Old 10-06-2018, 12:34 PM   #127
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
Nice parts! When I look at this thread the JDM Revolution 86 comes to mind.
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
The Following User Says Thank You to Raven86Project For This Useful Post:
SuperTom (10-06-2018)
Old 10-06-2018, 04:42 PM   #128
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Just looked that up I see the visual resemblance. Cant find any info on the build though.
SuperTom is offline   Reply With Quote
Old 10-06-2018, 06:20 PM   #129
Raven86Project
It weights 2173lbs (988kgs)
IG: raven86project
Build Thread HERE
The Following 2 Users Say Thank You to Raven86Project For This Useful Post:
korhun (12-19-2019), SuperTom (12-08-2019)
Old 10-06-2018, 07:23 PM   #130
SuperTom
SuperTom's Avatar
Thanks so much that's awesome! I doubt I can get that low without stripping the interior. I think ill be happy with it streetable at 2300
Old 10-07-2018, 05:03 AM   #131
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
Love your dedication!
Vin is offline   Reply With Quote
The Following User Says Thank You to Vin For This Useful Post:
SuperTom (10-14-2018)
Old 10-17-2018, 06:39 PM   #132
SuperTom
SuperTom's Avatar
Finally had nice weather on a day off to complete one of the doors. Took me most of the day to transfer everything over. I believe I can cut a lot of time out when I do the passenger side.
Had a few holes for clips I had to open a bit with a Dremel. But most important was the overall fitment was perfect!!
Bolted up the first time no adjustments made
Getting close to sunset finished in time
Stock door was heavy as fk. Not 50lbs I had heard, my scale says 43lbs stripped
So after I get the passenger side done this will be good for 64.5lbs weight reduction off the car.
Side note one of the bottom window stoppers is a big heavy piece of steel. I could easily make it out of aluminum and chop another pound off each door.
New car weight should be ~2375.25!
The Following User Says Thank You to SuperTom For This Useful Post:
Clipdat (10-19-2018)
Old 10-17-2018, 11:53 PM   #133
EdBoy
Driver
EdBoy's Avatar
Drives: 16 Subaru BRZ
good stuff, you going to paint match the doors or just leave them be?
BRZ Build Thread
See you space cowboy...
EdBoy is offline   Reply With Quote
Old 10-18-2018, 12:08 PM   #134
SuperTom
SuperTom's Avatar
Yeah most likely going to paint match everything. Still considering dry fenders, hood, roof first. I may leave the roof carbon, but yeah not doing this for the carbon look
Old 10-19-2018, 01:08 AM   #135
EdBoy
Driver
EdBoy's Avatar
good deal, the doors worth the price?
BRZ Build Thread
Old 10-19-2018, 02:23 AM   #136
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Paint is heavy, leave them unpainted for weight savings!
Originally Posted by humfrz
I'm old and lazy
SuperTom (12-03-2019)
Old 10-19-2018, 08:04 AM   #137
SuperTom
SuperTom's Avatar
Got lucky and happened to be browsing the Siebon site some of their dry parts were heavily discounted. Plus a found a great online code got both the trunk and doors for ~$3k shipped. They may have been selling off stock I don't see them listed anymore, only the wet which is much heavier and more for looks
Old 10-19-2018, 08:05 AM   #138
SuperTom
SuperTom's Avatar
You are so right what the hell was I thinking
HachiRokuX (12-31-2018)
Old 10-24-2018, 02:18 PM   #139
SuperTom
SuperTom's Avatar
Finished passenger side a few pics of the inside. Also removed these black heavy chunks of steel from inside the door. I thought they may be a window stopper but after moving the windows up and down they do nothing that I can see -1 Free pound!
Everything swapped
Finished!
Heavy chunks of steel 1/2 lb each
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
Clipdat (12-07-2019), new2subaru (10-24-2018)
Old 10-24-2018, 02:21 PM   #140
SuperTom
SuperTom's Avatar
Also have a new weight loss mod im going to be working on will take my time. This sucker is heavier than I expected. Got a used Dash bar for $100, it weights 17lbs. Going to swiss cheese the FK out this thing!
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 06:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 03:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 02:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 08:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-02-2013 12:45 AM
