Old 10-09-2018, 05:36 PM   #155
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by ermax View Post
Try double clutching. It will slip right into any gear with zero resistance. Even 1st at 30mph is effortless.
Didn’t work. Literally zero difference, but worth a try.
Old 10-09-2018, 07:58 PM   #156
Timing is the secret -
Old 10-10-2018, 04:24 AM   #157
ermax
ermax's Avatar
Perhaps you aren’t doing it right? Syncros aren’t needed at all if you’re double clutching. Double clutching doesn’t simply mean press the clutch two times.
1. Press clutch
2. Move from 6th to N
3. Release clutch
4. Rev
5. Press clutch
6. Move from N to 5th
7. Release clutch
A normal rev match really does nothing because it only spins the flywheel. By reving in N with the clutch out you are spinning the input shaft and therefor matching the speed of to input shaft to the speed of the output shaft which eliminates the job of the syncros. If you still get a grind then you didn’t match correctly.
Edit: And here is a video that explains it much better than I have. I also left out his first step (lift off the throttle) because I thought that was kind of obvious.
[ame]https://www.youtube.com/watch?v=tescWzTlGQ0[/ame]
Old 10-10-2018, 06:25 AM   #158
86MLR
86MLR's Avatar
Road speed/gearing/RPM
I do it all the time if I'm rolling in a old R series Mack
Old 10-10-2018, 11:34 AM   #159
Irace86.2.0
1. Press clutch
3. Release clutch
4. Rev
5. Press clutch
7. Release clutch
Yep, did it like that. Revving and not revving. It really makes no difference. The only way to make it not grind is to have significantly slowed the car to such a speed that shifting to 5th is not necessary like I could skip to fourth or lower; or to hold the clutch in, and super slowly press the shifter forward to the point of resistance then hold with mild pressure until the shifter resistance lessens, and then press slightly more until it goes into gear, almost like one would do when slowing and waiting for the car to go slow enough to get the gear into 1st. There is no going fast with any technique without the gear/synchro grinding from 6th to 5th on my car.
Old 10-10-2018, 12:31 PM   #160
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
...I assume no one actually uses the same password here as they do their bank or any other website for that matter.
Oooops... you mean I shouldn't use my usual password, "12345," for my banking AND here?
Not sure how I missed this thread.. just saw it today for the first time, read the first post/novelette and page or two, and not sure what to think. Won't watch the video.. life's too short.
FWIW.. I'm at 70K miles on a 2013 and it shifts and drives perfectly. I can't recommend the dealership I bought it from (5 hours south from my place), but the local dealership has been absolutely great. Warranty repairs have been resealing the cam coverplate twice, the timing cover recently, a TSB for window seals, all with no charge and no hint of arguing. Of course, I take it there for routine maintenance, got to know the service manager, and am polite and grateful for their work. They did tell me they didn't feel that replacing the brake fluid at 30K, the diff and tranny oils and plugs at 60K were necessary, but they were more than willing to do it at my request, and did for a reasonable price. Once my warranty wears out, I'll take over the maintenance. It pays to develop a relationship with a good dealership. Yes, in an ideal world, everyone should receive great service at every dealership even if you've never been there before, but walking into one fully loaded for bear isn't the best foot on which to start off, eh?
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following 2 Users Say Thank You to MuseChaser For This Useful Post:
Tcoat (10-10-2018), why? (10-13-2018)
Old 10-10-2018, 12:42 PM   #161
Need to read further. It just keeps getting better and better.
why? (10-13-2018)
Old 10-10-2018, 01:24 PM   #162
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by gravitylover View Post
In the old cars I used to be able to turn them off then put it into 1st and start it moving by using the starter but now you have to put the clutch in or they don't start so that option was off the table.
Tap the signal wires together and you don't have press the clutch anymore
Old 10-10-2018, 01:33 PM   #163
You should know better than to just say that on here.
You need at least a two page DIY with pictures and videos.
why? (10-13-2018)
Old 10-10-2018, 01:36 PM   #164
finch1750
finch1750's Avatar
Might be a bit more then 2 pages. Would have to write up the clutch pedal install first
Old 10-10-2018, 01:39 PM   #165
And don't forget to explain how an electrical circuit works. Three or four times.
Old 10-10-2018, 02:57 PM   #166
ermax
ermax's Avatar
Still sounds like you are not doing it right or not timing it right. You say it's just like 1st were you have to slow enough to get it in gear. I throw mine in first near redline with zero resistance, but only with a double clutch. Otherwise it's like a brick wall until your around 15mph or so.
Old 10-10-2018, 03:05 PM   #167
Why?
Old 10-10-2018, 03:21 PM   #168
ermax
ermax's Avatar
Why?
I will rephrase : I can throw mine in first near redline with zero resistance
But in an autox it's very common to throw it in 1st at 25mph and most cars don't do this well without double clutching.
The Following 2 Users Say Thank You to ermax For This Useful Post:
strat61caster (10-10-2018), Tcoat (10-10-2018)
Recommend a 0W-40 for me please empower-auto Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 07-21-2015 04:08 PM
Can you recommend me what to mod next? l0aded Scion FR-S / Toyota 86 GT86 General Forum 26 08-20-2014 11:40 PM
Anyone personally painted inside of tail light housings? BMHumanic Cosmetic Modification (Interior/Exterior/Lighting) 4 03-11-2013 12:44 AM
Fortune Auto FRS/BRZ coilover kits - Tried and tested personally FreedE Brakes, Suspension, Chassis 15 10-24-2012 11:58 AM
