#4691 |
Drives: 2017 BRZ (Sold), 2023 GR86
Is the C30 with the HBP a risky setup longer term? Using 96% of the unit's capacity has me worried for track use. I can't use the C38 since I don't have E85 and won't have a built engine.
It sounds like I can safely run the HBP on 92+ with the C30 when using an Ace header, but I still want to be sure I'm not placing unnecessary stress on the Rotrex unit. |
#4692 | |
pessimistic skeptic
#4693 |
pessimistic skeptic
I installed four clamps on both ends of the two hoses connected to the solenoid under the intake manifold. The difference is huge. Power and even mpg are noticeably better. Check the following thread. I should have done this when I installed JRSC in 2016.
https://www.ft86club.com/forums/showthread.php?t=109444 With a new MAF sensor (probably, o-ring replacement would have been sufficient) and the clamps, P0172 is completely gone. My engine is singing again. |
#4694 | |
My main concern is longevity of the Rotrex itself given that it’s being used at almost full capacity. Does the redline remain at 7400? |
#4695 | |
Drives: 2014 BRZ
To answer your question though, it depends on what you consider as 'risky'. Yes, you'll wear out the C30 faster. How much faster? I don't think anyone can answer with any certainty.
#4696 | |
Drives: 2017 toyota 86
I believe you can have the redline set to whatever you want. Although most people don’t go above 7600. With boosting stock motor probably don’t want to rev past 7400. But again Some people blow the motor NA or on super low boost. Some people are runnng 14psi and going 50k miles Strong. But the more boost the greater the risk and chance of blowing up your motor. Generally 8psi is considered the top ending of “safe” on stock internals. |
#4697 |
Drives: 2016 brz
FYI: Currently on JRSC C38 with 700cc injectors and DW65c fuel pump; stock internals and ceramic coated ft86 speed factory catted UEL header. Manual transmission redlining at 7690 (140km/h) on third gear pull (according to logs). I believe I once saw it redlining at 7890 but could not find the log. So... No problems other than loss of boost due to altitude (5250ft above sea level) and high oil temps (110 - 120C with spirited driving). PS: Ceramic coating the header helped quite a lot with engine bay temps.
Best. |
| The Following User Says Thank You to kowalski For This Useful Post: | mistople (10-07-2018) |
#4698 | |
#4699 |
Drives: Fast track beast
How does water/meth factor in getting more reliable power?
Sent from my SM-G965W using Tapatalk |
#4700 |
So you’re saying assuming everything is setup correctly and tuned properly there is absolutely zero risk to boosting even 9+ psi on stock internals? And Not an inverse ratio of more boost to lower average life expectancy of the motor?
You’re saying if I have 100 NA motors, 100 boosted at 8psi, and 100 boosted at 12psi they will all last the same amount of time on average? Each group will have the same amount of pre mature failures and same amount hitting 200k+ miles with no major issues/failures? |
#4701 | |
Drives: Q5 + BRZ + M796
Take Edelbrock. The stock kit comes with a pulley that greatly exceeds 8psi and the powertrain can potentially be warranteed for 30k miles or something. Hardly playing with fire or Edelbrock is insane.
#4702 |
Is the air filter that comes with the kit supposed to be dry or oiled?
#4703 | |
Drives: 2013 Subaru BRZ Premium
Sent from my XT1650 using Tapatalk |
#4704 |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
