Old 08-27-2018, 06:01 PM   #1
ccdrift
Drives: 2013 FRS
SCCA T4 Race Car Build - Suspension
Hi all, someone may already bring this up long time ago, but I did not find specific answer. Hope to get some help here.
I have my 2013 FRS since this March and had some track time in Michigan this summer. Since I raced Spec Miata before and really want to build this FRS to a full race car.
SCCA T4 would be good option. My question is what suspension/spring/damper is allowed in this class. Or what suspension do you use for T4 class? I bought my race ready Spec Miata, so I am new to how to build a car for racing. Any help would be appreciated.
What I found so far on SCCA GCR is:
Eibach 4.10582.880 and SPC 67660 allowed. Front strut tower brace allowed. Raceseng, part # raceseng-ft86-r-shock-top permitted.
Non-OEM limited slip differential allowed with +50 lbs. weight
penalty. 55mm flat plate restrictor required. Only 17” wheels permitted.
Eibach 4.10582.880 is Sportline Springs + Sway bar kits.
Does that mean the only spring upgrades to run T4 class is this Eibach Sportline Springs? We have to use OE damper?
Thanks,
Chen
ccdrift is offline   Reply With Quote
Old 09-07-2018, 02:41 PM   #2
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I am building my FRS into a T4 this off season as well so you're not alone.
You're correct on the suspension. You have to use that Eibach kit (Spring/sways) on the FRS - different cars get different options and non adjustable shocks that have a P/N stamped on them.
The popular option are Bilstein B8s but MCS and KW both have made non-adj shocks with OTS P/Ns for the cars they are sponsor (Dynasty FRSs in Florida and Oscar Jackson in California). Oscar uses the KWs.
PRO86 | WTCC | STL
Old 10-08-2018, 07:35 PM   #3
jfaphoenix32
Drives: 2018 Toyota 86
We just built a toyota 86 into a T-4 scca racecar for the runoffs at Sonoma..
Stay tuned for pictures and we will let you know how it runs and what we used...
Phoenix Built Roll cage
Non adjustable shocks suspension
Fire system
Race Seat
Shroth belts
jfaphoenix32 is offline   Reply With Quote
The Following User Says Thank You to jfaphoenix32 For This Useful Post:
strat61caster (10-22-2018)
Old 10-22-2018, 04:29 PM   #4
rice_classic
Fire system
Race Seat
Shroth belts
So the Bilstein B8s are the easy button for shocks without going for something like MCS/KW etc. The question I have is how did you go about incorporating height adjustability?
PRO86 | WTCC | STL
Old 10-22-2018, 05:11 PM   #5
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Reminds me of the T2 days when I was building a BMW for club racing.
The Bilsteins are not off the shelf and you would need get it custom valved for the appliction. The good thing is that based on the spring rates, they can match it for you. Believe mine were digressive. You can get new ones from them and have it revalved or send a used one and have it refreshed/custom valved.
MCS is good too (I use their double adjustables.... point is, their service is excellent)
Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
Old 10-22-2018, 08:52 PM   #6
rice_classic
Lutfy
I had planned on a revalve but still curious what adjustable perches are used to adjust ride height.
PRO86 | WTCC | STL
Old 10-23-2018, 04:39 PM   #7
lutfy
lutfy's Avatar
If it uses Eibach springs (OEM style) then it should work fine with the current perches on Bilsteins? If not, contact Ground Control and they can get you the custom perches (ride height collar etc).
Lutfy
2022 LR Defender
2023 BMW M2
Old 10-25-2018, 06:30 AM   #8
jmark
Drives: '97 NSX-T, '18 Type R
Fire system
Race Seat
Shroth belts
Joe's car won the 2018 SCCA Runoffs in T4 BTW.
https://www.scca.com/articles/201059...unoffs-victory
jmark is offline   Reply With Quote
Old 11-11-2018, 12:02 AM   #9
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
PSA: That car is currently for sale. For someone wanting to go T4 racing, it might be cheaper to buy a turnkey competitive car rather than build from scratch.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 11-11-2018, 01:05 AM   #10
rice_classic
If it was $25k I'd would have already bought it. I believe you can purchase/build one for under $25k and that's what my math is telling me... But in a couple months I'll be starting a build thread for my car. I think it will be a lot of fun and so far I haven't seen one yet for T4. I think it will be a positive thing to illustrate how easy and affordable it is to turn these into race cars and how affordable T4 racing is.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
strat61caster (11-11-2018)
Old 11-11-2018, 12:50 PM   #11
Rampage
Rampage's Avatar
That would be interesting. I hope you do that. I would definitely follow that thread.
Race-Spec ECU Tuning with EcuTek - SCCA Runoffs Championship Win Circuit Motorsports Software Tuning 0 12-14-2017 03:58 PM
Daryl Harr's FR-S SCCA Race Car Build driver71 Member's Car Journals 39 05-28-2016 04:50 PM
86 Meet & Race w/ SCCA Autocross Locust Northwest 136 08-22-2015 02:54 PM
86 Meet & Race w/ NWR-SCCA Locust Tracking / Autocross / HPDE / Drifting 5 08-11-2015 06:36 PM
Dixie SCCA autocross! Come race with us RWD-boxer Southeast 0 01-15-2013 09:52 PM
