Old 10-19-2018, 03:22 AM   #15
jflogerzi
jflogerzi's Avatar
Yeah I'd take ST coilovers (with a proper set up) over RCE Yellows with old and tired 2013 shocks.
If you can find some new and low mileage 2016 or 2017+ shocks, go for it with the Yellows. The ST coilovers are a fine choice for a basic street set up but with any coilover you'll have to pay a little more attention to set up.
- Andrew
Can you elaborate on "proper setup"
2013 Series 10 FRS #553
Old 10-19-2018, 09:29 AM   #16
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by jflogerzi View Post
Would be nice to find some of the new PP setup. Maybe I will try for those and pair with a set of yellows.
From what I've seen PP shocks are harder to come by and generally people ask a fair bit more than they probably should. Probably not worth the difference vs a low mileage set of '17+ shocks, which are already quite an improvement over earlier cars. I got a set of '17 shocks w/ less than 400 miles for $280 shipped. Likely putting Yellows on for next track season.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 10-19-2018, 11:05 AM   #17
jflogerzi
jflogerzi's Avatar
where did you manage to sang them?
Old 10-19-2018, 11:05 AM   #18
A good alignment (and I mean a GOOD alignment, not factory spec crap) and ride heights set with performance/ride in mind, not just looks.
- Andrew
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
jflogerzi (10-19-2018), Shark_Bait88 (10-19-2018), strat61caster (11-04-2018), Summerwolf (10-19-2018), Tristor (10-27-2018)
Old 10-19-2018, 11:22 AM   #19
Shark_Bait88
In the Suspension FS section of this forum
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Old 10-27-2018, 03:12 AM   #20
jflogerzi
jflogerzi's Avatar
What's a good shop in socal that can do install plus a solid alignment? Anyone have recommendations?
Sent from my ONEPLUS A5010 using Tapatalk
Old 11-03-2018, 06:30 PM   #21
jflogerzi
jflogerzi's Avatar
I just tracked down a almost brand new set of 2017 Dampers off a BRZ with 200 miles for 80$ without top hats. Just re-use my current stock ones. Going to pair it with RCE Yellows and camber bolts up front. Now the question is with the back.
Is it worth it to get some Whiteline LCA to allow for camber adjustments in the rear? I am planing on either Enkie RPF1's in 17x8 ET45 or 949 RACING 6UL 17X8 ET40. I want as neutral of a handling car and figured have LCA will let me get camber dialed in correctly. Rather do everything right since I am saving money rather then getting cheap coilovers. Also thinking of adding a 5mm spacer in front and 10mm spacer in back. I don't like the tucked look when you drop this car with near stock offset. Thoughts???
Old 11-04-2018, 01:31 AM   #22
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Go for the lcas, sounds like you care.
Changing wheel spacings changes handling.
ineedyourdiddly
Racecomp Engineering (11-04-2018)
Old 12-01-2018, 01:54 AM   #23
jflogerzi
jflogerzi's Avatar
@Racecomp Engineering
Can you help recommenced a good alignment spec for my car. Mostly a DD and canyon carver with a few HPDE a year.
RCE Yellow Springs
SPC LCAs
SPC camber bolts for up front
17x8 et40 and 225/45/17 Firestone Indy Hawk tires
Old 12-02-2018, 10:50 AM   #24
RCE Yellow Springs
SPC LCAs
Nice set up!
Front camber: -2.2
Rear camber: -1.8
Front toe: 0
Rear toe: 0.14 in
You might not be able to get -2.2 up front with just your bolts, but max them out and make sure it's even.
- Andrew
jflogerzi (12-02-2018)
Old 12-03-2018, 02:33 PM   #25
steel86gt
Drives: 2018 Steel Toyota 86 GT Black
West End Alignment in Gardena, CA is a reputable shop! Ask for Darin! (310) 808-9233
https://www.yelp.com/biz/west-end-al...vice_attribute
steel86gt is offline   Reply With Quote
The Following User Says Thank You to steel86gt For This Useful Post:
FirstWinter (12-04-2018)
Old 12-03-2018, 05:55 PM   #26
jflogerzi
jflogerzi's Avatar
Nice set up!
Front camber: -2.2
Rear camber: -1.8
Front toe: 0
Rear toe: 0.14 in
- Andrew
Will this cause excessive tire wear?
Old 12-04-2018, 12:47 AM   #27
churchx
churchx's Avatar
Drives: 2014 GT86
HPDE by itself will cause excessive wear. More camber will even wear pattern (and add grip), to not rip just tire outsides on track.
Suggested numbers by RCE are somewhere in between for DD only car (with optimum camber in -1.5 to -1 range) and track (-3+ front, -2.5 rear), just as you asked.
Or if you asked about impact on DD wear .. too slight to care imho. Camber impact on wear is minimal, and of extent to -2.5 shouldn't be noticeable. Excessive toe do wear tires much more, but hence the suggestion by RCE for zero toe front, and slight toe-in rear (some extra stability for acceleration out of corners). Those suggested numbers will also make car understeer less in turns (stock camber is 0, rear -1.1, so more camber front will make it push less).
From my experience, total wear from 5 trackdays was way more then DD wear from whole season. So imho you shouldn't care much about DD wear, but on track with more camber wear will be better . Tires are just consumables, like brake pads & fuel. On track they wear much much faster.
Also one can get two camber bolt set (spc 81305 + whiteline KCA416) for both lower mount holes. Together maxed out worth upto -2.3 at stock height, -2.5 for lowered.
The Following 3 Users Say Thank You to churchx For This Useful Post:
Aluma007 (12-04-2018), jflogerzi (12-04-2018), Racecomp Engineering (12-04-2018)
Old 12-04-2018, 11:33 AM   #28
Depending on usage, you could end up with improved tire wear.
- Andrew
jflogerzi (12-07-2018), strat61caster (12-04-2018)
Koni Yellows + Eibach Springs [OH] RavioliG Brakes, Suspension, Chassis 4 01-14-2017 09:07 PM
Koni Yellows with TRD lowering springs morrisonmagic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 07-09-2016 05:36 PM
RCE yellows vs ST coilovers Euphues Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-20-2015 07:15 AM
FS - RACECOMP ENGINEERING SPRINGS YELLOWS davidsolarbell Brakes, Suspension, Chassis 1 05-29-2014 02:31 PM
