#57 | |
Drives: 2016 White Pearl BRZ Premium
#58 | |
I have not since mid summer. My season is over, unless I send it out with someone going out of state this winter. |
#59 |
Drives: Fr-s
Anyone run RS3 and RS analysis on a Microsoft Surface? I'm considering picking up a Surface Go for this purpose.
I figured for this and travel it would work fine, I have another laptop, which I'd rather not lug to the track, for other tasks (such as video).
#60 |
I don't own a surface, but yes, I've used a surface for it many times.
The high resolution is fantastic for it. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | redlined600 (11-29-2018) |
#61 |
Drives: World Rally Blue BRZ
Does anyone's Solo 2 battery still drain even if it is turned off? Had mine go all the way down to 0% after a week or two. Having to remember to charge it before an event is a PITA.
#62 |
They do slowly discharge over time
FYI there was another firmware update last week. |
#63 |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Man, I really don't like the new Solo. I feel like it's harder to read and has more glare or something.
How on earth do they not use those lights on the side better? It would be AWESOME if they went red to green for predicted. Then I could go through a turn and quickly see "oh, thats better/worse" when I do __________ .
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#64 | |
Drives: 2014 Subaru BRZ
There are also a few options for the backlight which might help with glare, I put my Solo2 on the front quarter window so it's just above the vent on the left side of the steering wheel. That keeps it out of the any glare and as a bonus I can use it as an extended handle to help shut the door. |
| The Following User Says Thank You to 14stu For This Useful Post: | CSG Mike (12-04-2018) |
#65 | |
But yeah, the display isn't the best under sunlight...I do prefer the old solo when it comes to the display |
#66 |
I think you are missing what I’m asking for. I want it to go read when my predicted is increasing and green when it is decreasing.
#67 | |
For example: if I go around a corner and watch the lights, if I'm faster the lights are green and if I'm slower they're red. Now, as long as I keep the same number of lights on, I'm not gaining or losing time. If I get fewer red or more green lights, I've going even faster. The lights predict how much better/worse you'll be than your reference lap (fastest of the session, fastest of the day, or I believe you can just load/leave your fastest lap as the reference). I was on the 1.7cw at MSR-C Saturday, and since I have so few laps in that direction I was still experimenting with different lines through multiple corners throughout the day. The LED's immediately told me if a line was faster or slower and by how much (to the nearest tenth). I've found that this type of data is much more helpful than "theoretical best times" for making improvements. I'm not sure how this is different from what you want. My best guess is that you want to save your PB and have the lights tell you if you are improving sections time compared to your PB. I believe that you can set the Solo2 to do this by setting your PB as your reference lap, but I haven't tried (my opinion is that conditions vary enough that using the best time of the day/session is the best way to get faster, but I also always study my PB before and compare after a trackday). PM me if you want to share BRZ data for the local tracks (I'm BRZ4Science on TrackJunkies.org, btw). |
#68 | |
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
This is something I was very interested in, and while the Solo does appear to support it, our cars do not. We'll have to monitor oil pressure via a sandwich plate beneath the oil filter or an unused gallery plug on the block. I don't own a Solo 2 DL, but I'm pretty sure there's no way to "add" this value to the unit if not by OBDII. Anyone who is more familiar with the unit may correct me if that's false. While this product looks really cool, I think it's just not worth the trouble for me at this price point (for now). Maybe down the road it will make more sense.
#69 | |
Drives: Nevermorange FRS
Yup, I did learn that the car itself doesn't support OilT. This was on my list for my t4 build but I already have the original Aim Solo and since I got the Innovate combo OilP/OilT gauge and a WaterT gauge I figured the new DL2 was unnecessary. Down the road I may add it because it could be a good substitute for the dash and the other data it gathers from the computer could be a valuable analytical tool. However, when that time comes it may just be worth spending a few extra $$ to buy the MXM or MXS.
PRO86 | WTCC | STL
#70 | |
Not to go too off topic, but how do you like that Innovate combo gauge? I've taken a peak or two at it a couple times over the past few weeks, and I think it may be in my favor to pick one of these guys up.
| 2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| First FR-S in Ottawa Solo2 Event | Klinn | CANADA | 0 | 06-12-2012 11:13 AM |
