Old 10-21-2018, 12:08 AM   #19797
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
Green+red=brown no? Red turn signals are perfectly legal anyways
According to Google green + red = yellow. I know red turn signals are legal. I just think it would be neat to have an all red lens but retain the yellow turn signal.
Face_Plant is offline   Reply With Quote
Old 10-21-2018, 05:29 AM   #19798
Hypnocracy
Hypnocratic Missionary
Hypnocracy's Avatar
Additive color (mixing light sources - LED or incandescent) green + red = yellow your theory is correct
But, you have green light led and a red filter. Green - Red = ??? not the same. Filtering a green light with red lenses will be darker. Look into subtractive color theory.
Hypnocracy is offline   Reply With Quote
The Following User Says Thank You to Hypnocracy For This Useful Post:
Face_Plant (10-22-2018)
Old 10-21-2018, 08:26 AM   #19799
2018Asphalt86
Drives: 2018 Toyota 86 Base
Installed Tomei UEL and Tanabe OP
Tomei Expreme UEL, Invidia N1, Injen Evolution CAI, Crawford BPB, Tanabe OP, Tanabe FP, Radium MC Brace, CSF Filler Neck, Torque Solution TBS, Tanabe Rear STB, OFT STG2+ E85
2018Asphalt86 is offline   Reply With Quote
Old 10-21-2018, 04:04 PM   #19800
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Parts keep coming in. Now just need my front sway bar and bumpsteer kit.
via Imgflip Meme Generator
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
StraightOuttaCanadaEh (10-21-2018), zeal86 (10-22-2018)
Old 10-21-2018, 04:33 PM   #19801
Well, they sure are perty -
Leonardo (10-21-2018)
Old 10-21-2018, 05:53 PM   #19802
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks! I think so too!
Initial impressions.
FA COILS - These coils are nice quality parts. review after install.
BLACKWORKS LCA - Wow! These are beautiful! They have completely exceeded my expectations. More pics soon.
I LIKE TIRES!
Old 10-21-2018, 07:25 PM   #19803
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Did it yesterday, and nothing special, just replaced the cabin air filter and wiper blade inserts, both terribly overdue.
The total cost of both inserts was less than the cost of one replacement blade like a Bosch Icon that you'd get at a store, and the swap was practically child's play. Would recommend for those of you who haven't eliminated your OEM wipers yet to stick with replacement inserts.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 10-21-2018, 08:44 PM   #19804
WesMatthewsPDX
Drives: 2015 FRS 6 Speed Turbo
Installed the fit back up camera. Fun times it took me 3 hrs.
WesMatthewsPDX is offline   Reply With Quote
Old 10-21-2018, 09:07 PM   #19805
Ashikabi
Ashikabi's Avatar
If you are going for maximum cornering traction, I found the rear sway bar actually made it slipperier
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 10-21-2018, 11:51 PM   #19806
notout86
Drives: GTS 86 auto
Originally Posted by Enkrow View Post
To give you an idea of how far forwards I am, my elbow rests at the heated seat controls.
That sliding armrest is my favorite that I have seen though, I feel like none of the others are anywhere near as functional.
I prefer an armrest on the door that rests my elbow up high enough that aligns my hand with the steering-wheel spoke. I rest my other hand on the underside of the wheel on my thigh. Make a mock-up to try. I found a center armrest constricting and got in the way when changing gear.
GTS86 Auto (Australia)
Old 10-21-2018, 11:59 PM   #19807
notout86
Drives: GTS 86 auto
Originally Posted by LeonardoDaVinny View Post
Put on some red trim on the rear diffuser, spats, sideskirts, and front lip!
Attachment 171580
Attachment 171581
Are those tyres 215/45 like the o.e. Michelins? If so, are is the ride softer and what brand are they?
Like the red trim. Is it guaranteed not to fade.
Old 10-22-2018, 12:24 AM   #19808
notout86
Drives: GTS 86 auto
I hope you didn't put the video cable along the door sill like I did. If you go across in the trunk , put it between the rear seat backs and poke it up under the tunnel cover (no need to remove the cover) it is easy.
The Following User Says Thank You to notout86 For This Useful Post:
wulfstan (11-04-2018)
Old 10-22-2018, 07:59 AM   #19809
2018Asphalt86
Just bought an OFT and installed the Stage 2+. I will try E85 went my tank gets low, have 93 in right now.
First impressions:
Cold start is about 400 RPMs lower which is nice since I leave for work at 4:30 and the neighborhood is dead quiet lol.
Idle after warm up is at about 600, makes for a nice loping rumble at the intersection
Lots more throttle response and pretty decent pull even in higher gears which is really nice in traffic, no constant down shifting.
Overall very pleased with the purchase. I was even able to clear the CEL I got the other day after installing the catless uel.
Old 10-22-2018, 09:41 AM   #19810
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks for the input. The rear sway pictured is a 16mm Perrin. Plan on using the softest setting for the rear.
Rear : 16mm
3 position
16mm Hole #1 30%
16mm Hole #2 65%
16mm Hole #3 116%
What bar did you install that made it slipperier feeling?
My goal is to have my car feel: more connected, planted, stiffer, yet still not harsh, and a bit more technical to drive.
And if anyone notices that I have 2 sets of front endlinks... I was told by the vendor, that THESE FA coils 100% did not come with them. (even though front endlinks are pictured on the FA's website) So, I ordered whiteline front to match the rear endlinks. Now I have two sets....
I LIKE TIRES!
