Old 09-29-2018, 04:08 AM   #99
Apex No.525300887039
Drives: 2016 Scion FRS
front 6.1kg/13.4lb each, and rears at 4.8kg/10.6lb each
Apex No.525300887039 is offline   Reply With Quote
The Following 2 Users Say Thank You to Apex No.525300887039 For This Useful Post:
CounterSpace Garage (10-02-2018), mistople (10-03-2018)
Old 09-29-2018, 06:52 AM   #100
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Wangaroo View Post
I believe it's due to the resultant motion ration from the multi-link rear suspension. If the springs are 6k square, the rear spring rate is closer to 4.5k
Wheel rate is motion ratio^2 x spring rate. So 6k is closer to 3.4k at the rear wheel.
Old 10-05-2018, 05:39 PM   #101
Var
Drives: 2017 Subaru BRZ PP
What's the maximum recommended spring rate with these shocks?
Var is offline   Reply With Quote
Old 10-24-2018, 07:31 PM   #102
Bimble Bamble
Drives: 10 Series
5 month follow up: TRD sways, Whiteline LCAs, thats it
Install: They came sent to me at about stock height, i went to 2 fingers on all and they didnt settle too much from there.
-Street: Full soft is comfy, like a Cadillac, however too soft for me on 320 TW Hankooks, i use 8/11 as CSG recommended. Roads here are good tho.
-Track & Autox - Have not felt any ill effects of running trd sways, prob cause they are both only a tad stiffer. I run 5/7 with RE-71 and have PAX'd top 10 with only OFT stage 1 in STX. I'm amazed.
THESE COILS ARE NO JOKE!!! Save a couple thousand over others and put that money to good use elsewhere like I did!
Bimble Bamble is offline   Reply With Quote
The Following User Says Thank You to Bimble Bamble For This Useful Post:
Var (10-24-2018)
Old 10-24-2018, 08:23 PM   #103
Var
I can't wait to get mine. Have to wait for the next shipment
Old 10-25-2018, 01:38 PM   #104
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
They are here, but waiting for green light to receive and start shipping out. Thank you for your patience!
CounterSpace Garage is offline   Reply With Quote
Old 11-06-2018, 06:03 PM   #105
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
Originally Posted by snuff58 View Post
more . . . .
My target max HOT tire pressure was 32 psi and seems to be just right!
was running new but old Hoosier R6's 225/40-18, square.
Now heading back to Pitt Race this weekend w/ Chin Trackdays!
(on a side note, and unrelated, 21 Dodge Vipers are slated to show up!)
Well, now that my track season is over for the year, I'm anxious to do my own realignment for street use. Using a Longacre caster/camber gauge and a homemade c-channel bracket. Also made toe string apparatuses. pics of those next.
Sent from my XT1254 using Tapatalk
snuff58 is offline   Reply With Quote
Old 11-06-2018, 06:05 PM   #106
snuff58
snuff58's Avatar
pvc string toe alignment setup
The Following 3 Users Say Thank You to snuff58 For This Useful Post:
CounterSpace Garage (11-08-2018), dsc_pat (02-10-2022), strat61caster (11-06-2018)
Old 11-09-2018, 01:08 PM   #107
Doji Style
Drives: 2014 SWP BRZ
Mine arrived yesterday, I was planning on installing them over the weekend but I'm not sure I can wait. Might have some pics up tonight.
2014 SWP Subaru BRZ
2014 VW GTI
2013 Asphalt FR-S - Sold
Doji Style is offline   Reply With Quote
Old 11-10-2018, 11:12 PM   #108
Var
I was on a work trip to Portland and they came in a day before I got back (yesterday). I was excited to get home and install them.
They went in as expected. Took about 2.5 hours on floor jacks and taking breaks often.
I've only had a chance to drive it on one setting. 5 front and 8 rear from full stiff. In a straight line, 5 up front seems to control the spring really well. 8 in the rear doesn't. It feels a little bouncy. In corners, for some reason when the rear is loaded up everything feels better/smoother.
I left the ride height as it was shipped to me for the initial installation. And I've only driven about 10 miles, but it looks like it's sitting higher than the RCE yellows and Sachs combo I just replaced. I'll want to lower it at minimum 1/2 inch from where it is now, unless it settles/drops significantly over the next tank of gas.
I'm excited to drive this thing around tomorrow and try different shock settings.
Wheels/tires/alignment coming in the next week
Old 11-11-2018, 11:04 AM   #109
Doji Style
Originally Posted by mistople View Post
Does anyone have individual or total weights for this set?
I didn't get to weigh them before I installed mine, and I want to compare them to the stock PP dampers.
I regret not weighing mine either, pretty sure they’re heavier.
I have an alignment scheduled for tomorrow morning, are there suggested starting specs from CSG somewhere? I searched and found references to such specs but was unable to find the posts themselves.
2014 SWP Subaru BRZ
2014 VW GTI
Old 11-11-2018, 01:44 PM   #110
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Totally depends on your usage. What do you use your car for? Street/DD only? Heavy track use?
mistople is offline   Reply With Quote
Old 11-11-2018, 09:04 PM   #111
Var
Today I tried out 12F/15R. Really comfortable for cruising around.
I also tried 5F/6R. Amazing body control
What's weird, and totally subjective, is that I like the ride quality better on super soft or stiff. I don't like how the car rides in the middle of the shock range. This is completely independent of performance as I don't have much testing to base that off of.
So far I'm really liking these shocks and I wish I would have done this mod sooner
Old 11-12-2018, 07:08 AM   #112
Doji Style
Mostly track use, I’ve put 3000 miles on the car in a year.
2014 SWP Subaru BRZ
2014 VW GTI
WTB Tein Flex Z HachiRo Want-To-Buy Requests 1 09-19-2016 01:13 PM
tein flex z mclovin85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-14-2016 06:27 PM
TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day CounterSpace Garage Groupbuys 47 02-18-2016 12:33 AM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
