Old 10-03-2018, 12:36 AM   #2885
CSG Mike
CSG Mike's Avatar
Originally Posted by thriller View Post
Hi Mike,
Thanks for the response! I've uploaded an idle log here:
https://datazap.me/u/thriller/idle-2...og=0&data=7-11
It appears you have an install/vacuum issue.
This has nothing to do with your header, but you should not be running the CARB tune with an aftermarket header anyways.
Fix your install, then get a proper tune, to make it run properly. PM me to purchase a tune.
Old 10-07-2018, 11:08 AM   #2886
Colin86
Drives: 86
More of a road course guy but the drag strip is fun every now and again. First time I took my FRS out last year the track was rained out and I was only able to make one pass where I spun all the way down the track, ended up running a high 15 or something silly so I didn't post it.
Went again a week or so ago and go rained out again but had slightly better luck, was able to run a 3-4 passes. Car still has a lot left in it just because I have a lot to learn on launching the car without excessive wheel spin. Shame I wasn't able to make more passes as I'm confident I could have hit a 12 with some more practice.
Best ET
13.2 @107mph
Best Trap
13.6 @109
Car setup:
6spd FRS
Edelbrock w/ stock pulley
DW300c fuel pump and DW 700cc injectors
Delicious D box, flex fuel kit, and Edelbrock tune
Gruppe-S UEL header and over pipe (both coated)
HKS LegaMax
E85
Stock clutch
327whp 243wtq
215/45/17 MPSS on stock wheels aired down in the rear to 28psi (lol not exactly drag tires)
Colin86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Colin86 For This Useful Post:
B T (11-13-2018), gtengr (10-07-2018), shr133 (10-15-2018)
Old 10-08-2018, 09:31 PM   #2887
inonly
Drives: 2015 BRZ Limited
Somebody make a strut bar that fits! LOL
inonly is offline   Reply With Quote
Old 10-10-2018, 09:20 PM   #2888
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
More of an FYI and data point. Went to SMOG my car with the Edelbrock Kit installed, I live in CA. Car passed no problem.
The technician typed in the E.O. number, ran the visual and proceeded with emissions. Easy peasy 15 mins. In and out.
Mods are all CARB compliant (stock headers, stock engine, catback exhaust)
itsibarra is offline   Reply With Quote
The Following 3 Users Say Thank You to itsibarra For This Useful Post:
CSG Mike (10-10-2018), shiumai (11-04-2018), shr133 (10-15-2018)
Old 10-28-2018, 05:02 PM   #2889
gt86yasss
Drives: White 86
For those who have a D-Box, do you guys feel the improvement from driving? I have MotoEast remote tuned my car and sometimes I can feel some weirdness/hesitation throughout the 3k to 7k rpm range. Mike suggested me to get a Dbox, just wonder if it will really solve the problem?
gt86yasss is offline   Reply With Quote
Old 10-29-2018, 06:20 PM   #2890
Akari
Drives: 2013 DGM BRZ
I have a D-Box and don't experience any of that, although I haven't ever run without it.
Can you post up logs from when that's happening? It should be pretty easy to spot where/when that is causing you issues.
Akari is offline   Reply With Quote
Old 11-04-2018, 05:57 PM   #2891
Pho20
Drives: 2013 Subaru BRZ
I have a dbox I will sell you
Pho20 is offline   Reply With Quote
Old 11-04-2018, 09:43 PM   #2892
Colin86
Drives: 86
Same story here
Old 11-13-2018, 03:15 PM   #2893
diluzio91
Drives: '13 with go fast bits attached
Just ordered mine! Excited for the boost
diluzio91 is offline   Reply With Quote
The Following User Says Thank You to diluzio91 For This Useful Post:
CSG Mike (11-13-2018)
Old 11-13-2018, 03:48 PM   #2894
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Get a Delicious Tune, too...you won't regret it
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 11-14-2018, 01:03 AM   #2895
diluzio91
Drift office is doing mine
Sent from my SM-G965U1 using Tapatalk
paiceyfan (11-14-2018)
Old 11-14-2018, 07:04 AM   #2896
subielife
Subaru Ambassador
subielife's Avatar
Drives: 13 BRZ 18 Silverado
Mine is at my sponsors shop now, getting installed in the next few weeks. This is a track only car so I'll have some good info on how much abuse this system can take.
subielife is offline   Reply With Quote
The Following User Says Thank You to subielife For This Useful Post:
Takumi788 (12-10-2018)
Old 11-18-2018, 11:36 PM   #2897
shr133
shr133's Avatar
Drives: 2013 FRS
Best ET
13.2 @107mph
Best Trap
13.6 @109
Car setup:
6spd FRS
HKS LegaMax
E85
Stock clutch
327whp 243wtq
How bad is your wheel spin???
I'm going to be running a similar set up. I'm finishing up my E85 tune and I have full 2 1/2" exhaust w EL header.. Hope to get my supercharger in summer...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 11-21-2018, 12:57 PM   #2898
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I guess it's belt time. 23K miles and a little over 2 years. I heard a slight squeal a couple weeks ago on start up (a little cold outside) but that's it, I never heard that piece slapping the hood, could have been while the car was warming up though.
BirdTRD is offline   Reply With Quote
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
