Old 07-07-2012, 11:21 PM   #1
djliquidsteele
Drives: Scion FR-S
Anyone seen these turn signal/drl less?
What do you guys think? Do they light up white and then when you turn your turn signal on, they blink amber?
http://www.ebay.com/itm/2013-Scion-F...#ht_4367wt_986
djliquidsteele is offline   Reply With Quote
Old 07-07-2012, 11:34 PM   #2
jskurucz
Yep!
jskurucz's Avatar
Drives: 2015 WRX Sti
You're correct. I know V-Leds has had them for quite some time.
jskurucz is offline   Reply With Quote
Old 07-08-2012, 03:34 AM   #3
ragingSPAM
Photojournalist
ragingSPAM's Avatar
Drives: Firestorm FR-S, EG8 civic
only thing is if you install the resistors you'll have to hack up your stock harness...no bueno for that...so i would look into an adapter harness or something...well it may be tough finding an adapter which fits a bulb seat unless you make one...hmmm to ponder
ragingSPAM is offline   Reply With Quote
Old 07-08-2012, 03:43 AM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
way overpriced!!
automation (a vendor here) will have these bulbs available soon for $10
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
SkAsphalt (09-29-2012)
Old 07-08-2012, 03:53 AM   #5
ragingSPAM
Photojournalist
ragingSPAM's Avatar
I'm sure you can find the same bulb type for cheaper on ebay...just look for the correct base and bulb type with dual color LED's...also look for the correct resistor
Old 07-08-2012, 08:29 AM   #6
djliquidsteele
Drives: Scion FR-S
Originally Posted by 86_ZN6 View Post
way overpriced!!
Good to know. I'll just wait until then. Thanks!
Old 07-14-2012, 08:47 PM   #7
new86driftr
Drives: 86 stock
I bought those lights after a long research
yeah, they are pricey but completely worth it. It's impossible these lights will cost $10, and they include a set of resistors, these are the brightest leds I've had, they even offset my new hids.
new86driftr is offline   Reply With Quote
Old 07-15-2012, 04:32 AM   #8
ragingSPAM
Photojournalist
ragingSPAM's Avatar
I found a thread where you don't need to hack wiring, just replace the relay under the dash http://www.ft86club.com/forums/showthread.php?t=11444
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 02:36 PM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 11:26 PM
LED exterior and turn signal conversion fenton Cosmetic Modification (Interior/Exterior/Lighting) 0 06-08-2012 12:33 AM
FR-S / FT-86 Prototype Sound Clips! Startup, On Track, Turn Signal, Seat Belt, Gazoo! Harinjo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 85 01-26-2012 11:17 AM
