Old 06-03-2015, 11:28 AM   #15
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
Same one on mine came cross threaded from the factory. I just snapped it off since I had all new parts. Then made my way to the o2 sensors since I was putting on my OFH, one of those was also cross threaded from the factory as well so, had to get a new o2 sensor. Really sad considering that's how it came from the factory.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
Old 06-04-2015, 02:04 AM   #16
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
That shit happened to me too, at the exact same location, probably an over tightening from the factory.. But I cut it off, then drilled it out with pure titanium drill, then just replaced the bolt and nut
Good luck..
Teclis is offline   Reply With Quote
Old 06-04-2015, 02:32 AM   #17
Hotrodheart
Hotrodheart's Avatar
No choice, sell it.
Hotrodheart is offline   Reply With Quote
Old 06-04-2015, 01:23 PM   #18
BBYZILA
BBYZILA's Avatar
Drives: 2013 Firestorm FR-S
update: i brought it to a shop, they welded a head onto it, heated it up, took it out, along with the threads , so they retapped it to a bigger diameter, and then just put in a new bolt and nut. Also charged me 70$. lesson learned...
going to get my headers professionally installed.
BBYZILA is offline   Reply With Quote
Old 06-04-2015, 01:36 PM   #19
civdaddy
Drives: Slow
Don't count yourself out. Maybe you just need a better collection of tools to make the job easier? Having be right combo of sockets, wrenches, extensions, ratchets ect, can make the job much easier.
civdaddy is offline   Reply With Quote
Old 06-04-2015, 11:20 PM   #20
troek
troek's Avatar
Drives: 2012 Toyota 86
stripping a bolt was either incorrect wrench size, cheap wrench, or a bolt that was so stuck, something had to give. i think you can tackle the header your self, its pretty straight forward.
troek is offline   Reply With Quote
Old 06-05-2015, 12:04 AM   #21
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Six point sockets. Every time.
Thedishdoc (03-08-2019)
Old 06-05-2015, 12:12 AM   #22
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Originally Posted by NOHOME View Post
There is an app for that...
dafuq is that tool??? I messed up some nuts (weather/me over tightening 'em) and cant seem to get them off! Thats a bad@ss tool.
Old 06-05-2015, 12:36 AM   #23
bcj
Geo Tyrebighter Esq
bcj's Avatar
Nut Splitter
Similar but different
Old 06-05-2015, 12:45 AM   #24
Packofcrows
Ordered the one in vid off of e-bay. $15 w/ shipping. I'll let you guys know how it is when it gets here!
Old 06-05-2015, 10:11 AM   #25
NOHOME
Drives: RAVEN
google up "Nut Breaker" and you will find a ton of examples. Pretty cheap at the discount tool places, I paid like $15 for the ones I have. They come in a few sizes.
I do a fair bit of Brit car restoration and between heat and these things I manage to get most things apart without breaking them.
The person who posted "cheap wrenches or wrong size wrenches was also right
NOHOME is offline   Reply With Quote
The Following 3 Users Say Thank You to NOHOME For This Useful Post:
Packofcrows (06-05-2015), Thedishdoc (03-08-2019), troek (06-05-2015)
Old 10-07-2018, 01:00 PM   #26
dutchman1
Drives: 2017 86 6-Speed
Glad you got it taken care of, if you don't have the tooling it's probably no t cost effective to do it yourself.
For future reference, there's really about a hundred things you can do. There's really no magic way to get stuck hardware apart without effort, you just have to be more stubborn than the thing you're trying to get apart.
In your situation my first attempt would be to heat the nut up red hot (concentrate the heat on the nut, not the stud), and then put some vice grips on the nut and it should spin right off. The heat will expand the nut causing it to loosen. Rather than vice grips, you can also take a pointy chisel or punch, and try to hammer the nut in a circle. Hit the face of the flat kind of close to a point in the direction you want to turn the nut. You'd be surprised how effective that is, if you can get a good swing at it, it acts like an impact.
If you have a good socket selection, you can also sometimes hammer on a 12 point socket, one size smaller (metric or standard, whatever fits) and grab the nut that way.
You can also take a die grinder with a burr or cutting disc (whatever fits), cut the thing off, and then drill the stud out of the header flange.
As said above, in terms of not rounding it to begin with, wrench quality is important here. Better wrenches have much tighter tolerances and harder steel so they flex less, plus they are designed to grab the flats of the hex rather than the points. This is why you see the pro guys shelling out $500+ for a set of wrenches from sk/armstrong/snapon/whatever.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 10-08-2018, 02:04 PM   #27
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
I bought these from Amazon and they saved my butt a few times already.
MJones_RB is offline   Reply With Quote
Old 10-08-2018, 02:15 PM   #28
ermax
ermax's Avatar
I'm trying to understand what you stiped. First of all there is no "bolt". The overpipe has a threaded hole in it. There is then a threaded stud which screws into the overpipe. Then you have a nut that screws onto the stud. So which is stripped? The nut, the stud or the overpipe itself? If it's the nut, replace the nut. If it's the stud, replace the stud. If it's the overpipe then drill it out and replace the original stud/nut with a bolt and nut.
Here is the stud:
https://parts.toyota.com/p/STUD-BOLT...U00301117.html
Edit: Nevermind, I see you took it to a shop.
bolt, front pipe, head, over pipe, stripped
Greddy Evo 3 Front Pipe Connection Pic Request mad_sb Engine, Exhaust, Transmission 10 05-24-2017 09:41 PM
P/N for Front Pipe Hanger Bolt DarkSunrise Engine, Exhaust, Transmission 2 07-01-2015 12:47 PM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 01:42 PM
What is the difference between a Front pipe, a down pipe and an over pipe? liajet24 Engine, Exhaust, Transmission 5 09-19-2013 10:03 PM
