Old 07-18-2018, 04:07 PM   #85
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
Originally Posted by weederr33 View Post
Still waiting to see more people field this kit....
Mine is coming by the end of the month
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
The Following 2 Users Say Thank You to Raven86Project For This Useful Post:
monkeybike (07-18-2018), weederr33 (07-18-2018)
Old 07-18-2018, 06:06 PM   #86
gtengr
Drives: 2017 BRZ
My example wasn’t an absolute or an always statement.
Re-read the posts that I quoted. They were written as absolutes.
In fact, it would be odd of me to try to use an absolute to refute an absolute. Don’t you agree?
Grady acknowledged the effect of efficiency on IATs in his initial post. The only thing to add to that was turbo power consumption. To say "a larger turbo achieves lower IATs" simply isn't correct. It is actually going to be wrong most of the time because people are most likely going to pick the right turbo for their application on the first attempt. So, even if it wasn't a bad example, you were still making a point that no one was arguing.
Also, Grady's point was that no amount of efficiency change would allow for 6 psi to make 360 rwhp on 93 octane, and that is correct.
gtengr is offline   Reply With Quote
Old 07-18-2018, 07:00 PM   #87
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Right. I already apologized for not making it clear or spelling out the implications. A larger turbo is a relative thing to say. Perhaps a smaller turbo would be optimum at a given psi and a larger wouldn't depending on a number of factors such as the point of maximum efficiency. I should have said a different sized turbo instead of larger, but again, the point was that 6psi is not always equal to 6psi, and the idea is that a different sized turbo could allow for improved efficiency, reduced temperatures, better flow and allow for more aggressive tuning (a different turbo, not necessarily a larger, but again, a larger is a good/common example). I don't get if you are refuting that or arguing the fine points because the bigger point is that a given psi is not inherently deterministic of power output.
That was my whole point. I was arguing against one of his points--not his conclusion. I'm done here.
Old 07-24-2018, 07:03 PM   #88
Scracho
Drives: 2018 Subaru BRZ
Updates?
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
Old 07-30-2018, 04:32 PM   #89
Raven86Project
I just got mine! Ordered on April 26th.
IG: raven86project
Build Thread HERE
Evil Rocky (07-30-2018), funwheeldrive (08-17-2018)
Old 08-17-2018, 11:15 AM   #90
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
From local tuner's FB page where my car is at.
390ish rwhp @ 1.0 Bar
https://www.facebook.com/EvolutionRm...314?__tn__=C-R
stevo_12v is offline   Reply With Quote
The Following 2 Users Say Thank You to stevo_12v For This Useful Post:
Raven86Project (08-17-2018), weederr33 (08-17-2018)
Old 08-17-2018, 08:52 PM   #91
johl
johl's Avatar
Drives: toyota 86
So it gained 60hp with more than double the original boost? Something is off here
johl is offline   Reply With Quote
Old 10-13-2018, 07:48 AM   #92
johl
johl's Avatar
Drives: toyota 86
so are there any real world updates from people that have this kit?
Old 10-25-2018, 01:53 AM   #93
Raven86Project
I'll get mine dynoed in the near future.
IG: raven86project
Build Thread HERE
monkeybike (11-17-2018), weederr33 (11-18-2018)
Old 10-25-2018, 12:00 PM   #94
Northwest86
Drives: Velocity Orange 86 GT
Yea that shops Dyno numbers were waaaaaay off. No corrections were put on it at all. Temperature sensor for the dyno wasn't running. And they were on stock fuel on a 98 car. Even if you go by NSW Disney Dyno numbers 300-320hp is about the max you can get out of the stock fuel system. Which this car had. There is no way in hell they got those numbers on 6PSI. Let alone a stock system. The HKS system will perform exactly the same as any other Turbo application, give or take the usual 5% in efficiency gains or losses. Torque curves and boost response is the difference in kits that you see. It will however be fairly good in throttle response compared to most kits by the looks of it which will be its benefit over most kits.
Northwest86 is offline   Reply With Quote
Old 10-25-2018, 12:20 PM   #95
wbradley
Sarcastic SOB
wbradley's Avatar
Looks really nice...!
If I were to do another one I'd want to try this package for sure. If you can run this car safely at 275-300 HP, you're laughing. Any more than that power and you are mostly just laying rubber, unless you have 11" rear wheels with huge fender flares. Then, keep boostin'
Why do all the normally yellow coloured plastic parts look purple?
Old 12-28-2018, 12:52 AM   #96
johl
johl's Avatar
Drives: toyota 86
Mine is mostly installed and will be tuned next week.
The Following 4 Users Say Thank You to johl For This Useful Post:
Hot-Lava_Dave (01-10-2019), kev0 (12-28-2018), monkeybike (12-28-2018), Raven86Project (12-28-2018)
Old 12-28-2018, 01:03 AM   #97
Raven86Project
So you finally pulled the trigger! Congrats man!!! You're not going to regret it!
IG: raven86project
Build Thread HERE
The Following User Says Thank You to Raven86Project For This Useful Post:
johl (12-28-2018)
Old 12-28-2018, 01:23 AM   #98
johl
johl's Avatar
Drives: toyota 86
Your build definitely helped my decision. Other than what you have posted there isn’t a lot of information out there.
I’ve had a baseline dyno run done and will post both the before and after when I get it back
The Following User Says Thank You to johl For This Useful Post:
Never been so excited for an oil change... No Limit Motorsport Engine, Exhaust, Transmission 20 09-28-2012 12:59 AM
Beyond excited!! debs0712 Scion FR-S / Toyota 86 GT86 General Forum 12 06-27-2012 10:03 PM
Excited!!!!!! Filipino Royale BRZ First-Gen (2012+) — General Topics 2 06-13-2012 11:14 PM
So excited to be here!!!! staycrushing Scion FR-S / Toyota 86 GT86 General Forum 8 05-31-2012 08:05 PM
Brisbane get excited! spr1nter AUSTRALIA 29 05-14-2012 08:07 PM
