Old 10-11-2018, 08:22 AM   #1
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
Ohlin's vs. KW V3.
I am currently in a serious debate between these 2 coils for my car.
It is a stage 2 brz used as a DD and auto crossed 1 time a month.
What are the major differences between the 2? Has anyone driven on both setups?
Yes I have searched this topic, but didnt find good usable date.
-B
HeresMyMind is offline   Reply With Quote
Old 10-11-2018, 10:09 AM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
What's a higher priority, DD comfort or autox performance? Are you comfortable test and tuning damper settings and changing spring rates? Are you building a competitive scca car? Just local events for kicks? What kind of tires will you use?
imo neither will be great off the shelf for a competitive autox build, the springs are too soft. There's more potential in theory for the kw v3 because they are double adjustable, but that means more ways to get it set up wrong than right, I've heard that the Ohlins are more comfortable (maybe the most comfortable on this platform) but that may hold back ultimate performance. Sorry no direct experience with either but I've looked at a lot of setups for autox and there's not much off the shelf that's appealing imho. For a dual duty car where autox competitiveness isn't the top priority you'll probably be happy with either depending on where you personally land. If you want a more competitive setup there's other options but some have been successful on re-sprung V3's.
ineedyourdiddly
Old 10-11-2018, 10:09 AM   #3
fatoni
What is stage 2?
Drive upgrades. Don't buy them.
The Following 7 Users Say Thank You to fatoni For This Useful Post:
Boris_Petrov (07-24-2019), brybot (11-01-2018), kch (10-22-2018), SCFD (03-28-2025), strat61caster (10-11-2018), wparsons (10-11-2018), yberther (10-28-2018)
Old 10-11-2018, 10:16 AM   #4
HeresMyMind
Originally Posted by fatoni View Post
What is stage 2?
Just the typical full exhaust with headers and a tune. No boost or e85
Current have konis and eibach pro springs.
Not planning on going crazy and needing clubsport kw’s.
I do plan on running stx in autocross with some 17x9 245/40r17s
-B
Old 10-11-2018, 01:05 PM   #5
Racecomp Engineering
Both are pretty darn good choices and a big step up from what you have now.
1. For the Ohlins, the "new" standard Ohlins spring rates are not my favorite. We HIGHLY recommend customizing the spring rates. We have done this multiple times now with good success and can put together something that would fit your usage well. There is no upcharge from us on that.
2. The KW V3 gives you some tuning flexibility, if you can take advantage of it. Better handling than the standard spring rate Ohlins, but when customized right the Ohlins would have an edge in ride quality and handling.
- Andrew
Racecomp Engineering is online now   Reply With Quote
Turbo (10-11-2018), wparsons (10-11-2018)
Old 10-11-2018, 03:15 PM   #6
Turbo
Drives: FR-S Turbo
- Andrew
Would you recommend 'customizing' the V3's with different springs as well? And would this improve their performance to the level of a properly customized set of Ohlins?
Any thoughts on how the KW V3s would compare to a Japanese shock like the HKS Hipermax 4 SP ?
Turbo is offline   Reply With Quote
The Following User Says Thank You to Turbo For This Useful Post:
DarkPira7e (01-16-2020)
Old 10-11-2018, 03:31 PM   #7
CSG Mike
CSG Mike's Avatar
Off the shelf, the KW are better. The Ohlins need some massaging to really get done right.
It really comes down to, are you willing to learn to use two knobs to optimize the behavior of the car to both street driving and performance driving, or do you want to just "plug and play"?
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Boris_Petrov (07-24-2019), chaoskaze (10-09-2021), Turbo (10-11-2018)
Old 10-11-2018, 03:49 PM   #8
At that point, just get some RCE T2s. They're a custom valved and custom sprung coilover based on KW. The KW V3s potential is more limited since revalves are not really possible (only rebuilds to standard spec).
Have not tried the HKS coilovers. I like some of the specs of both the GT and SP coilovers, but there are a few things that I would change (spring rates on the GT for example, though the dyno plot I saw was solid for a street car and I like the top hats they use). The dyno on the SP was much more aggressive and I would expect a harsher ride over bumps than the Ohlins or KWs.
- Andrew
Turbo (10-11-2018)
Old 10-11-2018, 03:50 PM   #9
Turbo
Drives: FR-S Turbo
In your opinion, how suitable are these two coil-overs for track-driving? And is one better suited than the other, once spring rates are optimized?
Would a change in spring rates improve the KW's performance on this front, similar to how Andrew suggested the Ohlins need? There seem to be a lot of FT86 drivers whose cars see extensive track use with minimal street time.
Up to what level of track-day use/competition do you see the KW's and Ohlins' being a reasonably competitive option?
Old 10-11-2018, 04:43 PM   #10
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Up to what level of track-day use/competition do you see the driver being a reasonably competitive option?
Ftfy.
CSG Mike (10-11-2018)
Old 10-11-2018, 04:45 PM   #11
HeresMyMind
I drive my year round about 13,500 miles. And autocross 7-8 times a year.
I’m looking for something mainly comfortable.
I have eibach and konis but didn’t know if good could would be more comfy as a Daly.
-B
Old 10-11-2018, 04:50 PM   #12
CSG Mike
CSG Mike's Avatar
Parts don't determine competitiveness; the driver does.
The parts should really be used to build a car you are comfortable and consistent driving. In that regard, the Ohlins have a higher upper potential limit, due to the more extensive support available for them.
Unless you are planning on doing multiple rebuilds/revalves to get the exact behavior you want (and already have the knowledge to speak with the folks at Ohlins or a damper shop of your choice such as PSI), you're better off getting something already proven.
Consider a pre-proven, pre-customized option like RCE T2, or CSG FLA.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
bfrank1972 (10-11-2018), Boris_Petrov (07-24-2019), Racecomp Engineering (10-11-2018), wparsons (10-12-2018)
Old 10-11-2018, 05:10 PM   #13
bfrank1972
Drives: 2013 FR-S Argento
Wise words
Old 10-11-2018, 08:56 PM   #14
Turbo
Drives: FR-S Turbo
Yeah, that makes sense.
What about a situation where someone already has a set of KW V3's ready to install (as I do)? Knowing that the valving couldn't be changed later on, what (if anything) would you do on the spring front there? I'll be migrating there from the HKS SP that are on the car now.
It's a track-day car that drives to/from the track and sees a bit of weekend use.
SOLD KWv3 Coilovers with Ohlin Tophats ThatBlueBRZ Canada Classifieds 4 05-08-2016 12:40 PM
KwV3 with Ohlin Tophats 86Tony Canada Classifieds 5 02-09-2016 12:17 AM
