Old 10-28-2018, 09:59 PM   #1
Var
Drives: 2017 Subaru BRZ PP
Performance Pack rotor options
My factory pads are just about done. I haven't measured rotor thickness yet. Not sure if it's a good idea to reuse them or not.
Original hardware has one track day, and many, many miles in the canyons.
How often do you all change rotors?
What are good rotor options for cheap? I don't mind swapping for new rotors every time if they are cheap. I saw some Centric fronts for around $32 each.
Anything I should stay away from?
Any recommendations?
Thanks
Var is offline   Reply With Quote
Old 10-28-2018, 10:26 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
May depend on how agressive pads are to rotors. But usually rotors outlast pads. I'm through 3rd pad set (on non PP, OE brakes), and it looks, like my rotors will get through 4th, for example. Just check thickness of rotors and decide when/if it's time to change, but i somewhat doubt that only first pad set will wear them down enough.
Var (10-28-2018)
Old 10-28-2018, 11:04 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Depends on the pad, but I'll say you'll be fine with just new pads. For peace of mind get them measured. Replace if worn.
Old 10-29-2018, 12:50 PM   #4
wparsons
wparsons's Avatar
Don't just measure, also look for heatchecking as well. Chances are you're fine with OEM pads, but my current rotors will be replaced in the spring after two years.
flickr
Old 11-02-2018, 12:13 AM   #5
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Thanks
Some thoughts to consider:
- Rotor thickness
- Warpage
- Lip formation
- OEM discs actually last a long time
- Crappy metallurgy = crappy wear
- Ultra super ballin' discs also don't necessary mean excellent performance
- Brake pads make or brake your actual braking performance
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
wparsons (11-02-2018)
Old 11-02-2018, 11:51 PM   #6
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Thanks
I don’t think centric rotors would fit the Brembo calipers?
N1rve
Old 11-03-2018, 04:43 PM   #7
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
As long as the rotor is the same size it doesn't matter at all.
Also are you making a statement or asking a question?
Old 11-03-2018, 09:05 PM   #8
N1rve
N1rve's Avatar
Both?
N1rve
Old 11-08-2018, 03:43 PM   #9
Var
Turns out I don't need them but just for reference
Coil pack options ROADRACER Engine, Exhaust, Transmission 14 12-24-2018 02:33 AM
to performance pack or not Victorscp Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-19-2018 03:53 AM
Lightweight REAR rotor options himbo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 10-15-2018 04:59 PM
2017 OEM rims(non-performance pack) apatel471 Cosmetic Modification (Interior/Exterior/Lighting) 0 08-31-2018 09:30 AM
GT-86 optional performance-pack Ziptuning Scion FR-S / Toyota 86 GT86 General Forum 24 08-29-2012 03:00 AM
