Old 10-09-2018, 09:53 PM   #49253
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Along those lines, I opted to take the Fiesta out for one last thrashing before handing it over to Ford tomorrow. The drive was fantastic and the car is just as fun to me now as it was when I bought it. Then I got home and the plastic cover on the bottom side of the driver's seat popped off with a cracked clip that I had to glue back together. Sums up living with the car for 3 years quite perfectly. Nothing major ever broke, and the car is a blast to drive, but it constantly had little annoying things falling off or breaking. Almost all of it I could fix myself without much effort.
Fix Or Repair Daily?
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
ScoobsMcGee (10-09-2018)
Old 10-09-2018, 11:22 PM   #49254
Too bad you couldn't have fixed ugly!
humfrz is offline
Sapphireho (10-09-2018), ScoobsMcGee (10-09-2018)
Old 10-09-2018, 11:34 PM   #49255
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Eh, I like how it looks. Doesn't mean I expect anyone else to, nor does it bug me if they don't.
ScoobsMcGee is offline
humfrz (10-10-2018)
Old 10-10-2018, 12:33 AM   #49256
spike021
spike021's Avatar
Well, there's a chance my TOB and/or clutch fork is starting to go. A few months ago I started getting a "tuhtuhtuhtuh" or similar (i don't know how to enunciate in text) if I depressed the clutch all the way, but not all the time. Same thing happened tonight while I happened to be with some 86 guys down here, and they think it's clutch-related.
I think 2017+ are supposed to have a better one?
Unless I just put more stress on it the first 4 or so months learning to drive manual properly..
Instagram: @spike.grc
spike021 is offline
The Following User Says Thank You to spike021 For This Useful Post:
humfrz (10-10-2018)
Old 10-10-2018, 12:39 AM   #49257
Yep, she's a beauty fer sure -
(I'm jest ah messen wich ya - )
humfrz is offline
ScoobsMcGee (10-10-2018)
Old 10-10-2018, 12:53 AM   #49258
If it just squeaks while pushing it in or letting it out, with or without the engine running, it may be that just the clutch fork is dry. Several fixes have been posted to quiet it down (basically, lub it).
I doubt that your "learning curve" with the clutch, caused the TOB undo stress. Maybe the clutch disk took a beating, but they don't usually make noise unless they are worn out or are coming apart.
So, can the noise be heard if the engine is running but the clutch is NOT engaged?
How about when the engine is running and the clutch IS engaged (pedal pushed to the floor)?
How about a video/audio -
humfrz is offline
spike021 (10-10-2018)
Old 10-10-2018, 01:29 AM   #49259
spike021
spike021's Avatar
I'll try to take a video/audio another time.
As far as squeak while pushing in/letting out, yeah I've gotten that at times, but not all the time.
Nope, usually it's when I've started the car and then engage the clutch. When it happens I feel like it happens more often within the first half hour or half mile since the car's turned on. But can also happen later than that from stops.
spike021 is offline
Old 10-10-2018, 02:09 AM   #49260
How many miles on your car?
So, when you push in on the clutch and start the engine, does it make that sound (not the squeak, but the other sound) or does it just make the sound when you let up on the clutch pedal?
Calling on all clutch/TOB experts, we need a little help here -
humfrz is offline
Old 10-10-2018, 02:18 AM   #49261
spike021
spike021's Avatar
Just passed 18k the other day. When I start the car, it doesn't happen right at that moment. But once I depress the clutch fully to shift into gear, then it does the sound. It stops when I let up on the pedal past the bite point.
spike021 is offline
Old 10-10-2018, 06:33 AM   #49262
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
just get a loud exhaust and you won't have to worry about it anymore. these cars are so noisy I had to put a stop to it.
echo419 is offline
The Following User Says Thank You to echo419 For This Useful Post:
Old 10-10-2018, 06:55 AM   #49263
AnotherSlowAE86
AnotherSlowAE86's Avatar
Drives: Subaru BRZ and AE86 coupe
I used to drive a Fiesta ST. Loved that car, but the small interior space wasn't cutting it.
Build Threads:
1985 AE86 Coupe /// 2014 BRZ Limited (soon.. gathering pictures)
AnotherSlowAE86 is offline
Old 10-10-2018, 09:39 AM   #49264
ScoobsMcGee
I never felt cramped, but at 6'1" the top of the driver's seat back was definitely behind the B pillar. Probably looked pretty silly from the outside.
Hey now, that red pinstripe was hand drawn! I even paid extra to have my initials written along the pinstripe at the back of the doors.
humfrz (10-10-2018)
Old 10-10-2018, 11:01 AM   #49265
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I must have missed this piece of info when looking at coilovers.
Fortune Auto Coilovers are designed and assembled in Richmond VA.
I'm a HUGE fan of MADE in USA!
And, I thought I had made up my mind on what I wanted... Back to researching....
I LIKE TIRES!
Leonardo is offline
Old 10-10-2018, 11:07 AM   #49266
Fortune Auto Coilovers are designedand assembled in Richmond VA.
Find out where the components are MADE. Wording is everything here.
Tcoat is offline
Leonardo (10-10-2018), Teseo (10-10-2018)
