| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 | |
Re-member
Drives: Toyota camry
Never said anything about wear resistance.
Nothing decays like progress, and nothing preserves like neglect.
#16 |
Re-member
Its not all about viscosity. Oil acts like hydraulic fluid for the variable cam timing. To be fair though, Toyota did do a running change in oil weights without changing the engines in any way and some engines require different oil weights depending on which continent they are on. So I say follow what the manufacturer says but there is some wiggle room. That's right, I'm ending my discussion in this thread with the term wiggle room.
#18 | ||
Drives: Nevermorange FRS
It's also important to note that The Manual itself recommends a higher weight oil. Quote:
#19 |
form follows function
Drives: RIP '13 BRZ
I've seen 5w30 going around as the higher viscosity to run if you're tracking regularly, but I don't think you will hurt sticking with 0w20. Get your oil tested for metals next change and see if it's hurting.
#20 |
I think for daily driving 0W20 will do the job. Start up and warm up time remains the same.
if you do track the car, I think 5W40 will make more sense. It can handle high temperatures so the engine oil will not break down as quickly as 0W20. |
#21 |
Curious cat.
Drives: 86 GT base M/T - Red
What about this suff: Mobil1 0w 40?
http://www.gulf-sport.com/store/mobi...40-engine-oil/ I live in a hot climate and want an oil that'll protect well and stand up to high heat, even under AutoX/HPDE conditions (above 100 Farenheit ambient most days). we get really crappy oil selection here in Dubai, although the guys at the link I posted do sell Redline oils too.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#22 |
toyotas are practical :)
Drives: Hot Lava FRS
^^^ a lot of GTR's use that weight. I suggest you turbo it and change to 0w40 post haste !
#23 |
this is not he correct oil
I'm in AZ and the 0w-20 works fine at 115F you just get more evap the correct oil will offer more protection that one that is too thick at startup or moreso too thick during use, which is the case of the 5w-40 it appears there is subaru in lebanon http://www.bazerji.com/subaru/sgws/home.html do not return to the shop you took your car to, they have no clue what they are doing the OP needs to get to toyota or subaru 10 second search shows as follows |
#24 |
Drives: Subaru BRZ
There is alot of misinformation being given out in this thread. This article really helps explain what oil you should be using.
http://www.bobistheoilguy.com/motor-oil-101/ |
#25 |
Drives: 2001 Mr2 Spyder
smh.
1. Do not compare weight and viscosity to other different engines. Apples and oranges. 2. 0w-20 can even be used on a track application. Really, has anyone tested it under hard use? I don't think so, but it's not like synthetic 0w-20 can't handle higher temps and provide less breakdown over time as well. 3. 5w-40 MAY be better under hard use, but that is not guaranteed. The properties of the oil MAY be different by additives, brand, etc. 4. Buy your own oil and oil filter and just pay for the labor. That way you get what you want for your given application.
Member of Heya Project for Fr-S/BrZ.
Tire choice, Dash, Options list, Engine, Chassis, Suggestions; My fault Owned N/A '93 Mr2, N/A '91 Mr2, '98 Corolla, Mazdaspeed Mx-5, '07 Legacy Wagon, E90 328i well maintained and lit up on fire while driving on the freeway in traffic. |
#26 |
Drives: '06 AM V8V Coupe
I thought higher oil weight for track use was at best a bandaid for the problem of having oil that's too hot in the first place...
#27 | |
Drives: 2013 HotLava FRS, 2005 Legacy
Seriously, go read this article.
HotLava FRS MT |
#28 |
Drives: Volkswagen Golf GTI
Just a little food for thought.
If STI sells 5W40 oil for the BRZ, I would trust them that it's totally fine. http://www.sti.jp/parts/catalogue/br...8050ST060.html |
| The Following User Says Thank You to Kiwi For This Useful Post: | botbs (08-04-2020) |
