Old 11-10-2018, 11:24 AM   #1233
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
I left mine open. They don't connect to anything. But if you want to close them, you can buy some silicon blanking caps. Now that I think about it, I might do the same. It would give it a more "finished" look.
https://www.ebay.com/sch/i.html?_fro...1%2F4&_sacat=0
sly is offline   Reply With Quote
Old 11-10-2018, 12:05 PM   #1234
gahooligan
Drives: 2017 BRZ Premium
Sly, he is Talking about the pipes on the engine that actually flow coolant. If you wanted to cap them you would definitely need silicone caps. I tried rubber caps From the part store and they failed within a few weeks with a split that leaked coolant and made a mess. I would definitely recommend connecting the 2 with a hose. One of the original hoses that comes off the engine will actually work.
Sent from my SM-N960U using Tapatalk
gahooligan is offline   Reply With Quote
Old 11-10-2018, 12:09 PM   #1235
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by gtengr View Post
Hello folks, I started installing the supercharger yesterday and am nearly finished. I was wondering if you all capped those throttle body coolant pipes remaining on the engine or connected them with a hose? I'm having trouble sourcing silicon plug caps and think connecting them with a hose would be better than a cheap rubber vacuum cap from the parts store. I'm referring to the coolant stubs that feed the throttle body, not the stubs on the throttle body.
You could always use them to your advantage and install the Oem oil cooler too
MS, CSCS, TSAC-F, CPT
Old 11-10-2018, 12:13 PM   #1236
sly
sly's Avatar
Oh. My kit came with the blanking caps for the coolant lines. Maybe some kits didn't come with them. Be sure to use a hose clamp on them then because they will be under pressure.
Old 11-10-2018, 03:18 PM   #1237
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
there should be a couple of caps and clips in the kit and they are silicone rubber
Matt@Cosworth is offline   Reply With Quote
Old 11-10-2018, 04:00 PM   #1238
gahooligan
He has my used kit I believe, so he doesnt have the original caps.
Old 11-10-2018, 05:15 PM   #1239
gtengr
Drives: 2017 BRZ
Too late now
Correct. I have gahooligan's kit. Wasn't too comfortable with plugging them so I just connected the stubs with a hose to avoid having that coolant system pressure against a cap fitting.
Thanks for the responses. Bleeding the cores now!
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
weederr33 (11-10-2018)
Old 11-10-2018, 08:55 PM   #1240
gtengr
Drives: 2017 BRZ
All done. Still need to do the tune revision process with Delicious but the install feels solid and the power feels great already.
mrg666 (11-11-2018)
Old 11-11-2018, 07:45 AM   #1241
mrg666
pessimistic skeptic
mrg666's Avatar
There is no evidence without pictures!
I would do the same. Actually, just connect an OEM oil cooler there. It is a 15 minute job. And it really helps with cooling (not for track though) and initial warming up.
Old 11-11-2018, 02:10 PM   #1242
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Hi all,
Matt @ cosworth helped me a lot on the tune. However, I am on the 6th tune now and still have knocking at 5000rpm. I kind of give up because it cost me a lot for the shop flash and test again and again.
Matt noted that mt vehicle (2018 brz ts) may have a more restrictive exhaust and canadian 94oct fuel may not as good so knocking still exist.
I need suggestions from you guys, shall I ditch the cosworth supercharger and call it a day. Or shall I take the risk to buy full exhaust (header and catback)?
If go for header and exhaust, any recommendations? I want a reliable set up and prefer equal length catted header/exhaust.
Thanks!
botbs is offline   Reply With Quote
Old 11-11-2018, 02:46 PM   #1243
mrg666
pessimistic skeptic
mrg666's Avatar
Knocking at 5000 is terrible since this engine starts to shine after 5000. I have never heard such a problem without high-boost pulley. I would consult with CSG and Delicious.
Originally Posted by botbs View Post
Hi all,
Thanks!
Old 11-11-2018, 03:24 PM   #1244
Teseo
Drives: frs
Hi all,
Thanks!
Dont go "all-out" and try to be in safe zone
Old 11-11-2018, 04:55 PM   #1245
botbs
botbs's Avatar
What do you mean by don't go "all-out" and try to be in safe zone? Would you please elaborate more, thanks!
Old 11-11-2018, 06:06 PM   #1246
Teseo
Drives: frs
If its knocks at certain rpms, pull back the ignition a little
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
