Old 10-29-2018, 01:53 PM   #43
driggity
Drives: Silver Coupe with a Boxer
I'm sure the hbs helps but I'm not sure if there's anything reasonably priced with more bump travel than these SS1s at a 1 inch drop. A big part of that is the front lowering camber plate, but also KW have a good amount of travel.
What about in the rear of the car? I may be wrong but it feels like the stock suspension runs out of travel when accelerating out of bumpy corners on the backroads around here. That and better control in transitions are really my biggest complaints about the stock suspension for back road driving.
driggity is offline   Reply With Quote
Old 10-30-2018, 09:38 AM   #44
Originally Posted by 2Wavy View Post
For what applications would you recommend the RCE T2s and what applications would you recommend the SS1? I have a daily driver that I autocross 10 times or so a year and plan on tracking soon, which one would be better for me?
For more serious tracking, the T2s are better. If you run r comps and are comfortable tuning a 2 way damper (or learning a little bit), they'd be the way to go for you. Just a little more potential.
The SS1 will ride slightly better out of the box and still perform really well, even with r-comps. The ceiling is just a little lower in comparison to the T2s.
- Andrew
Old 10-30-2018, 09:40 AM   #45
Still plenty of travel (bump and droop) in the back. For context, we recommend against using some of the 2 inch drop rear top mounts with our RCE coilovers because you have enough bump travel without them, and you won't have enough droop if you use them. It's a lot of usable front and rear travel.
- Andrew
driggity (10-30-2018)
Old 10-30-2018, 03:34 PM   #46
lc300
Drives: 2014 BRZ Sport Tech
These are zinc coated stainless steel, does that mean they’re closer to the ST coilover instead of the inox steel from the KWV1’s?
I’m worried about corrosion affecting these coilovers in the long run.
lc300 is offline   Reply With Quote
Old 10-31-2018, 10:30 AM   #47
They don't have the inox stainless finish that the KWs or our RCE T2s have, and are more similar to a conventional coilover. I don't expect major corrosion issues and will be running them on my own car over the winter. That said, I will definitely take some time to clean them off when I can.
- Andrew
Old 10-31-2018, 01:13 PM   #48
2Wavy
Drives: 2016 BRZ
Kind of a more general question, since your products are made by KW, which products are tested with their 7 post rig? Are the T1, T2, T3, and SS1 all tested this way?
2Wavy is offline   Reply With Quote
The Following User Says Thank You to 2Wavy For This Useful Post:
Tristor (10-31-2018)
Old 10-31-2018, 04:34 PM   #49
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Any estimate on the camber adjustment range the plates allow?
tyler_win_photo is offline   Reply With Quote
Old 11-01-2018, 11:03 AM   #50
The 7 post rig was extremely helpful in development for this platform overall. We learned a lot early on with KW when we were developing our T2s...those lessons, along with everything else we have done since then, have informed the development of every one of our parts. So while the SS1s did not see the shake rig, there's a direct line between the T2s and the SS1s (and the T3s). We weren't starting from scratch each time. Something that's great when you start with a 2 way (T2s) is you can tune them and say "if we ever develop a 1 way coilover, it would be great if the compression felt just like this and we let the user tune rebound in this way".
More recently, Myles seeing how KPAX uses a shake rig with their Bentley GT3 cars has just been pretty cool.
- Andrew
Old 11-01-2018, 11:06 AM   #51
With the slotted lower mounts and camber plates, you can get a lot of camber. Well over -3 at least.
I'm getting my alignment tomorrow.
Speaking of which, if anyone wants to go for a ride starting next week, let me know!
- Andrew
venturaII (01-18-2019)
Old 11-01-2018, 11:10 AM   #52
Also, FYI...the camber plates are nice and quiet.
- Andrew
Old 11-01-2018, 11:52 AM   #53
Chuckls
Moutain Runner
- Andrew
Cant wait to get mine.
Waiting for the WRX to sell before diving in :/
-086/500 tS
Chuckls is offline   Reply With Quote
The Following User Says Thank You to Chuckls For This Useful Post:
Racecomp Engineering (11-01-2018)
Old 11-05-2018, 12:23 PM   #54
FYI you can get -2.2 camber up front if you get a set of the OEM camber bolts without even touching the camber plate. We can supply the bolts if needed.
- Andrew
Old 11-05-2018, 12:39 PM   #55
Boosted
Boosted's Avatar
Drives: 13 brz, 06 STI
I have had these on for about 2 weeks and thoroughly enjoy them. They are much more streetable then my 4 year old buddy club racing coilovers. There is a lot more adjust ability and you can tell the valving/spring combination are thoroughly matched (better then stock ride quality). I am running about 6 clicks in the front and 3 in the rear from full soft. This makes commuting great while still allowing for good road feel/feedback. I get a alignment Friday and then will dial in more of a backroads setting for a better start point when I track it next year. I waited on the alignment since I didnt change the ride height much from the previous setup and made sure to mark all chamber bolts to ensure they were installed back the same. The spring perch collars are super easy to adjust and love the locking allen bolt concept over dual locking collars.
Pictures wouldnt upload, so I will edit them later at home.
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car)
1988 CRX si- b16A1 (Sold)
RIP 2003 WRX
Boosted is offline   Reply With Quote
The Following 2 Users Say Thank You to Boosted For This Useful Post:
QueenBRZ (11-05-2018), Racecomp Engineering (11-05-2018)
Old 11-05-2018, 01:03 PM   #56
wparsons
wparsons's Avatar
- Andrew
And if you run the SPC lobed bolts in the lower hole with the lower bolts in the upper hole, you'll be closer to -4* without touching the camber plates! I maxed out at -3.8* on my V3's with that bolt combination.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Racecomp Engineering (11-05-2018), strat61caster (11-10-2018)
SuperStreet ToyoTires Meals N' Wheels Meet at Edgie's in Milpitas - photos & videos PMok Northern California 5 02-09-2015 05:26 AM
-0.5 for RaceComp Engineering wrxneffect User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-04-2014 04:21 PM
Mackin FR-S Superstreet Cover Evasive Tuned! Out Now!!! Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 18 12-07-2013 10:20 PM
Racecomp Engineering industrial User/Vendor/Sponsor Reviews, Feedback, Comments 0 05-02-2013 04:17 PM
Racecomp website down? Mikepage Off-Topic Lounge [WARNING: NO POLITICS] 8 04-22-2013 03:12 PM
