View Poll Results: What name should Toyota use for the production Toyota FT-1?
Supra gets my vote! 367 74.59%
I don't know, but its time for a new name. 125 25.41%
Voters: 492. You may not vote on this poll
Old 10-24-2018, 09:54 AM   #3809
Sasquachulator
Pavement Grey
Originally Posted by Wise View Post
A bit disappointed that they didn't at least attempt to replicate the fighter cockpit design from the MKIV and MKIII.
As expected it's a BMW interior.
yup, it may look a bit different than the BMW interiors (All the brand new ones seem to be following a stretched 'hexagon' shaped theme for the center stack)
but its all BMW switchgear so far.
Sasquachulator is offline
Old 10-24-2018, 10:24 AM   #3810
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I hate how all the companies are moving towards that stupid radio / info screen design. I know it is supposed to increase visibility and packaging, but damn....just slap it in the dash!! Mazda, I thought was bad....now the new Altima is the current top offender (IMO) but this might beat them all.
Summerwolf is offline
The Following User Says Thank You to Summerwolf For This Useful Post:
Ultramaroon (10-26-2018)
Old 10-24-2018, 10:47 AM   #3811
The ultimate "disaster" is the Tesla Model 3 in my opinion. Another reason I wouldn't buy one.
Dadhawk is offline
JD001 (10-24-2018), Ultramaroon (10-26-2018)
Old 10-24-2018, 11:03 AM   #3812
Summerwolf
Panda Trueno
Summerwolf's Avatar
Fack...... that is awful. The sizing reminds me of
the new dodge rams giant tablet in the middle, I just dont get it.
Was dash visibility really that bad!?!?!
Old 10-24-2018, 11:36 AM   #3813
its your entire dash instrumentation too.
Dadhawk is offline
Summerwolf (10-24-2018)
Old 10-24-2018, 11:49 AM   #3814
Summerwolf
Panda Trueno
Summerwolf's Avatar
It seems like that would be a huge night driving distraction. Idk how they display at night, I'm sure they have that in mind. But there still has to be illumination there.
Dadhawk (10-24-2018)
Old 10-24-2018, 11:50 AM   #3815
I've not driven one, but I'm assuming it has a "dark mode" like a moving map does at night.
Dadhawk is offline
Old 10-24-2018, 02:57 PM   #3816
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
All cars are moving away from knobs and physical controls, which can suck because user interfaces can be lame and can be harder to operate than knobs. What is worse is when the screen fails, and then the features can't be adjusted because their are no knobs. This is why they are putting both for now, but the future is what Tesla is doing.
As far as design, it isn't pretty, but a tablet up high is better than down low. Maybe when autonomous cars become more of a standard and the reliability is virtually flawless then the screen will be moved lower and integrated with the dash because taking your eyes off the road won't be an issue. For now, this design seems better to me. It allows for a cheaper vehicle, and it allows for a control unit that is easily replaceable if it fails, which is probably cheaper to replace/reproduce than something that is integrated.
Irace86.2.0 is offline
Old 10-24-2018, 04:09 PM   #3817
,,,For now, this design seems better to me. It allows for a cheaper vehicle, and it allows for a control unit that is easily replaceable if it fails, which is probably cheaper to replace/reproduce than something that is integrated.
I think this is only acceptable if the car also has a heads up display. Otherwise instruments need to be within you scan range that doesn't require you to turn your head. That's my primary problem with it.
I would not buy a Model 3 (or an ICE equivalent) for this one reason, everything else being equal.
Dadhawk is offline
Old 10-24-2018, 06:42 PM   #3818
Irace86.2.0
I rarely look at my speedometer. I look at my tach more than anything then my oil pressure gauge, boost, oil temp, etc. Even with that said, I rarely need to look at my tach unless I am taking the car to redline. Even with that said, there is a shift light, and even still, the Tesla has no need for a tach. I think the argument for a HUD or a traditional gauge layout is weak.
Tesla is definitely not the first to do this, as you mentioned. Toyota, Honda, GM, etc have all done it. They actually claim it is a better position to have it. The focal point is slightly less extreme. The contrast between a dark dash and the bright exterior is less extreme too. The distance the eye has to travel is usually less. The head doesn't have to move as much. But that is probably all marketing BS . The real advantage is the car is cheaper to build with a symmetrical dash for LHD and RHD.
Old 10-24-2018, 07:41 PM   #3819
Sure, if you don't use it. I have a very specific instrument scan pattern I use when driving, and check all instruments on a fairly regular basis. I suppose if I never looked at them that would make sense.
Tesla is definitely not the first to do this, as you mentioned. Toyota, Honda, GM, etc have all done it. They actually claim it is a better position to have it...
I think it is a better position for the non-critical instruments usually in that panel (radio, HVAC, map, etc) I have no issue. For your primary instruments though its a bad location IMO. That's OK, some cars have had their regular "steam" gauges in that location as well, and I wouldn't have bought them either.
Dadhawk is offline
Old 10-25-2018, 04:43 AM   #3820
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Supposedly Ford went back to knobs and switches after people complained about an all touch interface. That is, one had to look away from the road to change air con controls. If you can't change basic functions like that without looking away from where you're going there is something wrong with the interface.
Captain Snooze is offline
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Dadhawk (10-25-2018), Ultramaroon (10-26-2018)
Old 10-25-2018, 08:40 AM   #3821
FTCLUB_USER_0086
Drives: C450
All these touch screen displays are a bad idea. I don't know why they are even allowed. Looking/using your smartphone is considered distracted driving in some places while using these kinds of touch screens to change a setting (HVAC, Radio, GPS, etc...) isn't?
You pretty much have to focus on the screen to be able to select properly.
Sent from my SGP621 using Tapatalk
FTCLUB_USER_0086 is offline
The Following 5 Users Say Thank You to FTCLUB_USER_0086 For This Useful Post:
Captain Snooze (10-25-2018), Dadhawk (10-25-2018), LancePower (10-25-2018), new2subaru (10-25-2018), Ultramaroon (10-26-2018)
Old 10-25-2018, 10:10 AM   #3822
Sasquachulator
Pavement Grey
that really depends on how responsive the touch interface is.
IT makes me wonder why no cars have an interface that is actually as fast and responsive as a smartphone, they always seem sooo laggy.
Ford's Sync system apparently was bad for awhile.
Cadillac's Cue system is laggy as hell.
I had a Honda Fit with a touchscreen interface which was OK, but the volume slider was a touch slider and it was somewhat laggy and annoying at times.
Im sure if the interfaces responded like a smartphone it wouldn't be so bad.
I still prefer knobs/buttons though for some functions.
bmwforsuckers, boring-zzzzzzzzzzzzz, brz, celica supra confirmed, frs, ft-1, hatch-y +1, morethanucanaffordpal, nomanualnogo, supra, toyota, twins, watstheretailon1ofthose
Toyota FR-S : Official Name for the FT-86 Concept? Dark Scion FR-S / Toyota 86 GT86 General Forum 155 08-04-2010 11:05 PM
