Old 11-14-2018, 09:16 PM   #1359
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Originally Posted by Lococholo84 View Post
Lowered just a tad more and added some negative camber in the front.
Clean and simple...love it! What's the setup on the suspension?
Will BRZ is offline   Reply With Quote
Old 11-14-2018, 09:59 PM   #1360
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Your Car and wheels look great!
Adding one set of camber bolts will fix your poke. They are $20 and are easy to install. It takes longer to take the wheels off, than it does to install the two bolts.
Easier yet to "fix" the poke, take off the 20mm spacer.
Originally Posted by humfrz
I'm old and lazy
JeremyR (12-03-2018)
Old 11-14-2018, 11:58 PM   #1361
Leonardo
Country Boy 4 Life
Leonardo's Avatar
True, but they would work and make the wheels look really good too.
I was running a 25mm spacer when I had 18x8 +45 front wheels and a set of camber bolts. -1.4 front camber, I had even tire wear.
I LIKE TIRES!
Old 11-15-2018, 04:38 PM   #1362
Lococholo84
Drives: Celica, Frs
Thanks...On bc racing coilovers.
Instagram @machine_type
Lococholo84 is offline   Reply With Quote
Old 11-15-2018, 07:32 PM   #1363
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
Thank looks really good!
eastendraceshop is offline   Reply With Quote
The Following User Says Thank You to eastendraceshop For This Useful Post:
Lococholo84 (11-15-2018)
Old 11-15-2018, 10:15 PM   #1364
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
LoL true, I am thinking of switching the 20mm spacers to the rear and remove the 25mm one. I end up with sling all over my doors and side mirrors after applying tire shine. Its even worse when it rains and I drive through dirty water.
xenarc is offline   Reply With Quote
Old 12-01-2018, 09:30 PM   #1365
spike021
spike021's Avatar
Still practicing with my new camera and new lens. Just a couple photos from tonight's post-stormy weather 'shoot' (including super filthy car with mud caked all over ):
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following 5 Users Say Thank You to spike021 For This Useful Post:
broberg (07-30-2019), mizzta21 (04-29-2019), mrg666 (02-03-2019), tehShirt (12-02-2018), Waffle86 (12-02-2018)
Old 01-02-2019, 11:40 PM   #1366
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
https://www.ft86club.com/forums/pict...ictureid=11633
vintagemxer is offline   Reply With Quote
The Following 2 Users Say Thank You to vintagemxer For This Useful Post:
eastendraceshop (01-08-2019), yberther (01-05-2019)
Old 01-31-2019, 07:30 PM   #1367
spike021
spike021's Avatar
The Following 3 Users Say Thank You to spike021 For This Useful Post:
JeremyR (02-01-2019), mizzta21 (04-29-2019), mrg666 (02-03-2019)
Old 02-03-2019, 03:05 PM   #1368
mrg666
pessimistic skeptic
mrg666's Avatar
Excellent stance! What is your suspension?
Old 02-04-2019, 03:52 PM   #1369
spike021
spike021's Avatar
thanks! RCE Yellows and SPL RLCA's in the back. -1.6 camber up front and -1.4 in rear, IIRC.
The Following User Says Thank You to spike021 For This Useful Post:
mrg666 (02-04-2019)
Old 02-08-2019, 02:05 PM   #1370
Jonboy73
Jonboy73's Avatar
Drives: Toyota GT86 GTS
New owner from the U.K. Totally standard for now and the only planned performance mods will be a UEL header and N/A tune to remove the torque dip issue. Also the usual stereo and speaker upgrades as well as a planned lip kit install.
Jonboy73 is offline   Reply With Quote
Old 02-08-2019, 04:42 PM   #1371
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Jesse36m3 is offline   Reply With Quote
The Following 4 Users Say Thank You to Jesse36m3 For This Useful Post:
freddydo (04-04-2019), mrg666 (02-09-2019), spike021 (02-13-2019), Waffle86 (02-08-2019)
Old 04-16-2019, 12:49 PM   #1372
MX-5RACER
Drives: 1999 Miata
Need to get some better beauty shots, but these were just after installing my Feal 441+ coil overs.
Mods:
Perrin lightened crank pulley
HKS ELH
Momentum Intake
OFT customized tune
Custom 2.5" exhaust from the header back, with cat
Rota Titan 17x9 wheels w/RE-71R's
Feal 441+ Coil-overs with Swift springs
SPC lower rear arm
Atoto A6 200mm Andriod head unit (Best $250 spent on the car)
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
LIGHTNING RED BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 409 03-01-2025 11:28 AM
STERLING SILVER BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 525 08-26-2022 09:46 PM
Scion Whiteout VS Satin White Pearl R0ME0 Scion FR-S / Toyota 86 GT86 General Forum 32 04-17-2012 07:16 PM
Can someone photoshop this Satin Pearl White?? TOYSTRY FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 04-11-2012 06:51 PM
Satin White Pearl? Jehuty77 Scion FR-S / Toyota 86 GT86 General Forum 56 03-02-2012 08:35 PM
