Old 10-20-2018, 06:09 PM   #4747
Brz866
Brz866's Avatar
Drives: Series Blue WRB JRSC C38 HBP Flex
Anyone currently running the C38 with HBP on 93 octane with supporting fuel mods and oil cooler? My question is how reliable is this setup? My understanding is tuning plays a big part and the rest is up to the rods.
Brz866 is offline   Reply With Quote
Old 10-20-2018, 06:58 PM   #4748
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
I'm putting this out as a feeler:
Would anyone be interested in a used C30 complete JRSC CARB tuned kit?
It's about 3 years old, the C30 itself is about 2 years old as it was replaced a couple years ago when the original failed. I have since over maintained the new unit and change the oil every 12 months regardless of miles.
Everything would be provided to you 100% complete and in very very good condition.
Fair price would be worked out if there was interest.
I am debating returning the car to stock and trading it in.
Private message me so we don't derail the thread here please.
Sent from my SM-G950U using Tapatalk
keithr is offline   Reply With Quote
Old 10-20-2018, 11:38 PM   #4749
CSG Mike
CSG Mike's Avatar
No need for supporting fueling mods for that setup. Oil cooler is always a great idea.
With good tune, you should be okay!
What will the car be used for?
Old 10-21-2018, 01:21 AM   #4750
Brz866
Brz866's Avatar
The car will be almost entirely street driven. Maybe an autocross one or twice next year but that's it. Delicious tuning is doing the ecutek e-tune. Just worried about the engine holding up to the increased boost pressure and power levels. I understand this setup with a full catless exhaust could be near the 300 whp zone. I was thinking maybe shifting around 7k instead of redlining would help a lot as well. Any advice on how to be as safe as possible on this setup is much appreciated!
Sent from my SM-G955U using Tapatalk
Old 10-21-2018, 01:26 AM   #4751
CSG Mike
CSG Mike's Avatar
Shifting at 7k instead of 7400 will definitely help with long term reliability, as well as reduce peak boost seen. Should be totallyfine. Let them know you want the lowered redline.
Old 10-21-2018, 01:49 AM   #4752
Brz866
Brz866's Avatar
Thank you Mike that gives me some much needed peace of mind. I've looked but I can't find a whole lot of info involving HBP/93/reliability. I opted for injectors and fuel pump per my tuner's recommendation just in case of E85. Would the stock fueling system have sufficed for HBP and 93?
Last edited by Brz866; 10-21-2018 at 02:28 AM. Reason: I should clarify I did the injectors and pump as a future-proof in case of E85 down the line.
Old 10-21-2018, 05:57 AM   #4753
CSG Mike
CSG Mike's Avatar
Yup!
Old 10-21-2018, 11:03 AM   #4754
mrg666
pessimistic skeptic
mrg666's Avatar
I have JRSC (c30 with default pulley) installed on a stock engine (stock header, injectors, fuel pump, etc) with CARB tune. I am noticing that the CARB tune, although it is very smooth and efficient at normal temperatures, does not seem to perform well in colder weather. I can understand that hot or cold temperature can affect the performance (power) but the engine should still be smooth at least. The engine feels different on a cold day in the same week with the same gas in the tank. Is there an updated tune for JRSC that I can get? Do you think Delicious tune can help? If I order Flash & Go tune, do I need to replace the MAP sensor?
Old 10-21-2018, 12:18 PM   #4755
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
@mrg666
See other thread with duplicate post for comment.
Old 10-22-2018, 04:13 PM   #4756
mrg666
pessimistic skeptic
mrg666's Avatar
@mrg666
The whole post was repeated to explain the reason for the following question which I didn't ask in the DT thread.
Old 10-22-2018, 07:30 PM   #4757
gtengr
Drives: 2017 BRZ
Originally Posted by mrg666 View Post
I am most interested in comparing stock-header+JRSC to Ace-header+JRSC, I mean the difference Ace header makes with JRSC. Data is very limited showing this difference. Maybe because it doesn't make much difference.
Anything worse than the NA power increase from the Ace is quite frankly impossible. I would expect the NA gains plus another 5-10 rwhp.
gtengr is offline   Reply With Quote
Old 10-22-2018, 11:37 PM   #4758
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
It will certainly be more than 5-10hp over the CARB tune. Quite a lot more under the curve.
mistople is offline   Reply With Quote
Old 10-22-2018, 11:53 PM   #4759
gtengr
Drives: 2017 BRZ
5-10 hp over the NA gains would be a 20-30 hp increase
Old 10-23-2018, 11:23 AM   #4760
mistople
mistople's Avatar
Whoops. I didn't have coffee yesterday. You said NA in your post twice and I still thought we were talking about a CARB vs. ACE setup. Ignore me!
The post you originally quoted was talking about stock header + JRSC vs. ACE + JRSC—which is indeed at least a 20-30hp difference.
The Following 2 Users Say Thank You to mistople For This Useful Post:
gtengr (10-23-2018), HachiRokuX (10-26-2018)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
