#4761 | |
Drives: JR FR-S,
Jackson Racing Staff Chris |
| The Following User Says Thank You to Jackson Racing For This Useful Post: | mrg666 (10-23-2018) |
#4762 |
Drives: frs
Hate to parrot what JR said but I agree. I drove my car with the same setup you have last winter in sub freezing temps and didnt have any issues.
| The Following User Says Thank You to amcp1 For This Useful Post: | mrg666 (10-23-2018) |
#4763 |
Clean your MAF sensor. A dirty MAF affects the entire RPM range, but affects idle most!
| The Following User Says Thank You to CSG Mike For This Useful Post: | mrg666 (10-24-2018) |
#4764 |
Drives: 13 Brz Jrsc
how many quarts of traction fluid do i need?
just got this kit second hand thanks |
#4765 | |
https://www.counterspacegarage.com/r...-fluid-1-liter https://www.counterspacegarage.com/rotrex-oil-filter |
#4766 |
Drives: 2013 FRS
Reporting back from track weekend.
Last time I took the car for a shake down at an HPDE event and car ran fine all day. I went on a 2 days time trials at Laguna Seca. Car ran flawlessly all day. The CARB tune and street tires put me in the midpack of my run group. The power delivery is smooth and linear, perhaps too smooth and linear that it felt drama-less - in a good way While still no match with most cars purely in acceleration department, I wasn't far off to most except some really fast ones The smooth and linear power delivery induces high confidence, and I noticed that within 2 sessions I was pretty much pedal to metal all the time, so much I literally ran full tank of gas in the next 2 sessions. I had little under 1/5th tank when I prep'ed to exit and that's when session ended. I filled up the tang and did the calculation: 7.2 miles / gallon! At 2.238 miles, a gallon gives just little over 3 laps... Not that using gas bothers me, but this means I need to watch my fuel more closely than what I am used to. Lesson here is to those tracking their JRSC'ed FRS/BRZ, don't forget to check fuel level every lap !! ![]() Oh, engine temp stayed cool all day, never went near half mark ![]() Happy supercharging
2013 FRS - JRSC CARB
"Use all of the track" they say |
#4767 | |
Drives: 13' Asphalt
Sent from my PH-1 using Tapatalk
"always forward" >>>>>>>>>>>
#4768 |
Drives: 2013 FRS
Yes I do have the JRSC engine oil cooler
| The Following User Says Thank You to milanojess For This Useful Post: | S. Snake (10-26-2018) |
#4769 |
Drives: 13' Asphalt
Okay just wondering. I should PROBABLY get one in case mine ever finds itself on a track.
#4770 |
Drives: 2013 FRS
my understanding is that these cars' oil temp gets pretty high even in stock form. The obdii port has oil temp readout but no gauge displays that critical info. I think any modded engine that sees hard use should have the oil cool installed.
| The Following User Says Thank You to milanojess For This Useful Post: | S. Snake (10-29-2018) |
#4771 |
Drives: 13' Asphalt
I'm aware of the nessecity of the oil cooler for track use. I'm more or less on the edge of making the plunge into taking my car to the track but knowing myself it may become a hobby that has my interest one or two track days then I'll just walk away from it like it didn't happen.Sent from my PH-1 using Tapatalk
#4772 |
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
If anyone is interested I parted out my car and have a brand new Jackson Racing C30 High Boost Pulley, and Jackson Racing Version 2 Intake Pipe that I am interested in selling.
#4773 |
Before I was boosted, I monitored my oil temperatures on the track. Highest I saw was 275 F. Ambient temperature was 85. I'm running 5W-30. I sent the oil to Blackstone labs and they said it was fine.
| The Following User Says Thank You to D-rek07 For This Useful Post: | milanojess (11-01-2018) |
#4774 | |
Drives: 2018 BRZ tS
Also would be interested in the JR 4 Bar MAP Sensor and Forge Diverter/By Pass Valve. Price for both? Color for Forge Diverter? Nevermind this...I just found your other post...PM'D! Last edited by J1Avs; 10-31-2018 at 05:29 PM. |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
