Old 11-18-2018, 07:59 PM   #1275
gahooligan
Drives: 2017 BRZ Premium
Originally Posted by gtengr View Post
Removed the MAF, cleaned it (didn't appear dirty), and the car runs great again. I get the feeling this isn't over though. Why would a MAF with 11k miles on it (always stock airbox and filter) be dirty? Are the oil vapors from the PCV able to travel upstream during certain throttle conditions and foul it?
I have an idle log, but it's 0.2 mb too big for datazap. Short term fuel trims were around -16% but varied. Sent the idle log to my tuner (Delicious).
You didnt install something like a perrin intake or k&n filter, with an over-oiled air filter did you? No way PCV vapors are traveling backwards up the intake.
Sent from my SM-N960U using Tapatalk
gahooligan is offline   Reply With Quote
Old 11-18-2018, 08:00 PM   #1276
gahooligan
Are the pins in your connector secure? Unplugging and replugging may have been what solved the issue... just a thought.
Old 11-18-2018, 08:15 PM   #1277
gtengr
Drives: 2017 BRZ
Nah still stock. Need to get an air filter though. Was going to get a CAI and muffler if I'm still happy with the car overall in a few months. Do you still have your Perrin CAI and want to sell it?
That was one of my initial thought. The harness to the MAF is a bit tight, and the engine torquing on its mounts pulls on the airbox which is mounted to the chassis (another reason I want to move to CAI), so the engine could have been pulling on the connector enough to slightly unseat it or something. I fed it as much slack as I could when I re-installed the MAF. It ran fine for about 15 miles today, but I had to park it to travel for work and won't be able to mess with it again for a few more days.
gtengr is offline   Reply With Quote
Old 11-18-2018, 08:57 PM   #1278
gahooligan
Sold the perrin but you may be on to something with the connector...
Old 11-18-2018, 09:09 PM   #1279
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Trade you your rich code for my lean code. I still can't figure out why I'm throwing P0171
sly is offline   Reply With Quote
Old 11-18-2018, 11:41 PM   #1280
gahooligan
Lean on top end or idle?
Old 11-19-2018, 12:41 PM   #1281
eMCee
eMCee's Avatar
Drives: GT86
Hi Gents,
Sorry to interrupt the flow.
I've posted a dyno chart in dedicated thread with graphs before, and after the installation.
It showed around 285HP/ 335Nm (247lb-ft) at the engine.
Stock exhaust and engine, on 102 RON fuel.
What do You think, optimistic, dyno cheat, or as expected?
Now only one thing is on my mind - forged con-rods and bearings, or not
eMCee is offline   Reply With Quote
The Following 2 Users Say Thank You to eMCee For This Useful Post:
Seba (11-25-2018), sly (11-19-2018)
Old 11-19-2018, 01:30 PM   #1282
sly
sly's Avatar
What size pulley are you using? That sounds pretty good. Better than I expected for stock exhaust.
Old 11-19-2018, 01:33 PM   #1283
sly
sly's Avatar
Both but mostly idle. I don't want to jinx it as I haven't taken a new ECU log yet, but I let it idle for about 5 minutes and did not get a CEL. I took the throttle body, intake tube and all vacuum lines off. Notice that the throttle body was fairly black underneath. Indication of oil blowby. Only had the charger on 10,000 miles or so. Surprised there was that much. Definitely need a catch can.
I cleaned the throttle body and put hose clamps on every vacuum line at both ends. Noticed my evap hose had not been fully seated. So far no CEL. I have a dedicated thread regarding my lean conditions. Will update it later once I make a determination.
Old 11-19-2018, 01:41 PM   #1284
eMCee
eMCee's Avatar
Drives: GT86
Hi sly,
It was a default one that came with the kit. I belive it's 70mm.
Old 11-19-2018, 06:36 PM   #1285
gtengr
Drives: 2017 BRZ
Hi Gents,
I think it looks about right for flywheel hp and your mods.
Old 11-19-2018, 09:23 PM   #1286
gahooligan
Something I learned that others may disagree with, take it for what its worth... It's been said that a catch can is not needed with this kit. I ran a UPR can from my other vehicles. It caught a lot of oil. I can also 100% guarantee you that if you overfill this engine in the slightest it will push more oil than you can believe out the PCV... With a 1/2 a quart or less overfilled, running high rpms and boost at a track day, I completely filled the can. To the point it was sucking in into the intake and smoking badly. Once i fixed the oil level, never had the problem again. I was always EXTREMELY careful after that to not overfill, even in the slightest. Run a can and never overfill. My $.02.
The Following User Says Thank You to gahooligan For This Useful Post:
sly (11-20-2018)
Old 11-20-2018, 12:39 AM   #1287
sly
sly's Avatar
I have the Forester OEM oil cooler installed and I had been adding about a couple ounces more of oil than what was recommended. Now that I think of the way it is designed, it probably doesn't need ANY extra oil. I may have been overfilling it and that may have caused the blowby. Thanks. I'll back off on the oil and get a can just to be sure.
Question is where to mount it. The fitted kits put the can at the back of the engine where my throttle body now is. I can't really put it near the battery because that's where the new coolant reservoir and pump are for the intercooler.
Old 11-20-2018, 01:11 AM   #1288
gahooligan
Just make new lines. Legnth doesnt matter so much... I mounted mine off the passenger strut tower.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
