Old 11-08-2018, 10:39 PM   #43
dpaqu
Drives: 2018 Gt86
Originally Posted by Code Monkey View Post
Shit still not working the way it should for me. With the 86Nanny, AiM sometimes turns on when I start the car, sometimes it does not. The SmartyCam turns on when the AiM turns on automatically, but when I have to start the AiM manually, the SmartyCam does not turn on automatically, I have to press the power button.
Yesterday the AiM worked for the first two hpde sessions, then it shut off in the middle of the third session and the SmartyCam stayed on.
Very frustrated with the setup.
Have you been able to correct the issue?
dpaqu is offline   Reply With Quote
Old 11-09-2018, 08:58 AM   #44
Code Monkey
Drives: Subaru BRZ
I moved the Nanny OBD extension cable away from my right leg and it seemed to help, maybe I was rubbing against the cable during track sessions. Still, the auto on/off function is not working as it should. After shutting the car off, the Solo stays powered all the time, like an hour later you get back to your car for another session and the damn Solo screen is on.
Code Monkey is offline   Reply With Quote
Old 11-09-2018, 10:33 AM   #45
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
I have the same issue. You need to zip tie the connector to the OBD port. THEN I also pull the wire towards me and make sure the line is tight then tape it on the side (pastic) up a bit before routing it back down around the gear and to the Smarty Cam.
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
The Following User Says Thank You to lutfy For This Useful Post:
Code Monkey (11-09-2018)
Old 11-09-2018, 12:15 PM   #46
dpaqu
Drives: 2018 Gt86
I'm going to have to get one. Just wish I could log oil pressure. Also not thrilled with the reports of how buggy it can be.
Old 11-09-2018, 06:11 PM   #47
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I was looking at the user manual and under the display settings (page 24) it has a screen shot of a OILP (oil pressure) being displayed in BAR.
https://www.aim-sportline.com/downlo...de_101_eng.pdf
PRO86 | WTCC | STL
Old 11-18-2018, 12:51 PM   #48
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Can someone tell me how to put this thing in predictive mode!?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 11-19-2018, 11:02 PM   #49
ka-t_240
Anyone having battery issues? I can leave home with mine fully charged. Get to track(the one a 6 hour drive) and it was already sub 80% with being off the whole time. Unit was dead after 2 -3 sessions.
Or should I expect to just have to leave it on a charger 24/7
ka-t_240 is offline   Reply With Quote
Old 11-20-2018, 02:43 AM   #50
CSG Mike
CSG Mike's Avatar
You have to configure and enable screens in Race Studio 3.
Old 11-20-2018, 11:13 AM   #51
GrandSport
GrandSport's Avatar
Ugh, what? Was the Solo1 too user friendly?
Same here. Have to charge it between sessions. I think I PREFER the Solo1. This is crap. All it did was add colors.
Old 11-20-2018, 12:13 PM   #52
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Have you updated the firmware recently? I think one of the updates was to help improve the battery life.
Not sure if it worked though, if mine's in the car it's plugged into the OBD2 port which powers it.
Joesurf79 is offline   Reply With Quote
Old 11-20-2018, 02:44 PM   #53
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
It sounds like there are a bunch of issues with the 2DL. Should I just go for an original version, or are these just pending code fixes that haven't rolled out yet?
mistople is offline   Reply With Quote
Old 11-20-2018, 03:13 PM   #54
CSG Mike
CSG Mike's Avatar
I prefer the solo 1 too at this point. The few added features of the Solo 2 is not worth the hassle of not beign able to do ANYTHING without a computer.
Old 11-20-2018, 03:13 PM   #55
CSG Mike
CSG Mike's Avatar
They're updates that need to eventually roll out.
FWIW, the Solo 1 was a total shitshow for years when it first came out.
Old 11-20-2018, 07:58 PM   #56
redlined600
redlined600's Avatar
Drives: Fr-s
It seems to, after updating mine, it sat for a long time without totally killing the battery.
redlined600 is offline   Reply With Quote
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
First FR-S in Ottawa Solo2 Event Klinn CANADA 0 06-12-2012 11:13 AM
