Old 10-13-2018, 04:34 PM   #1
jflogerzi
jflogerzi's Avatar
RCE yellows springs vs ST coilovers
I have a used 2013 frs with 60k miles on the odo. I am looking to lower the suspension just a bit to give it a bit better stance once I get my new wheels. I am wondering if I should byte the bullet and pick up some decent coils vs changing the springs. STs are about 850$ brand new on sale at FT86 speed factory atm. I am just worried the stock strut will go sooner rather then later... And then I will need more work to replace the struts
2013 Series 10 FRS #553
Old 10-13-2018, 06:08 PM   #2
Chuckls
Moutain Runner
at 60k miles I might opt for a coilover. CSG makes a great Tein coilover!
Chuckls is offline   Reply With Quote
Old 10-13-2018, 06:50 PM   #3
jflogerzi
jflogerzi's Avatar
at 1400$ it's a bit out of my range. My car is mostly daily driver, back roads and a few hpde per year.
Old 10-14-2018, 07:46 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
@Racecomp Engineering should have some interesting thoughts on this topic.
Originally Posted by humfrz
I'm old and lazy
Old 10-14-2018, 09:47 PM   #5
jflogerzi
jflogerzi's Avatar
I welcome inputs. If there is a better combo out there I want to know about it.
Old 10-15-2018, 09:27 AM   #6
wparsons
wparsons's Avatar
IMO, spring for new shocks at a minimum. I'd try to find some 2017+ used ones if you can, they're a good deal and better than the earlier shocks.
I wouldn't buy coilovers for your usage, good stock shocks (or bilsteins) and springs sound like a good combination for you.
flickr
Old 10-15-2018, 11:33 AM   #7
Yeah I'd take ST coilovers (with a proper set up) over RCE Yellows with old and tired 2013 shocks.
If you can find some new and low mileage 2016 or 2017+ shocks, go for it with the Yellows. The ST coilovers are a fine choice for a basic street set up but with any coilover you'll have to pay a little more attention to set up.
- Andrew
Old 10-17-2018, 11:39 AM   #8
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
The plain Tein Flex Z can be found for cheaper than the ST coils. Comes with camber plates while the ST's do not.
tyler_win_photo is offline   Reply With Quote
Old 10-17-2018, 12:56 PM   #9
norcalpb
norcalpb's Avatar
I like the ST for it’s superb comfort, but my friends and I have always had our front struts blow with ST. While you send the shock in to get replaced, they don’t give you a temporary shock so your the car will experience down time.
Old 10-17-2018, 04:46 PM   #10
wparsons
wparsons's Avatar
Camber plates aren't good for everyone, so that might not be a plus (other than selling the plates) if they aren't good for the person's usage.
flickr
Old 10-17-2018, 07:44 PM   #11
tyler_win_photo
It does make for an easier install. No having to remove your stock top hat.
Old 10-18-2018, 11:44 AM   #12
wparsons
wparsons's Avatar
A new set of stock top hats are just as easy... point is, camber plates aren't for everyone.
flickr
Old 10-18-2018, 01:24 PM   #13
norcalpb
norcalpb's Avatar
Only if you don’t have proper tools.
To install ST you don’t even need to remove the top hats, just disconnect the stock struts and remove the center strut nut and the whole thing comes out.
It is so worth it to buy a $20 pass through wrench system to use in tandem with an Allen wrench to avoid spinning the strut.
Loosen the upper strut but while it is on the ground to take stress off the nut.
Old 10-19-2018, 02:19 AM   #14
jflogerzi
jflogerzi's Avatar
Would be nice to find some of the new PP setup. Maybe I will try for those and pair with a set of yellows.
Koni Yellows + Eibach Springs [OH] RavioliG Brakes, Suspension, Chassis 4 01-14-2017 08:07 PM
Koni Yellows with TRD lowering springs morrisonmagic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 07-09-2016 04:36 PM
RCE yellows vs ST coilovers Euphues Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-20-2015 06:15 AM
FS - RACECOMP ENGINEERING SPRINGS YELLOWS davidsolarbell Brakes, Suspension, Chassis 1 05-29-2014 01:31 PM
