Old 11-08-2018, 05:52 PM   #20035
Originally Posted by milanojess View Post
Thanks for asking,
no codes
re fuel, the two times happened with different tank of gas and i never fill with non first tier gas. I did have some 100+ oct gas recently from Laguna seca and the last tank was mixture of half 91 half 101. Indeed, the first times that it happened, i believe, was the 2nd morning of track event, which would have been 100% 100 oct ( 100oct is called for JRSC'ed car at track ) So good point. Now that it's back to full 91, i shall keep an eye to see if that happens again.
Thanks
Once you've changed the tune, don't bother comparing experience with us stock plebes. Check with the JR owners' thread.
milanojess (11-09-2018)
Old 11-08-2018, 06:31 PM   #20036
Dadillac
Drives: 2018 Ford Mustang EB Premium 6M
Installed the under trunk lid carpet. The lid looks so 1970's without it. The install took about 1 minute after getting the clips out of their individual bags. A before and after pic.
Don
Modern warriors saddle iron horses of chrome
Dadillac is offline   Reply With Quote
The Following 3 Users Say Thank You to Dadillac For This Useful Post:
Busybee (12-17-2018), humfrz (11-08-2018), Myriad (11-29-2018)
Old 11-08-2018, 06:31 PM   #20037
Dadillac
Not sure why they are turned 90 degrees. They are correct orientation on my computer. Sorry
Don
The Following User Says Thank You to Dadillac For This Useful Post:
Ultramaroon (11-08-2018)
Old 11-08-2018, 07:54 PM   #20038
Flint8821
Drives: 2013 Scion FRS
New windshield looks good. No issues with Spider Glass. Took 2 hours. They say first chip repair is on them, if I need one. $280 out the door. Nice!
That's awesome. I'm glad that there were no issues.
I'm actually a bit hesitant on having it fixed. Any tips for us, like what to watch out for when they are doing the replacement? I looked at a bunch of reviews of other shops here in Chicago, and quite a few people complained that their roof area close to the windshield and dash got totally scratched when the techs were removing the windshield.
Flint8821 is offline   Reply With Quote
The Following User Says Thank You to Flint8821 For This Useful Post:
Old 11-08-2018, 10:12 PM   #20039
Don
Meh. Hardly a deal breaker.
Old 11-09-2018, 05:51 AM   #20040
Hypnocracy
Hypnocratic Missionary
Hypnocracy's Avatar
Went to the Autozone to buy something to remove hard water spots or wax steaks from my windshield...they didn't have the RainX goo remover or 0000 steel wool I was after...they did have two 9011 Bulbs...
The streaking on the windshield is madding...in the morning after the dew has been hit with the wiper blades...the remaining moisture has to air dry...no amount of wiping removes it and in the dark of early morning an oncoming car or street light illuminates the moisture where it is as opaque as frost until the light source moves past...so...checking the internet for ways to clean my windshield.
1. White Vinegar. My wife keeps a gallon to add to the wash or use as a natural cleaner. Soaked a hand towel and started rubbing...cleaned with water and still see the same pattern. No improvement
2. Dawn Dish soap. Rinsed the hand towel...liberal amount of liquid soap...rub in circles...horizontal strokes...vertical strokes...rinse....ugh...
3. Really frustrated at this point...so I go with the brillo pad...Wet the glass and start to do circles...this feels promising...as I work to new areas the pad grabs on the first stroke and the following stroke feels easier...once the entire area has been worked I rinse and dry...pattern is still there but maybe...just maybe faded.
Cleaned windshield wiper blades
I give up. Waiting til my next early morning dew-commute to see if it has improved...on to the high beam bulb modification.
Last week I modified the low beams using a H11 bulb...It is noticeably better...at the time there was only one 9011 bulb for the high beam mod...so I put it off til I found two...different Autozone and $50 later I pull out a hack saw blade and needle nose pliers...compare existing bulb to new one and see I have to remove a heavy 1/8 of top tab. Make cut with hack saw (holding blade in my hand) and break away the waste with needle nose pliers. They install without issue.
Night comes...grab a 32oz cup of water...splash on the FR-S windshield...hit the windshield wipers and pray...promising results blades seem to cut the moisture...I'll have to wait til the morning dew point is close to the actual temperature to see if there is improvement.
Head to the country two lanes to get away from street lights...hit the high beams...I'm pleased with the improvement of the bulb swap-mod compared to stock...Easy no pulling off the front clip to remove headlight buckets and putting them in the oven etc. etc.
Hypnocracy is offline   Reply With Quote
The Following User Says Thank You to Hypnocracy For This Useful Post:
humfrz (11-09-2018)
Old 11-09-2018, 10:08 AM   #20041
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I can't see any scratches or anything. The shop also does detailing and ceramic coating etc., so they are probably more sensitive to that kind of thing I would think. I just sat on their couch, no customers in work area. I would make sure that the car is clean.
Flint8821 (11-09-2018)
Old 11-09-2018, 12:10 PM   #20042
I've found that Invisible Glass usually does a good job.
For heavy hard water spots, I have used 16N hydrochloric acid.
(I don't recommend that stuff for the non-chemist)
Hypnocracy (11-10-2018)
Old 11-09-2018, 12:31 PM   #20043
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Do what the junkman does. I love this guy.
[ame]https://www.youtube.com/watch?v=MOIu2cNNPH4[/ame]
Ultramaroon (11-09-2018)
Old 11-09-2018, 01:18 PM   #20044
Nothing about water spots.
Old 11-09-2018, 01:26 PM   #20045
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Elbow grease.
Old 11-09-2018, 01:34 PM   #20046
Elbow grease.
Spots are looking nicer.
Old 11-09-2018, 02:15 PM   #20047
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Accents the swirls.
Old 11-09-2018, 02:35 PM   #20048
milanojess
milanojess's Avatar
Drives: 2013 FRS
Originally Posted by johan View Post
turn the key to ON, wait 3 seconds to allow the fuel pump to fully prime, then turn the key to fire the starter.
Thanks for the suggestion, will try it it happens again.
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
