View Poll Results: What name should Toyota use for the production Toyota FT-1?
Supra gets my vote! 367 74.59%
I don't know, but its time for a new name. 125 25.41%
Voters: 492. You may not vote on this poll
Old 10-08-2018, 02:09 PM   #3767
JD001
JD001's Avatar
Drives: Subaru BRZ
I got this feeling that when the "covers" do eventually come off it's going to be a massive let down.. Why I say this? Because the camouflage adds drama to the shape that I think the naked car will lack and it's been over exposed.. UK cars out in July 2019!! What's that about ?
JD001 is offline
The Following User Says Thank You to JD001 For This Useful Post:
mn_ca (10-08-2018)
Old 10-08-2018, 07:33 PM   #3768
gymratter
Drives: BMW
[ame]https://www.youtube.com/watch?v=fXg-b5oSIqU[/ame]
gymratter is offline
Old 10-09-2018, 08:09 AM   #3769
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by ermax View Post
Yeah I’m kind of doubting they were doing it in the 80s with the higher ride and no aluminum. But I can guarantee you they were focused on getting it as low as possible. That’s just what you do when building a sports car.
Higher ride? 80s Corvettes were pretty low... C4 height: 46.7", C7 height: 48.6". C4 also had plenty of aluminum, and composite leaf springs, and weighed 100-200 pounds less than a C7. Already mentioned, c.g. height for the C4 was reportedly 14"!
ZDan is offline
The Following 2 Users Say Thank You to ZDan For This Useful Post:
ermax (10-09-2018), SuperTom (10-09-2018)
Old 10-09-2018, 08:48 AM   #3770
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
On the whole, today's cars are freaking tall. Those stupid ass pedestrian crash regulations necessitate taller hoods, which in turn requires bigger wheels (to maintain proportions). Whole car is higher up as a result. It sucks.
WolfpackS2k is offline
The Following User Says Thank You to WolfpackS2k For This Useful Post:
daiheadjai (10-09-2018)
Old 10-09-2018, 08:58 AM   #3771
ermax
ermax's Avatar
I wasn't implying they didn't use any aluminium at all (although rereading my post I see I left out the word chassis). I just assumed the C4 would be at a disadvantage by not having a fully aluminium chassis, CF roof, hood and floor. I would think the aluminium and CF in the higher areas of the car would give the C7 a big advantage but apparently not.
ermax is offline
Old 10-09-2018, 08:28 PM   #3772
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Huh? Crash regulations dictating hood height? Source?
I’m pretty sure hoods are taller because vehicles are bigger, which is a result of many factors. How tall is the C7’s hood or ours? If there is a standard then it is low.
The C7 has a larger engine, transmission, etc with more modern electronics than the C4. The two are not even in the same league—not in safety, power, performance, braking ability, chassis stiffness, etc. I suppose it sucks that COG and weight were traded for better performance and safety because those two features make a sports car really enjoyable too, but yea, most would prefer the safety and performance of the modern C7.
Irace86.2.0 is offline
Old 10-09-2018, 11:27 PM   #3773
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
http://www.autonews.com/article/2012...ars-due-in-u.s.
So many modders have more cents than sense!
Rampage is offline
Old 10-10-2018, 11:33 AM   #3774
mazeroni
Drives: 2013 Scion FR-S Series 10
The highest part of the engine has to be at least .8 inches in distance from the hood so when the pedestrian hits they don't strike the engine.
https://www.caranddriver.com/feature...fatter-feature
I can't find the actual documents from the NTHSA. I'm not sure if these are regulations that the US shares or if it is just European regulations automakers adhere to since it is cheaper just to use the same hoods.
The LT1 is pushrod so no cams on top, making the engine shorter in height and allowing for the low hood. I don't know the height of the front end, but I think they are comparable.
mazeroni is offline
Old 10-10-2018, 12:00 PM   #3775
Irace86.2.0
Could you name a car that has a hood that comes closer than 0.8 inches of the engine? Because there seems to be plenty of room for strut tower bars and top mounted superchargers in our engine bays. The article seems to just be whining without really giving any concrete numbers or examples. In both articles they kind of say, "Well, haven't you noticed cars are looking boxier...well, it is because of this." Wrong. There could be lots of reasons why the cars look bigger or boxier that have nothing to do with pedestrians and hood clearance.
Some of those reasons could be having a global frame or platform. A large, boxy shape can allow a manufacture to use the same frame for multiple vehicles that are in different classes, but it doesn't make for tight packaging. Another difference is engine size is larger compared to vehicles of the past. Another is vehicle sizes are growing again because oil and gas are relatively cheap compared to inflation. Remember that vehicles of the 70's to the 80's got radically smaller due to the oil shortage and spiking gas prices. And yes, safer vehicles require larger crumple zones, more electronics like airbags, etc, so vehicles have been getting bigger and heavier in general. If you keep adding features and electronics to cars then they need to grow.
Old 10-10-2018, 12:53 PM   #3776
mazeroni
Ah, sorry. I'm merely responding to the question about the height of the hood. All I can say is that EU regulations are X. How struts bars or other additions factor into meeting those regulations would require research that I don't car to do.
Hell, it could be that most cars have always met those standards and the only real change is that market research shows that people like all of their cars to look look like a hulking mass.
But yes, you are right that there are going to be many factors that determine a design of a car that will not be obvious to you or me without someone from a design studio here to share insights into that process.
For example, the Supra is based on BMW's CLAR global architecture (https://en.wikipedia.org/wiki/BMW_CLAR_platform), which underpins the new 3, 5, and 7-series, and X5, X7, X8, etc. So yea, if you ask whether designing a global platform for an SUV might "negatively" influence the shape of your sports car, I'd say you are onto something.
mazeroni is offline
The Following User Says Thank You to mazeroni For This Useful Post:
Irace86.2.0 (10-10-2018)
Old 10-10-2018, 01:12 PM   #3777
WolfpackS2k
Any hard points under the hood have to have a minimum crush space allowed. This even includes the freaking windshield wiper mounts. It's fucking retarded, and if you don't think that automakers would prefer lower, sleeker cars (much more aerodynamically efficient) I don't know what else to say. If you look at almost any new car sold today with this in mind it's ridiculously easy to see how artificially tall hoods are. Just look at the side profile, or at the hood at the base of the windshield. Lots of clearance. Cars have gotten noticeably chunkier and taller over the last 15 years and it is a direct result of these (mostly European) regulations.
This is also why the new ZR1 is not available in Europe.
Old 10-10-2018, 01:53 PM   #3778
Irace86.2.0
I see. And you are right, even the rear height is getting taller for pedestrian safety.
Old 10-10-2018, 01:56 PM   #3779
WolfpackS2k
Sorry if I was short. This stuff pisses me off to no end. The design of most modern cars is just horrible, mostly because of this.
SuperTom (10-10-2018)
Old 10-10-2018, 05:40 PM   #3780
Irace86.2.0
Lol I was kinda being sarcastic with the pic above unless rear pedestrian impacts at high speeds is really a concern. I’m sure the rear of the 911 grew taller because of increasing displacement, coupled with more electronics, a water cooled motor vs air cooled, and better aerodynamics.
bmwforsuckers, boring-zzzzzzzzzzzzz, brz, celica supra confirmed, frs, ft-1, hatch-y +1, morethanucanaffordpal, nomanualnogo, supra, toyota, twins, watstheretailon1ofthose
Toyota FR-S : Official Name for the FT-86 Concept? Dark Scion FR-S / Toyota 86 GT86 General Forum 155 08-04-2010 11:05 PM
