| View Poll Results: Which gas is better? | |||
| Shell |
50 | 44.64% |
| Chevron with Techron |
27 | 24.11% |
| Mobil/Exxon |
5 | 4.46% |
| BP |
5 | 4.46% |
| other. please state. |
25 | 22.32% |
| Voters: 112. You may not vote on this poll | |||
Drives: toyota 86
Now before you say "not this thread again", yes, i understand, im sure this has been posted many times, but since our car has been out for 6 years now, it would be a good time to make a thread about which gas is better, since more people have experimented over the years..
That being said, for the people who live in the USA (not sure about canadian gas), which gas brand works better in our cars, in terms of better gas mileage, less knocking, smoother idles, and better performance. And yes, i know, it's all the same gas, but im talking about which gas has the best additives... I added a poll |
#2 |
Brand has little to with it and fuel is not consistent from region to region anyway. Just get the newest fuel you can find no matter what brand and all is good.
#3 |
Drives: 2005 Toyota Camry
you should read the list.
https://toptiergas.com/licensed-brands/ "Top Tier Gas" only means it has to meet a level of additives. Branding doesn't matter on the retail level. |
#4 |
Famous Potatoes
Drives: '15 ultramarine
Here, all gas comes from the same refinery, and none of the brands add enough of anything to matter. For example, years ago Porsche did a study of fuel additives. They determined that the Chevron Techron was the best and actually worked, however, Chevron doesn't put enough of it in the fuel to do anything. If you want the cleaning of Techron you have to buy bottles of it (yes, they do sell it, and it is expensive) and add it.
Again, it is all the same. Buy the cheapest at the station that has turnover. And "Top Tier" is a marketing gimmick. |
#5 |
Sunoco 93 since day 1
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#6 |
Drives: 2013 DGM BRZ
I usually just go for high-volume stations that are affordable.
Been running mostly Costco 92 (They do so much volume that they refill their tanks twice a day), have had 0 issues and my FI tuner was able to get a few more degrees of timing than normal. If you experience any performance issues, knocking, or unsmooth idle, especially NA, then there's a pretty major problem with the fuel you're getting. |
#7 |
The Dictater
Drives: '13 Red Scion FRS
#8 |
Drives: 2013 FRS
All said and true, most first tier brands have consistent quality fuel, while no name brands often suffer with less performance, check engine when pushed, etc. ive seen these behavior with Costco, Valero, and other no name gas disguised as shell. The last one apparently took over an old shell station and pumped unknown gas. I was puzzled why I wasn’t able to reach expected speed until I returned to gas station next day in day light... went to gas up at nearby major gas and had no problem getting to top gear before turn 8 on willow springs.
2013 FRS - JRSC CARB
"Use all of the track" they say |
#9 |
Drives: 2016 BRZ Limited, Stock
My tuner told me to go with Chevron, so I do.
#10 |
Just the tip
Drives: 2017 DGM BRZ
The manual says 93, or 91 if that's all that is available so I go by highest octane available from stations with high fuel turnover.
So... Chevron 94 for me (ethanol free). |
#11 |
6/22/12-2/6/24
For my engine, I've felt Chevron being the smoothest.
But I don't fill them because they're so pricey. I fill Shell (2nd best for my engine) because of their fuel rewards program giving me $0.05 off each fill and the occasional extra $0.25 from T-Mobile Tuesday. I've saved $100.16 ever since I've started ... 2 or 3 years ago?.
#12 |
Drives: 2015 FR-S
Since the last cricket fix I had done a couple years ago I've only ever ran Chevron 93 and the chirp has stayed gone so I'm sticking with that.
#13 |
Drives: 2013 FR-S Series 10
These are mass produced engines that aren't really anything special... any decent gas station where the gas doesn't sit for months should be fine.
#14 |
Drives: frs
| AAA: Top Tier Fuel Study | tekFRS234 | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 07-14-2016 07:52 PM |
| CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) | edwinisdumb15 | Southern California | 2 | 07-03-2016 02:50 AM |
| CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) | edwinisdumb15 | Southern California | 0 | 06-26-2016 11:57 AM |
| Costco Gas now Top Tier | N1rve | Off-Topic Lounge [WARNING: NO POLITICS] | 22 | 04-15-2014 06:19 PM |
| Companies supplying top-tier gasoline in the USA and Canada | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 10-11-2012 04:40 PM |
