| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Legacy
Help winter wheels/tires for tS
I am looking at a wheel/tire package these are Tire Rack certified with the BRZ PP brakes.
Note these wheels have +42 offset but I can look at ones with +45 but I don't know that is better? TireRack won't say if they will be ok for tS but I assume they should be ok because the tS os not lowered. here is the tires/wheels the wheels are https://www.tirerack.com/wheels/Whee...kageFlow=false https://www.tirerack.com/tires/tires...cleSearch=true Last edited by Rai-zero; 10-22-2018 at 12:25 AM. |
#2 |
If it fits PP brakes it will fit your TS.
+42 offset is good. The Methods will work well for you. For a winter wheel, 17 inch wheels make a little more sense and will save you some money but not a huge deal. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Rai-zero (10-22-2018) |
#3 |
Drives: Legacy
thanks
#4 |
For a 17x8, a 225/45/17 works well.
I run Bridgestone Blizzak WS80 on my car and like them. - Andrew |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#5 |
Country Boy 4 Life
I have tried a few different sets of studded tires now. Nokian Hakkapeliitta 9's are my favorite, and available in 225/45/17
I LIKE TIRES! |
#6 |
Drives: Legacy
Hey all I don’t want snow/ice tires. I’m looking for tires that will perform in cold conditions, I typically run the high performance winter tires.
#7 |
A.K.A. Starlord
Drives: 2015 Series.Blue
Lol. You know you don't have to start a new thread for every question, right?
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | Rai-zero (10-22-2018) |
#8 | |
Site Moderator
Drives: ichi 86 Project
| The Following User Says Thank You to ichitaka05 For This Useful Post: | Rai-zero (10-22-2018) |
#9 |
Country Boy 4 Life
You linked the Alpin PA4 tire, and don't want a snow tire?
"The Pilot Alpin PA4 is Michelin's Performance Winter / Snow tire developed to meet the needs of enthusiasts who may encounter snow-covered roads..." I still say Nokians.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Rai-zero (10-22-2018) |
#10 |
Drives: Legacy
performance winter tires good not just for snow.:
"Compared with Studless Ice & Snow winter tires, Performance Winter / Snow tires deliver better handling on clear roads along with improved wet and dry traction in winter's cold temperatures. The tradeoff comes with modestly lower ice and snow traction. But when winter weather strikes, Performance Winter / Snow tires still deliver better performance than the best all-season tires." [ame]https://www.youtube.com/watch?v=NJoRpE0GT3E[/ame] Last edited by Rai-zero; 10-22-2018 at 10:15 PM. |
| The Following User Says Thank You to Rai-zero For This Useful Post: | Leonardo (10-22-2018) |
#11 |
Drives: 2017 BRZ
For a winter tire that does well in warmer conditions, Nokian WR G3. Still does well on ice/packed snow, but really well on dry/wet. And doesn't fall apart above 40°F
| The Following User Says Thank You to cjd For This Useful Post: | Leonardo (10-24-2018) |
#12 |
Only happy when it rains.
Drives: series.blue
I don't get winter 'performance' tires. Totally misses the point of the tire. You don't need winter tires for the dry, you need them for snow/ice/slush/etc.
Nokians are the best, but crazy expensive. I have General snow tires and they were awesome, and they handled rather well too. |
#13 | |
Drives: Legacy
Snow/ice tires are better in snow/ice but *worse*everywhere*else* than every other tire. WORSE THAN EVERY TIRE when it's not snow/ice. I am not driving in snow and ice that much so I don't need snow and ice tires. Where I live the roads are plowed after it snows so 98% of the driving will be on dry roads or in rain. Now my car has Summer tires so they are not good in cold temps so if the temp is less than 40 degrees then I need to get either all season or snow tires. In this case performance winter tires give the feel and drive of all season tires but are better in snow than all season if I am forced to drive in snow. If you would think about it the snow/ice are better for snow and ice but worse everywhere else. Since my driving will be 98% not snow, I will buy performance winter tires are better than all season in cold and far better than snow and ice tires in wet/dry conditions. Here is a review that test snow/ice tires https://www.tirerack.com/tires/tests...y.jsp?ttid=193 here is a review of performance winter tires https://www.tirerack.com/tires/tests...y.jsp?ttid=181 example from test (similar/same test car). Dunlop Winter Maxx (Snow./ice tire) Ice stopping 12-0 mph 35.4 feet stopping 50-0 wet/dry 159/97 feet cornering wet/dry .54/.81 G Michelin X-Ice Xi3 (Snow/ice tire) ice stopping 30 feet stopping 50-0 wet/dry 131/93 feet cornering wet/dry .63/.84 G Dunlop WinterSport (performance winter tires) Ice stopping 12-0 mph 35.6 feet stopping 50-0 wet/dry 105/91 feet cornering wet/dry .75/.88 G Michelin Pilot Alpin PA4 (performance winter) Ice stopping 32 feet stopping 50-0 wet/dry 105/88 feet cornering wet/dry .76/.89 G You can look at the tests overall but the summery is this: Snow/Ice tires good in snow but not great in dry/wet conditions. Look at the test snow/ice take 159 or 131 feet to stop in the wet vs 105 feet for the performance tires it's a no brainer to get the performance winter tires for a performance car. Plus I have an AWD car that I will drive when it is really snowing or ice out. Performance winter tires good all around in cold wet or dry weather Last edited by Rai-zero; 10-28-2018 at 11:41 AM. |
| The Following User Says Thank You to Rai-zero For This Useful Post: | Spuds (10-28-2018) |
#14 |
Drives: 2014 GT86
Rai-zero: are snow/ice tires worse when warm weather and on good pavement? yes. But it makes sense to give up some grip when it's plentiful, to gain all grip possible, when it's scarce, as later is when there is higher probability to get into accident or stranded. At least for ones driving within legal limits on public roads.
| Urgent Springs Install Help! PDX | LeonardoDaVinny | Northwest | 22 | 09-05-2018 07:32 PM |
| Urgent help needed please! | Swoldier86 | Scion FR-S / Toyota 86 GT86 General Forum | 134 | 12-31-2017 10:07 PM |
| Urgent need of help | 86z | Issues | Warranty | Recalls / TSB | 6 | 11-12-2016 11:48 AM |
| WTB: CAMSHAFTS urgent! | Ondreiko | Want-To-Buy Requests | 0 | 09-25-2014 02:17 AM |
| FS LED kits(Urgent) [WA] | GTiko | Australia Classifieds | 1 | 10-29-2012 11:43 AM |
