Old 09-30-2018, 08:57 PM   #29
dpaqu
Drives: 2018 Gt86
What data elements does the logging function capture from our cars over the CAN/OBD? Throttle position/brake pressure, steering angle?
Edit: So this little thing will capture all these parameters(from another AIM threat) and overlay it with GPS coordinates, G force data and video? Wow. Wish it worked.
  • RPM
  • Vehicle speed
  • Pedal position sensor
  • Brake pressure
  • Steering angle
  • Brake switch
  • Engine Coolant Temperature
  • Intake air temperature
  • Manifold air pressure
  • Ambient Air Temperature
  • Barometric pressure
  • Lambda value
  • Throttle position
  • First Catalyser temperature
  • Clutch switch
  • Front left wheel speed
  • Front right wheel speed
  • Rear left wheel speed
  • Rear right wheel speed
  • Oil temperature
  • Engaged gear
dpaqu is offline   Reply With Quote
Old 09-30-2018, 10:58 PM   #30
redlined600
redlined600's Avatar
Drives: Fr-s
  • RPM
  • Vehicle speed
  • Brake pressure
  • Steering angle
  • Brake switch
  • Lambda value
  • Throttle position
  • Clutch switch
  • Oil temperature
  • Engaged gear
To be fully integrated it would require an aim smarty cam.
redlined600 is offline   Reply With Quote
Old 10-01-2018, 08:22 AM   #31
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
  • RPM
  • Vehicle speed
  • Brake pressure
  • Steering angle
  • Brake switch
  • Lambda value
  • Throttle position
  • Clutch switch
  • Oil temperature
  • Engaged gear
The firmware update for our cars now has it capturing all of the data promised. Mine works great now (cough, took forever, cough).
Joesurf79 is offline   Reply With Quote
The Following 3 Users Say Thank You to Joesurf79 For This Useful Post:
CSG Mike (10-02-2018), redlined600 (10-01-2018), Sleepless (10-01-2018)
Old 10-01-2018, 08:03 PM   #32
dpaqu
Drives: 2018 Gt86
Does the software package it in a way that you can use it without a engineering degree? What have you learned using it?
The Following User Says Thank You to dpaqu For This Useful Post:
Joesurf79 (10-02-2018)
Old 10-02-2018, 02:48 AM   #33
CSG Mike
CSG Mike's Avatar
What you get out of the data is purely up to you. All it is doing is giving you the information you collected. You have to interpret it.
At a basic level, look at your speeds. From there, you could go into all sorts of detail.
PM me to order an AIM.
Old 10-02-2018, 07:06 AM   #34
Joesurf79
Joesurf79's Avatar
There's plenty to gain from it if you 1) are consistent 2) have data from someone else to compare to on screen. It helps if they're in a similarly prepped car of course, but looking at the data traces side by side, you can see if the other person is breaking earlier, later, on the gas sooner, feathering the throttle or not, what their speed is through a corner and if they are exiting at a higher speed.
CSG mike is correct that it just collects data, the interpretation is up to you. But once you have aim data to share and others share with you, you can start to make some general judgements on where you're losing big chunks of time looking at your lap on screen side by side compared to others. The key is that you need to be experienced enough to be consistent lap to lap, or else your changes will just get lost in the noise.
Check this book out if you're willing- it's a great primer on this topic. https://www.amazon.com/Practical-Gui...words=bob+knox
Old 10-03-2018, 05:10 PM   #35
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Spend a couple hours on James Colborn's channel and you'll be a pro at analyzing data with Race Studio. He's a brilliant racer (a brilliant man) and his videos are well put together for learning how to get the most out of the software.
https://www.youtube.com/playlist?lis...8iHBjjNDnCNCTf
Make sure you are using the data for good and not bad.
What I mean by that is:
Good: Data illustrates bad behavior or poor car setup. It can be used to identify talent gaps or help you understand why that thing you think is fast, is actually slow.
Bad: The data says your car has a 1:39 in it when you're doing 1:43s so without any car or driver development you just go out to do 1:39s and run into things or other people.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
CSG Mike (10-03-2018), gkubed (02-02-2019)
Old 10-10-2018, 11:55 AM   #36
dpaqu
Drives: 2018 Gt86
Thank you for the book recommendations. Looks like it's going to be intense. The videos are excellent and pretty accessible. The gps overlays of his different lines when he overcooks a corner are illustrative.
Does this thing have any engine diagnostic uses? Can I add oil pressure logs to it?
Edit- answered my own question again. It can't. Need an Aim MXL or something. The rabbit hole gets deep quick with brake pressure monitors, tire and brake temp sensors ect.
Old 10-10-2018, 12:32 PM   #37
Code Monkey
Drives: Subaru BRZ
Ok, the intermittent rebooting/flickering is solved now once I got the 86Nanny installed. When I did the pedal dance and had to turn the car on and off a couple of times with the Solo DL hooked up to the OBDII port, the Solo got confused I guess.
The only problem with the Solo now is that it stays powered on when the car is shut off even though I think I have it set to a 5-minute shut off. If I shut it off manually, I come to the car later to find the Solo turned on by itself, wtf.
Code Monkey is offline   Reply With Quote
Old 10-10-2018, 02:20 PM   #38
CSG Mike
CSG Mike's Avatar
Sounds like the OBD2 port connection is still shaky, and when a connection is detected, the Solo powers on.
Old 10-10-2018, 03:20 PM   #39
Code Monkey
Drives: Subaru BRZ
It cannot be shaky because the Solo works fine during a super shaky session and then the car is parked/stationary with no movement whatsoever.
The 86Nanny OBD connector is firmly on, if it were not, my guess is that all the nannies would turn back on. The Nanny OBD port extension is also solid, I have to wiggle the Solo OBD connector a bit to uncouple it from the Nanny extension.
Old 10-13-2018, 02:35 PM   #40
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
I have this issue as well. The power on and auto power off are inconsistent so I always manage manually and always disconnect from the OBD2 port on the 86nanny when done. I have the Smartycam HD as well and the two together will drain the battery easily overnight. This is with the v1 Solo to be clear.
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
Code Monkey (10-13-2018)
Old 10-27-2018, 10:37 PM   #41
redlined600
Drives: Fr-s
Anyone willing to share some data with can channels with me so I can get some familiarity with the software over the winter?
Old 10-28-2018, 11:20 AM   #42
Code Monkey
Drives: Subaru BRZ
Shit still not working the way it should for me. With the 86Nanny, AiM sometimes turns on when I start the car, sometimes it does not. The SmartyCam turns on when the AiM turns on automatically, but when I have to start the AiM manually, the SmartyCam does not turn on automatically, I have to press the power button.
Yesterday the AiM worked for the first two hpde sessions, then it shut off in the middle of the third session and the SmartyCam stayed on.
Very frustrated with the setup.
The Following User Says Thank You to Code Monkey For This Useful Post:
dpaqu (11-08-2018)
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
First FR-S in Ottawa Solo2 Event Klinn CANADA 0 06-12-2012 11:13 AM
