ramps are much more enjoyable now!
Gas mileage hit was pretty big, I could consistently get 34 - 36 MPG highway, and now I'm averaging ~24 MPG. Also, I may be crazy but it seems the exhaust note is now a bit louder (and was already loud to begin with). Only other negative is the Edelbrock tune; it idles a little choppy and throttle response is mediocre, although I likely attribute this to my other exhaust mods.
Overall very happy with the kit. It was a fun project and I picked it up for a great deal. Looking forward to the better tune in the spring!
Chris3007 is offline   Reply With Quote
The Following 3 Users Say Thank You to Chris3007 For This Useful Post:
BertoFT (11-21-2018), HachiRokuX (12-30-2018), paiceyfan (11-21-2018)
Old 11-21-2018, 08:50 PM   #2900
CSG Mike
CSG Mike's Avatar
@Chris3007
Your car will drive FAR better when you get a proper tune dialed in to your mods. The CARB tune is literally only meant for otherwise stock powertrains, and won't run/feel right with other power mods!
Old 11-21-2018, 09:33 PM   #2901
Mr_Eyo
Drives: 2017 Toyota 86
@Chris3007
What about a catted UEL header? Would a new tune be needed over the CARB tune?
Mr_Eyo is offline   Reply With Quote
Old 11-22-2018, 12:32 AM   #2902
CSG Mike
CSG Mike's Avatar
As stated many times, the CARB tune is for the STOCK header and STOCK front pipe only.
Any deviation requires a tune to run properly.
PM to order a custom tune.
Old 11-23-2018, 10:23 PM   #2903
Colin86
Drives: 86
Originally Posted by shr133 View Post
How bad is your wheel spin???
I'm going to be running a similar set up. I'm finishing up my E85 tune and I have full 2 1/2" exhaust w EL header.. Hope to get my supercharger in summer...
At the drag strip I spun all the way through first gear and halfway through second. I was way too aggressive on the launch, with more practice/finesse it wouldn't have been so bad.
If conditions are right on the street I've rolled into first and maintained a decent amount of traction, although there's almost always a little slip. If conditions aren't right first gear will completely break away. Second can be rowdy, but it's uncommon to completely light the tires up the way first occasionally does. Things are drama free in third gear and above, but the car continues to pull hard. Car still had healthy acceleration in 5th at 128mph on the road course.
You're in for a good time.
Colin86 is offline   Reply With Quote
Old 12-03-2018, 02:22 PM   #2904
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Has anyone here done a complete tear down of the supercharger plenum? Anyone want pictures when I do mine? I think the butterfly valve surround on the anti surge return was manufactured incorrectly (confirmed for initial models by edelbrock but not mine) so I'm going to tear down and find out.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
BigFatFlip (12-05-2018)
Old 12-05-2018, 05:48 PM   #2905
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Originally Posted by BirdTRD View Post
I guess it's belt time. 23K miles and a little over 2 years. I heard a slight squeal a couple weeks ago on start up (a little cold outside) but that's it, I never heard that piece slapping the hood, could have been while the car was warming up though.
Sorry to hear about the belt. Did you happen to notice if the belt jumped a rib on the water pump pulley or the a/c compressor pulley?
Thanks
Nitro22 is offline   Reply With Quote
Old 12-05-2018, 06:09 PM   #2906
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Ewww, that doesn't sound good. I no longer have mine, but I've always been curious about it, so some pics would much appreciated!
Old 12-05-2018, 10:54 PM   #2907
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Thanks
I actually checked for that. The belt was where it was supposed to be on all the pulleys so I'm not sure what may have caused it to come apart like that. I can't imagine that it's just "normal" wear and tear though.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Nitro22 (12-05-2018)
Old 12-06-2018, 12:47 AM   #2908
GrabTheWheel
Drives: 16' BRZ
I know someone on here must know somebody who wants a barely used Edelbrock kit for Christmas (less than 1000 miles on the kit). If so please send me a PM.
GrabTheWheel is offline   Reply With Quote
Old 12-06-2018, 10:26 AM   #2909
gtengr
Drives: 2017 BRZ
FWIW, the Cosworth kit instructions recommend replacing the belt every 10k miles.
gtengr is offline   Reply With Quote
Old 12-06-2018, 01:46 PM   #2910
toast
Drives: 14 BSP Edelbrock BRZ
This might be the only way to get one before Xmas, I've been waiting for mine for more than 2 months and am told there is a line behind me...
toast is offline   Reply With Quote
Old 12-06-2018, 03:29 PM   #2911
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Interesting. I don't see anything in the Edelbrock installation that specifies belt life or replacement interval.
Old 12-10-2018, 02:38 AM   #2912
jflogerzi
jflogerzi's Avatar
Has anyone installed the OEM oil cooler using the alternative throttle body option. I am guessing this would be a no go due to the supercharger?
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
