Old 09-30-2018, 12:31 PM   #19671
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
Yesterday I helped my buddy replace the sparkplugs in his 2015 WRX. This wasn't exactly my FR-S, but it's close enough since it also has the FA20 with a few minor differences. This goofball was still running the original plugs at 95,000 miles. I guess he didn't get the memo that they're supposed to be replaced every 60k...
I managed to do it without jacking up the engine and only got one bent fingernail and two bloody knuckles. To be honest the FA20 in the WRX sits up a bit higher than the FA20 in the FR-S/BRZ/86 (probably due to the AWD system), so that's probably why lifting the engine wasn't required. It was good practice for when I have to replace my sparkplugs in about 9,500 miles.
Face_Plant is offline   Reply With Quote
The Following User Says Thank You to Face_Plant For This Useful Post:
humfrz (09-30-2018)
Old 09-30-2018, 08:59 PM   #19672
notout86
Drives: GTS 86 auto
Originally Posted by FRShFA20 View Post
I'll look into that. Thanks. Even with all the ceramic, tape, and blanket, the engine bay still gets hot.
Sent from my SM-G935P using Tapatalk
While you are at it, shield your battery too.
GTS86 Auto (Australia)
Old 09-30-2018, 09:02 PM   #19673
notout86
Drives: GTS 86 auto
Originally Posted by Face_Plant View Post
Today I installed the one piece center dashboard trim thingy (not sure what the proper name is) from the 2017+ 86/BRZ. It's a huge upgrade over the ugly two piece plastic trim that my car came with.
It does look classier. Makes you wonder why it was in 2 pieces originally.
Old 09-30-2018, 09:09 PM   #19674
notout86
Drives: GTS 86 auto
Originally Posted by mrderp View Post
Cleaned up my shed full of Nissan S14 parts. Threw away spare parts that were water damaged beyond repair.
Compared the OE exhaust from 2014 and the one from a canadian manual 2017.
Except for the flanges and tips being different everything else is exactly the same.
was the Nissan S14 a 200SX with o.e. turbo? I kinda regret selling mine after 20 years and going to the Toyota 86.
Old 09-30-2018, 09:24 PM   #19675
notout86
Drives: GTS 86 auto
Google for a Youtube on how to do the '86 without lifting the engine. I found one recently. Couldn't ToyoBaru have included access panels/holes?
Old 10-01-2018, 03:02 AM   #19676
Face_Plant
Face_Plant's Avatar
I bet they planned to make it ugly on purpose for a few years then update it so they could get people to trade in their older FR-S or BRZ and drop the dough for a new one.
Access panels or holes would probably comprise the rigidity of the front of the car. I haven't looked at my engine in a while, but from what I remember the cylinder heads are right in line with the frame rails, whereas on my friend's WRX the engine sits up an inch or two higher, making the sparkplugs easier to access. I know it's possible to change them without lifting the engine, but unbolting the engine mounts is as simple as removing two nuts, then you're free to lift the engine a few inches for easier access. This is probably the route I'll take for less cursing and fewer bloody knuckles.
Old 10-02-2018, 05:31 PM   #19677
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I added a drop light with 6 foot cord that is fused and has a switch. It is a small strip of LEDs that I put in a piece of 1/2 pex tube. I can look under hood, under the car, and waive it around if I need help. (let's hope I don't)
And, NO its not on while I'm driving.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Astroboy (10-02-2018), humfrz (10-02-2018)
Old 10-02-2018, 05:51 PM   #19678
Ashikabi
Ashikabi's Avatar
But could it be?
Old 10-02-2018, 05:58 PM   #19679
Leonardo
Country Boy 4 Life
Leonardo's Avatar
But could it be?
Sure, I used a cord like pictured below. So, you would have to pop the hood, turn the light on, shut the hood, and then drive around. The light will stay on till you spin the switch again. Shutting the car off won't shut the light off.
I thought about wiring it to a pressure switch, so it would turn on if the hood opened. But flipping the switch is easy, so I wired it with a standard switch instead.
I LIKE TIRES!
Old 10-02-2018, 06:10 PM   #19680
Hypnocracy
Hypnocratic Missionary
Hypnocracy's Avatar
Visited the Toyota Dealership to program my OEM replacement key....$250ish for key & $110 service charge...
Found a second set of rims on Craigslist local...Picked up these Kosei K1-TS wheels $250 (CHEAP)
Went to Discount Tire for Conti's...mounted them on said Kosei wheels...while busting one center cap $600+
Found the last two refurbished Kosei Center caps on the interwebs for $18 each.
Hypnocracy is offline   Reply With Quote
Old 10-02-2018, 06:23 PM   #19681
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
good find id love to find a set of those. Cheap, Light
SuperTom is offline   Reply With Quote
Old 10-02-2018, 08:14 PM   #19682
dnieves
Drives: FR-S 10 Series
Dropped 10 Series off with Cadillac dealership bodyshop to fix a ding (PDR) and a scratch from some Hyundai owner suddenly losing a part from his POS on the Long Island Expressway.
dnieves is offline   Reply With Quote
Old 10-02-2018, 09:33 PM   #19683
Well, Leonardo, that's nice - but what do you use it for -
Old 10-02-2018, 10:16 PM   #19684
_kongzilla_
Drives: Raven FRS
Canards
_kongzilla_ is offline   Reply With Quote
The Following User Says Thank You to _kongzilla_ For This Useful Post:
LeonardoDaVinny (10-14-2018)
