Old 08-15-2018, 12:30 AM   #1205
fl4t ftw
Drives: 2013 DGM BRZ, 2016 FiST
Checking in. Just changed out my ptuning EL header for a Tomei UEL. Much rumble, but I can feel a little loss up top. I’ll take it. Gt3076r V1 kit. 10:1 compression.
fl4t ftw is offline   Reply With Quote
Old 08-15-2018, 01:11 PM   #1206
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
You tuned by PTuning? If so, their tuner tunes the PTuning EL header a bit differently than other header setups. The rumble must sound nice though for sure.
rb6freak is offline   Reply With Quote
Old 08-17-2018, 01:18 PM   #1207
fl4t ftw
It was tuned by Precision Tuning before I bought the car.
Old 09-26-2018, 05:37 PM   #1208
Joveen
Joveen's Avatar
Drives: Bone stock
Who has 3" catback running with this kit? Did you guys have to fabricate?
Sent from my SM-G935T using Tapatalk
Joveen is offline   Reply With Quote
Old 09-29-2018, 08:39 PM   #1209
woojukim116
Drives: SCION FRS 2014
No, I just bought 3" perrin cat back exhaust, and it bolts on I think. There is Ptuning cat back exhaust which may not be in production now, and I couldn't find a used one. You may be able to find one if you get lucky, and I think it is better suited to the kit.
Modified pipes came with the kit which was 3" turbo --- cat back.
woojukim116 is offline   Reply With Quote
The Following User Says Thank You to woojukim116 For This Useful Post:
Joveen (09-30-2018)
Old 10-01-2018, 04:40 PM   #1210
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Mac White, who is also in the Midatlantic area has been trying to sell the Ptuning exhaust for about the past 2 months for DIRT cheap. You definitely just weren't looking the right places.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 10-26-2018, 02:27 PM   #1211
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
50,000 miles on my turbo kit and still going strong. Any other PTuning owners out there still going good?
The Following 3 Users Say Thank You to rb6freak For This Useful Post:
CSG Mike (10-26-2018), Joveen (10-26-2018), Mrc@ptuning (10-29-2018)
Old 11-09-2018, 04:40 PM   #1212
tS Violet
tS Violet's Avatar
Drives: '18 BRZ tS - White
Should I reach out to PTunning directly about fitment questions? I have a '18 BRZ tS and I am not sure if there is any clearance issues with the "v-bars". Also, debating heavily between the Greddy 518z and this kit. Can anybody way in? Cheers!
tS Violet is offline   Reply With Quote
Old 11-10-2018, 10:35 AM   #1213
J1Avs
Drives: 2018 BRZ tS
The PTuning Kit is a hell of a kit, and I would have gone that route on my tS if I wasn’t so dead set on going with the JRSC. It’s defintiely pricier, especially with all the add-on’s that are recommended, but every kit I’ve seen in person talked with the owners can’t say enough positive things about it. PTuning is my local shop I use, and I can’t say enough positive things about my experience also. It also definitely looks the best from a purely visual standpoint.
...maybe one day when I have another giant need to waste, I’ll swap over to the PTuning Kit
J1Avs is offline   Reply With Quote
Old 11-10-2018, 12:36 PM   #1214
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
If you're a potential customer, yes you should call them. The PTuning V2 kit clears the firewall strut-tower bars (Are these the V bars?) due to redesign of intake to the new the cobra snake looking one. Good luck with your selection, my vote was PTuning 4 years ago and would be again today.
The Following User Says Thank You to rb6freak For This Useful Post:
Mrc@ptuning (11-12-2018)
Old 11-12-2018, 09:37 AM   #1215
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Thanks Mike!
The V-bar (strut tie-bar) on the tS should not be an issue due to the Cobra intake on our revised V2 turbo kit. The only fitment issue we see is the Flexible Draw Stiffener bars that are mounted to the bottom front cross member of the tS. The draw bar on the passenger side of the car will have to be removed in order to run our kit since the bar interferes with our low mounted gt turbo. We don't feel that removing those bars to install the turbo kit will make any noticeable difference in handling but that's your call.
Mrc@ptuning is offline   Reply With Quote
Old 11-12-2018, 05:03 PM   #1216
tS Violet
tS Violet's Avatar
Originally Posted by Mrc@ptuning View Post
Thanks Mike!
Thanks for the information! I will be in touch with some additional questions sooner than later. The purchase would not be until late spring of '19. I also need to find a local resource for tuning.
The Following User Says Thank You to tS Violet For This Useful Post:
Old 11-13-2018, 05:43 PM   #1217
Myuri
Drives: 2016 BRZ
Thanks Mike!
Yo, Im looking into buying a ptuning kt in the distant future still doing lots of research at the moment as i am new to the scene here and to turbos in general with the kit about how much am I looking at to spend in supporting mods? That can include new pistons and con rods etc thank you sorry for the noob question
Btw S1000RR is probably my favorite bike
Myuri is offline   Reply With Quote
Old 11-13-2018, 05:44 PM   #1218
fl4t ftw
Research my friend! You don’t need a built motor for <300whp, generally speaking.
The Following User Says Thank You to fl4t ftw For This Useful Post:
Joveen (11-13-2018)
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2638 03-11-2026 07:19 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
