Old 10-17-2018, 05:06 PM   #15
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
My dealer is excellent. YMMV.
PetrolioBenzina is offline   Reply With Quote
Old 10-18-2018, 01:14 AM   #16
Awong124
Drives: 2019 Toyota 86 GT
It is the MAF cleaner. Well documented symptoms. Also totally unrequired. Same as the "de-carboning of the engine intake". If you have carbon build up in your intake you have bigger issues!
I don't know about this specific car, but carbon build up on the intake valves on Audis and VWs is completely normal. Because of direct injection, no fuel runs over the intake valves to clean off the carbon build up. I'm a tech at an Audi dealership, and whenever we do a job that requires removing the intake manifold we almost always recommend a decarb. It can get pretty bad after maybe 100,000 km. I probably wouldn't have recommended it at 27,000 though.
Awong124 is offline   Reply With Quote
The Following User Says Thank You to Awong124 For This Useful Post:
MJones_RB (10-18-2018)
Old 10-18-2018, 02:08 AM   #17
Welcome to the gang -
Just for your information, as mentioned above, the FA20 engine is both direct and port injected, so the port injectors usually take care of most of any carbon that tries to buildup around the valves.
Old 10-18-2018, 02:16 AM   #18
Awong124
Thanks!
2006 Mazda 6 GT V6 MT
2019 Toyota 86 GT MT
Old 10-18-2018, 12:20 PM   #19
LOL
As Hum pointed out this should not be an issue with this engine.
As you pointed out even engines where it is an issue 27K miles is a ludicrous number to say it should be done. Hell, Granny's Impala that never see's over 30MPH could go longer than that.
As I pointed out if you have carboned up the intake on one of these engines you have bigger issues than build up to address.
As a few have pointed out this add on was a totally unnecessary up sell and the sort of stuff that gives all dealers a bad name whether they deserve it or not.
humfrz (10-18-2018)
Old 10-18-2018, 01:28 PM   #20
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
so was this issue resolved besides never going to a dealership for a tuneup
SuperTom is offline   Reply With Quote
Old 10-18-2018, 02:41 PM   #21
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Apparently, it's related to the cleaner used on the MAF sensor. I'm waiting for it to clear itself, and it seems to have reduced slightly. When the engine warms up good, it still revs up when in gear and the clutch is pressed. If it doesn't stop by the weekend, I'll pull the battery cable and reset the ECU to see if that helps.
MJones_RB is offline   Reply With Quote
Old 10-18-2018, 11:49 PM   #22
MrDinkleman
Drives: 2016 Oceanic, "base" model
I'd suggest you check the maintenance guide that came with your car. For my 2013 FR-S, the 30,000 mile maintenance is no big things.
Good. I have 80k miles on my 2016. I recently had the plugs changed but only because I had to take my FRS in to get a new TOB. Yeah, i know the plugs and TOB are unrelated but I figured as long as the car was at the dealership, why not?
Only other maintenance has been oil and filter changes every 4k miles. Oh, and I changed the air filter once.
MrDinkleman is offline   Reply With Quote
The Following 2 Users Say Thank You to MrDinkleman For This Useful Post:
humfrz (10-19-2018), MJones_RB (10-19-2018)
What the hell is this? husker741 BRZ Photos, Videos, Wallpapers, Gallery Forum 27 04-20-2014 04:15 PM
The hell is BMW doing? dem00n Other Vehicles & General Automotive Discussions 39 01-27-2014 12:15 PM
Does your FR-S shock the hell out of you when you get out? ortizwyld Scion FR-S / Toyota 86 GT86 General Forum 58 03-10-2013 12:00 PM
Hell yea!! _F-R-S_ FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-23-2012 09:46 PM
What the hell is this? Wesley Off-Topic Lounge [WARNING: NO POLITICS] 14 10-31-2012 01:49 PM
