Old 11-02-2018, 12:00 PM   #1
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
Value spring recall and TOB clutch issue
I took my Frs to the dealer for the TOB clutch TSB and was told my extended warranty will not cover the premature wear on my clutch and have to shell out 1k to replace my clutch. Since the recall requires the engine to be lifted do you guys think the dealer will cut me some slack n the clutch labor? I think that Toyota dropped the ball on this clutch issue.
speedy racer is offline   Reply With Quote
Old 11-02-2018, 02:10 PM   #2
Hazzard
I had the TOB chirping issue come up right before the extended warranty ran out. I talked to the dealer, they were able to recreate the issue and said that the TOB replacement would be covered under warranty. They did offer to replace the clutch since they would have it apart and it would "save on labor", but they still wanted $1k for the clutch, pressure plate and resurfacing the flywheel. It sounds like they are cutting you some slack on labor, but it can't hurt to ask.
My clutch hasn't been slipping, so I decided to hold off on the replacement.
Hazzard is offline   Reply With Quote
Old 11-02-2018, 02:14 PM   #3
If still in the warranty time period the TOB replacement is covered under warranty. The clutch is not covered under the TOB TSB only the bearing itself.
Talk to them if it will save some costs. We can't guess what they will do.
Old 11-02-2018, 02:16 PM   #4
Do not wait to long! I did and the bearing blew and took the whole clutch system with it. My clutch never did slip it just went from squeal to bang.
Bonburner (11-02-2018)
Old 11-02-2018, 02:45 PM   #5
speedy racer
Yea, I took my FRS to the dealer 2 months ago when I noticed the clutch grinding when I engaged the clutch. I told them that I saw a TSB on the TOB but they cannot do anything till I can replicate the issue. So I kept driving it till it got worst and I complained to Toyota about it. Maybe If they would have fixed the TOB then I would not have to replace the whole clutch assembly.
Old 11-05-2018, 01:25 PM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
TSB on the TOB is also limited to under 35k miles and under 3 years if I recall correctly, which sucks, but that's what the fine print says.
EndlessAzure is offline   Reply With Quote
Old 12-03-2018, 09:26 PM   #7
86league
Drives: '13 BRZ Limited
Subaru told me today that the TOB is not covered under the powertrain warranty (I'm at 35k, but > 3 years). Called Subaru of America to see what they would do since this is a known issue with a TSB, etc... Case being investigated.
Get this : Dealer quoted me $2500 for the clutch job. Wanted me to authorize $750 for teardown now to get started. They apparently gave Subaru of America the $2500 quote as the work that needed to be done when they were contacted about my case to verify the problem. I don't feel they are helping me out any there...
From what I can tell - list price on everything would be about 780 (Flywheel, pressure plate, disk, TOB, clutch fork, pivot, 8 flywheel bolts, 6 pressure plate bolts, clutch fork spring, 2 TOB retainer clips) - How do they get $1700 in labor? #@&*!)$
Get all the parts from an online source and resurface the flywheel and it's closer to $400. Probably a little less if I get an exedy vs Subaru. Kind of doubt I need a clutch fork, but it's $20...
Called 2 local shops and they want about $800 in labor.
Happy Holidays!
86league is offline   Reply With Quote
Old 12-03-2018, 09:32 PM   #8
Happy Holidays!
It says right in the TSB that it is covered under the basic warranty not the drive train one.
If just the TOB is bad they do not need to replace anything else. If it blew and took out the clutch than $2500 is still way high. I don't remember what I paid for the whole works but it wasn't that much.
Old 12-03-2018, 09:33 PM   #9
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Happy Holidays!
The powertrain warranty is 5yr/60k... “bumper to bumper” is 3yr/36k. $2,500 for a clutch job is insanely high for a BRZ.
NCtoBRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to NCtoBRZ For This Useful Post:
Mr.ac (12-04-2018), Rampage (12-03-2018), strat61caster (12-03-2018)
Old 12-03-2018, 11:02 PM   #10
86league
I understand - just thought I'd confirm what EndlessAzure posted directly above mine, should have worded better.
I thought I'd just try as this is a known issue with a defective part and I've seen a couple of people who had luck getting it covered under the powertrain warranty. Kind of feel like it should be covered - 35,000 miles for a TOB failure is way too early - had several other cars go > 70,000 before trading them with the original clutch and TOB working fine.
Odd that the Subaru Clutch disk is $170 retail, while the Totyota is ~90. TOB is similarly cheaper $21 vs $55. Rest of the Subaru parts seem to be cheaper than the Toyota ones.
The Following User Says Thank You to 86league For This Useful Post:
Tcoat (12-04-2018)
Old 12-04-2018, 12:38 AM   #11
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Holy shit, that is price rape.
I did the tob with a bad back, on the floor with basic tools, and a beer in one hand. I did have a friend help pull it out and put it in but that was due to my limited back strength.
If I had a lift and air tools/stands I bet I can do that in an hour.
Sounds like your best bet is to take it to some local auto mechanic. At best maybe $600ish with parts included
The Following User Says Thank You to Mr.ac For This Useful Post:
funwheeldrive (12-05-2018)
Old 12-04-2018, 09:48 AM   #12
gravitylover
Good luck with that. When I needed to do mine last summer the best price I could come up with anywhere in the extended NY Metro area (hundreds of good shops) was ~$1200.
Old 12-04-2018, 10:03 AM   #13
cjd
cjd's Avatar
Drives: 2017 BRZ
That's your angle then, of they refused to repair because they couldn't replicate till 2mo later and xyz miles, to can makea case that it contributed to the clutch issues you now face. May not help, but be nice about it, and be consistent and reasonable in what you're asking for.
Old 12-06-2018, 09:43 PM   #14
86league
I
Just to follow up in case anyone is interested.
Subaru of America offered $600 toward the TOB replacement. Trouble is all of the dealers around here quoted around $1200 for the job (SoA had this quote). I didn't have a good feeling that they wouldn't find a clutch that needed replacement, then I'm paying list (or over) for parts and $165/hr for labor. AllData shows 6.5 for the TOB job, +0.4 for clutch disk and flywheel. A lot different than the #s shown in the TSB.
Going to do it myself.
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
VALVE SPRING WORLD - PRESS RECALL Trap63 Issues | Warranty | Recalls / TSB 85 03-12-2019 11:38 PM
Worldwide Power Steering Issue Safety Recall nzer Issues | Warranty | Recalls / TSB 27 08-08-2016 06:14 AM
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 03:42 AM
