| Member's Car Journals Car journals by our members. |
#30 |
Drives: 86 & CX-5
New Tie Rods Needed???
Having a knock sound on abrupt level changes/bumps.
![]() I "think" I need shorter end links... ![]() Raised the fronts a bit and re-did the preload on the coilovers to make sure everything was in order. Checked all bolts too. Final Result: The sound lessened but it's still there. Everything else seems fine and drives nicely. ![]() How she sits now :-) Last edited by ett808; 05-19-2018 at 03:15 PM. |
#31 |
Drives: #337 2017 Toyota 86
Extra NVH is to be expected with a spherical bearing and no rubber in the top hat. You'll hear little clunks and pick up more vibration from the road no matter what.
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
#32 |
Drives: 86 & CX-5
Meant to say end links. I have had coilovers on many cars and this noise isn't normal. Pretty sure it's just the OEM end links are too long.
#33 |
Drives: 86 & CX-5
#34 |
Drives: Series10 FRS 6MT
Nice to see other kouki 86 in Austin, I’ve only seen one other in the round rock area. Looks good man
3/18/14: '14 Firestorm Monogram FR-S 6spd-Sold
2/6/16:'13 SILVER IGNITION Series10#322 FR-S 6Spd-sold 5/12/18: ‘17 Toyota 86 6-spd |
#35 |
Drives: 86 & CX-5
Megan Strut Bar
New part arrived. The construction feels similar to most other strut bars out there. I don't anticipate any issues with it. I'll report back once installed and drive for a bit.
#36 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
#37 |
Drives: 86 & CX-5
Megan STB cont.
Post install pixs.
| The Following User Says Thank You to ett808 For This Useful Post: | StraightOuttaCanadaEh (05-31-2018) |
#38 |
Drives: 86 & CX-5
Megan Strut Bar Video
Did a little vid on the Megan Racing Strut Tower Bar.
[ame]https://www.youtube.com/watch?v=hl6vJ8pYwq0&ab_channel=ET86[/ame] |
#39 |
Drives: 86 & CX-5
Whiteline End Links and Ramps
![]() Couldn't wait for the SPL ones so picked up some Whiteline ones. I'll chime back in if it fixes my front suspension noise problem. ![]() Ramps :-) |
#40 | |
Drives: 14 brz
#41 |
Drives: 86 & CX-5
Swift Spec R Springs
![]() So I had my 2017 stock suspension laying around the garage and I thought I'd put it to use on my "simplified suspension setup". More to come later on that :-) Swift SPEC R Spring Rate: 4.4K Front / 5.3K Rear Drop: 1.1" (28mm) Front / 1.0" (22mm) Rear Last edited by ett808; 11-14-2018 at 04:58 PM. |
#42 |
friendly
Drives: 17' 86
Dude what offset are those? I never liked the hypergrams but those are fireeeee
| Kai's 2017 Toyota 86 | 86Kai | Member's Car Journals | 68 | 08-23-2018 09:08 PM |
| Toyota 86 Mud Guards on 2017 BRZ | JSube | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 05-01-2017 10:57 AM |
| 2017 Toyota 86 QUESTIONS | Clee | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 02-08-2017 02:15 PM |
| 2017 toyota 86 AT | BrokenSouls | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 10-18-2016 09:22 AM |
| 2017 Toyota 86 | Driftz | Southwest | 3 | 06-04-2016 02:52 PM |
