Old 10-18-2018, 12:07 AM   #71
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
It moves!
first gear is usesless even with my sticky-ish Federal RSRR tires.
Second gear spins super easy too. Need some 3.55 or 3.73 gears.
Clutch feels soft, need to bleed again perhaps.
Reverse is hard to get into, even with the solenoid deleted, need to check trans fluid.
temp got up to 195*, never heard the fans kick on, need to dig into that.
AC belt jumped a groove, need to check that alignment.
spitsnaugle is offline   Reply With Quote
Old 10-18-2018, 01:10 AM   #72
miffi
Drives: 2016 FR-S
Congratulations! Very cool build!
Did you and Collins get the AC working with the MRS unit?
Sent from my ONEPLUS A5000 using Tapatalk
miffi is offline   Reply With Quote
Old 10-18-2018, 09:43 AM   #73
spitsnaugle
Its being working on. He's waiting on me to finish up the AC lines.
Old 10-18-2018, 11:09 AM   #74
gtpvette
Drives: 2015 FRS - FFR GTM
Excellent news!
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 10-23-2018, 02:56 PM   #75
spitsnaugle
Made its first drive to work today:
Bled the clutch for a third time, and drained/refilled the trans with proper GM MTF, I'm still having some issues with reverse, I can get over to the gear, but cant push up into it without the engine off. I think its signs the syncros or gears are bad. I should have a month of warranty remaining on the trans, going to try to push that issue through asap.
A side note, Though 3/4" is OEM size for a GTO -- I recommend a 7/8" master cylinder over the 3/4" for a firmer pedal and faster engagement. Noting this in my first post for future references.
Old 10-23-2018, 07:58 PM   #76
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Bled the clutch for a third time, and drained/refilled the trans with proper GM MTF, I'm still having some issues with reverse, I can get over to the gear, but can push up into it without the engine off. I think its signs the syncros or gears are bad. I should have a month of warranty remaining on the trans, going to try to push that issue through asap.
I have an "issue" with my clutch. When it's cold, the pedal is really close to the floor. As it warms up, it comes up and behaves great... Have bled it multiple times and have not been able to figure it out. The shop that did my swap did another one with the same master, and the same "issue".
As a side note, the TR6060 factory fluid is GM ATF. I have been using Mobil 1 Synthetic ATF since day one and once the transmission heats up, shifts like butter. While its cold its notchy and a bit crunchy. But I have friends with Camaros and they tell me their transmission behaves exactly the same from factory.
Good note on the 7/8", I might try that.
Old 10-23-2018, 08:06 PM   #77
Sportsguy83
Drives: Limited BRZ
How much firmer? My pedal is super light with the 3/4 master. I am using an OEM LS7 clutch kit.
I do not want a stiff pedal, but it wouldn't hurt it to be a little firmer, so you can get a bit more feedback through it.
Old 10-23-2018, 09:22 PM   #78
spitsnaugle
The M12 T56 was originally Dexron III ATF as well. However according to recent GM TSB's, newer Dexron ATFs are not compatible, stating to use ACDelco Manual Transmission Fluid #88861800.
I have not made the switch the the 7/8ths yet. But back with my LS swapped 240z thats what I had and was the popular choice. There is a step between at 13/16th but I think with as light as 3/4 is, 7/8 would be perfect..
Old 10-23-2018, 10:11 PM   #79
Sportsguy83
Drives: Limited BRZ
Gotcha
Good to know. What clutch are you using?
Old 10-24-2018, 01:11 PM   #80
VR4EVER
Drives: 2013 LS3 FRS, 3000GT VR4, MKV Supra
You wasted no time getting it out and about LOL!
How does it feel weight wise? Similar to stock?
VR4EVER is offline   Reply With Quote
Old 10-24-2018, 03:12 PM   #81
spitsnaugle
OEM replacement by previous owner.
Feels pretty similar. Haven't pushed corners at higher speeds yet, but slower tighter corners are easier to turn with the assistance of the throttle.
Old 10-24-2018, 05:47 PM   #82
spitsnaugle
aaaannd this didnt take long....
I was hoping (since I already had these plug wires) that with ceramic coating the headers, and DEI insulation sleeves, they'd be ok... but after an hour's drive to work, two are toast.
The Fix
Get cut to length spark plug wires.
FAST 295-2422.
fast 295-2423, or something like MSD 32073.
Ideally with 90* spark plug boots.
Then moved the spark plug wires around the the front of the engine, supported them with insulated hose clamp off the head, then go under the headers.
I've since sold my CX headers and customized some Sikky headers to work.
Old 10-31-2018, 11:43 PM   #83
spitsnaugle
Got my new 7/8 master cylinder in... almost.
Installed it, was bleeding the line again and kept getting air from the banjo bolt.
Went to tighten it... and the SOB banjo bolt broke off. So I'm waiting for another 3/8-24 bolt to arrive...
bah humbug.
Old 11-01-2018, 12:24 AM   #84
Sportsguy83
Drives: Limited BRZ
Damn! I'm waiting to hear your feedback on it.
cx racing, ls swap, ls2, pure automotive
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP ILLSMOQ Engine Swaps 172 11-24-2022 07:01 PM
LS2 swap by KAB Customs with Pure Automotive Motec Sportsguy83 Engine Swaps 254 10-17-2018 12:45 PM
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 11:10 AM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 04:21 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
