Old 10-23-2018, 01:15 PM   #29
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Okay I think Chicago and Toronto have similar road surfaces so that sounds just about right. Good thing I kept my oem coils. I will try that and hope it works cause these are more than twice the price of my coilovers. I think I'll keep OEM top hats in the back only, cause the front doesn't give me issues, just the back. All I know about my current ones is that they're 5kg/mm in the front and 4 in the back.
What brand are they? Interesting, 5k front 4k rear... I have not installed mine yet, (literally just ordered the roller bearings) but mine have stiffer springs on the rear. 6k front 7k rear. The OEM springs are stiffer in the rear too. Don't know exactly how this will change your car, but it has.
I LIKE TIRES!
Old 10-23-2018, 01:18 PM   #30
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Yeah, that's pretty soft. That's actually around the same softness as the V3s. Though I suspect that the V3s will still ride better. They'll also survive Toronto winters if he decides to drive it in the winter.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 10-23-2018, 01:23 PM   #31
Leonardo
Country Boy 4 Life
Leonardo's Avatar
They should ride better; they consistently get great reviews for aggressive street driving with some track use mixed in. And the Stainless bodies are nice too!
They were my first choice.
I LIKE TIRES!
Old 10-23-2018, 01:23 PM   #32
StraightOuttaCanadaEh
Wes
What amount of camber are you running at the front? I honestly would recommend staying with OEM top hats up front too if you can get away with it. It will really help with the NVH.
Can't remember off the top. Like -2?
Instagram: @gt86ws
Old 10-23-2018, 01:24 PM   #33
Wes
Oh yeah I've been driving in the winter. I have those ISC coilover socks
Instagram: @gt86ws
Old 10-23-2018, 01:24 PM   #34
Wes
Meisterr. Seemed a good choice at the time and at that price. And truth be told, they're not bad. Just obviously not up to our roads and not as good as a coilover twice the price
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Leonardo (10-23-2018)
Old 10-23-2018, 01:25 PM   #35
Stang70Fastback
A.K.A. Starlord
If you're at around -2, you should be able to achieve that without camber plates. The V3s have a pretty bit slot for the upper knuckle bolt. When I installed mine, I pushed my knuckle to "max camber" on the strut, and initially installed the camber plates at the "zero" setting before getting an alignment, and both front wheels were right around 2 degrees of camber in that configuration. I run more than that amount of camber, so that's why I have camber plates (autocross things), otherwise I too would run the stock front top hats for a bit less NVH.
Old 10-23-2018, 01:27 PM   #36
Wes
Oh that's excellent then. Very good to know, thank you. Maybe I'll put them at the top of my wish list. Cause the more stuff I do to my car, the more inadequate the current ones seem
Instagram: @gt86ws
Old 10-23-2018, 01:28 PM   #37
Stang70Fastback
A.K.A. Starlord
So do I! Two salt-covered winters later and my coilovers still literally looked like new when I peeked underneath. That rust-looking stuff on top of the metal ring behind the bottom coil was some other gunk or something that flaked right off when I touched it.
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
Leonardo (10-23-2018), StraightOuttaCanadaEh (10-23-2018)
Old 10-23-2018, 01:31 PM   #38
Wes
damn, good to know they actually work! I was wondering this whole time
Instagram: @gt86ws
Old 10-23-2018, 10:37 PM   #39
Decep
Drives: 2013 FR-S Series 10
easiest thing would be to add more sidewall to your tire imo. if you're already on the newer springs and shocks.
Old 10-23-2018, 11:35 PM   #40
Wes
I thought about this but don't know how high I should go. Currently I'm 225/40/18
Instagram: @gt86ws
Old 10-24-2018, 07:25 AM   #41
new2subaru
Weight Weenie
Drives: 15 FR-S
I run 225/50 R16 on the street and it helps the ride tremendously. I have 23mm extra sidewall over your 18's!
But, after reading what I think you want I'm not sure that's what you're really after. If you want a "tight" suspension, you could start adding more poly bushing gradually.
Can you do the work yourself? If not, I would imagine bushings would get expensive.
The Following User Says Thank You to new2subaru For This Useful Post:
Leonardo (10-24-2018)
Old 10-24-2018, 09:19 AM   #42
Wes
yeah they're pretty expensive to install. I'm think poly would be too rigid, no?
Instagram: @gt86ws
Save money on suspension upgrades! AJW Performance Brakes, Suspension, Chassis 34 05-05-2016 10:05 AM
Save money on suspension upgrades! AJW Performance Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-09-2015 11:06 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
Wear on outside of tires - suggest suspension upgrades? 1Cor10:23 Tracking / Autocross / HPDE / Drifting 43 06-13-2014 08:51 PM
