Old 10-16-2018, 11:02 PM   #1
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Run slightly larger wall in rear?
Hey guys, so I'm currently running Enkei RPF1's 18x9.5 with 255/35/18 tires. My Coilovers are Yonaka Spec 2's (Camber adjustment), and I don't run slammed at all. I noticed recently how much room I have in my rear even with the 18" rim and was thinking of running a 265/40/18 on the back, would anyone be able to chime in and give some advice on running a 40 wall in the back with a 35 in the front? Major issues or just minor difference in the feel of the drive? The ride is raked towards the front the purpose of having room in the back.
Thank you in advance.
scottryan is offline   Reply With Quote
Old 10-17-2018, 07:40 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
Seems like a bad idea. You know 265/35-18 have more sidewall than 255/35-18, right? 255/35 front with 265/35 rear or 275/35-18 rears (a bit more sidewall still) would be a much better plan, I wouldn't even consider 265/40-18 which are more than an inch bigger in diameter vs 255/35
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Leonardo (10-17-2018), scottryan (10-18-2018)
Old 10-17-2018, 09:37 AM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Don't do it. A 265/40/18 is too big of tire. As ZDan has already said, stick to 35 series, if you want to go taller and wider.
This thread has good info on page one about running 265 width.
http://www.ft86club.com/forums/showthread.php?t=41083
I LIKE TIRES!
Old 10-17-2018, 10:02 AM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
That's a pretty large discrepancy front-to-rear. You're talking about a 20% taller sidewall, and a more than 5% increase in circumference, all for only a 4% increase in width.
Let's weigh the pros and cons.
Pros:
- *Slightly* more lateral grip (at the rear only.)
- Improved looks if you like a bit of rake.
- Improved ride comfort (at the rear only.)
Cons:
- Sloppier rear handling.
- Slightly increased propensity for understeer.
- Slightly less controllable rear end at the limit.
- Incorrect speedometer/odometer readings.
- Potential for ABS/TCS/ESC issues due to wheel speed sensor discrepancies.
- Slower acceleration.
- Slower top speed (at stock power levels, since our vehicles are drag limited.)
- Greater unsprung rear mass (I assume the 265 will be heavier.)
- More expensive tire (I assume it's more expensive.)
- Inability to rotate tires front-to-rear to maintain even wear.
- Inability to use spare tire for any length of time if you get a rear flat, seeing as the front tires (which are supposed to be rotated to the rear in the event of a flat) no longer match the rear tires.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Shark_Bait88 (10-17-2018)
Old 10-17-2018, 10:44 AM   #5
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Larger wheels don't fill out your wheel well anymore than smaller diameter wheels, because the difference in tire sidewall evens it out. 18" v 17" will end up with same overall diameter (roughly) when you include the tires.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Stang70Fastback (10-17-2018)
Old 10-17-2018, 10:58 AM   #6
Pros:
Cons:
Your control systems will go insane and mess with you constantly!
scottryan (10-18-2018), tyler_win_photo (10-17-2018)
Old 10-17-2018, 11:35 AM   #7
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Definitely run a 35 series tire. 40 series with a 265 section is way too thick in terms of sidewall. And like others have noted, your TCS is not going to like it.
tyler_win_photo is offline   Reply With Quote
The Following 2 Users Say Thank You to tyler_win_photo For This Useful Post:
Old 10-18-2018, 11:56 AM   #8
scottryan
Financial Distress
scottryan's Avatar
Awesome response, this is why I always consult you guys. I didn't know the sidewall effectively changed from 255 to 265, I'll look into a rear 265, I really don't like the slightly stretched look with my current ones.
The Following User Says Thank You to scottryan For This Useful Post:
Tcoat (10-18-2018)
Old 10-18-2018, 02:32 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
Sidewall height is given in "%" from width, not absolute values. So of course, wider tires with same procentual profile height will have also higher sidewall. While it is not that precise, simplest rule of thumb is when you up one of tire sizing, to keep diameter somewhat same, you lower other tire sizing parameter.
If one wishes for some weird tire choices, eg. for staggered setup (also not advised on these cars, but some go for such for sake of arguable looks and to fit max possible width tires, which is also not advisable), just google for tire calculator and use any of found online calculators to see how similar or dissimilar different sized tires will be.
Leonardo (10-18-2018)
Has anyone tried to replace the rear speakers with a sub and/or larger speakers? soilent Electronics | Audio | NAV | Infotainment 9 12-28-2017 03:48 PM
Slightly stiffer rear sways make a difference??? SwaggFPS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-24-2016 07:48 PM
HIC ROOF Spoiler$100/TRD REAR bumper rep$100/slightly bent Raven hood $100 VakaGT Exterior Parts (Aero, Lighting, Etc.) 16 07-11-2016 01:49 AM
Larger Rear Wheels - Tacky or Acceptable? Orly Scion FR-S / Toyota 86 GT86 General Forum 33 02-28-2010 11:16 PM
