Old 11-16-2018, 05:32 PM   #1261
gtengr
Drives: 2017 BRZ
Well the car ran fine for about 500 miles, but today it started running rough intermittently and has the P0172 code. I pulled over and did a hand check of the vacuum attachments and intake clamps for tightness and they all seemed ok. I don't think it's a vacuum/intake leak since the problem comes and goes. Seems more like it's a sensor or electrical connection. A search points to most people having this issue with aftermarket intakes, but I'm using a stock 2017 intake and air filter with ~10k miles with the Cosworth kit. Anyone else dealt code P0172? I'm going to check the O2 sensor splice harness and the MAF, and do some datalogging tomorrow.
gtengr is offline   Reply With Quote
Old 11-17-2018, 03:10 AM   #1262
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Originally Posted by Seba View Post
Hi,
what device and software do you use to collect and save live data when driving the car?
Seb
I use a laptop running Windows 7. EcuteK software loaded. Cosworth USB stick, EcuteK cable plugged into OBDII port.
sly is offline   Reply With Quote
The Following User Says Thank You to sly For This Useful Post:
Seba (11-25-2018)
Old 11-17-2018, 03:28 AM   #1263
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Originally Posted by weederr33 View Post
I believe you can make the pulley smaller, but it would need some adapter which could protrude a bit and hit the hood potentially. Matt@Cosworth talks about it a bit somewhere in this thread as well as on the UK thread.
It's a shame you guys don't have corn power (E85). :/ And yeah going crazy on all the bare metal is no fun. When I had my kit, it felt damn good at just 280 bhp. But that's all relative.
hello gents
If you already have the small 63mm pulley then there's no room to go smaller with the standard nose gearbox on the charger
I did a mod on our dev car to increase the diameter on the stock crank pulley by about 6% with a interfered on sleeve and then resized the ancillary pullies, modified the tensioner so it can swing over more and fitted smaller idlers
this then gives you about 0.8bar of boost and 330bhp ish providing you have some steel rods in there
the biggest issue with going this route is the pulley then clouts the front cover and the boss it hits is the oil gallery route
so this has to be modified / welded up and broddled to remove the sharp corners inside - this also helps with the oil pressure at high rpms anyway so very worthwhile while you have the engine apart anyway
the charger is capable of 1.2 bar and the cooling system was all sized for this from the beginning so that will be fine
other mods to try I'd also say to investigate a larger / ported throttle body and an aftermarket air intake as with the smaller pulley you will start to get a restriction due to both of these
as ever steel rods are very strongly reccommended on this engine at anything past what our kit delivers
Matt@Cosworth is offline   Reply With Quote
Old 11-17-2018, 10:14 AM   #1264
gtengr
Drives: 2017 BRZ
Good info. Any recommendations on which air intake fits/works best with the kit?
Old 11-17-2018, 02:35 PM   #1265
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
You could try the Perrin CAI. It sits in the bumper and is supposed to get the coldest air. The only pain is changing the filter come that time.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
gtengr (11-17-2018)
Old 11-17-2018, 02:57 PM   #1266
Kodename47
Kodename47's Avatar
Drives: UK GT86
I've gone Airaid on the Sprintex. As this uses the OEM airbox too, it can be made to fit and no bumper removal required. I think the Skunk2 offering could be made to work as well. Most other intake kits move the MAF to the replacement tube so aren't an option.
.: Stealth 86 :.
Kodename 47 DJ:
gtengr (11-17-2018)
Old 11-17-2018, 06:25 PM   #1267
muckypuppy
Drives: MY13 SWP BRZ Cosworth 2.3
I am running the Perrin CAI and I believe Gahooligan was as well until he sold his kit. Both our cars were running the small pulley and E85 tuned by Delicious.
muckypuppy is offline   Reply With Quote
Old 11-18-2018, 12:34 PM   #1268
Cosworth_0686
Drives: Cosworth ('17 BRZ, '76 Vega)
The other pic is of the fuel connector bracket that I cut instead of using the aftermarket fitting. I preferred keeping the factory fitting and buying it again to go back to stock rather than mod the line.
I finally got the Cosworth tune installed and verified that it runs!! Now that I've started actually taking things apart, I've encountered the instruction to cut the stock fuel lines, and I'm a bit hesitant about that, as I'd like to keep that connector if possible. To verify the part that you cut instead, was it along the red line that I drew in? Does the other quick-connect fuel line just attach back to the stock location?
Cosworth_0686 is offline   Reply With Quote
Old 11-18-2018, 01:03 PM   #1269
sly
sly's Avatar
Here is the way the lines are intended to be attached. I just cut the fuel line itself and left off the quick disconnect. IMO dealing with hose clamps is more convenient than dealing with the quick disconnect that needs a special tool.
The GDI fuel pump, which is the metal one with the QR code etched in it, comes with a new banjo fitting. Use some washers and a hose clamp and you're done. The other fuel line goes to the manifold injectors. Again a simple hose clamp does the job. I've never had any fuel leaks.
Old 11-18-2018, 02:04 PM   #1270
gtengr
Drives: 2017 BRZ
yes that's where I cut
Old 11-18-2018, 04:00 PM   #1271
Matt@Cosworth
interesting
how much power did you make?
Old 11-18-2018, 04:32 PM   #1272
gahooligan
Drives: 2017 BRZ Premium
This is true. Perrin worked great. But, i was on 93, no e85. I didn't feel like getting gas every other day...lol. Dont know how much power I made but it was fast and i had mustang drivers tell me, on track, it was fast...
Sent from my SM-N960U using Tapatalk
gahooligan is offline   Reply With Quote
Old 11-18-2018, 05:42 PM   #1273
Cosworth_0686
Thanks!
Old 11-18-2018, 07:27 PM   #1274
gtengr
Drives: 2017 BRZ
Removed the MAF, cleaned it (didn't appear dirty), and the car runs great again. I get the feeling this isn't over though. Why would a MAF with 11k miles on it (always stock airbox and filter) be dirty? Are the oil vapors from the PCV able to travel upstream during certain throttle conditions and foul it?
I have an idle log, but it's 0.2 mb too big for datazap. Short term fuel trims were around -16% but varied. Sent the idle log to my tuner (Delicious).
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
