Old 09-28-2018, 11:20 PM   #1
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
OFT trouble uploading tune to Tablet
Ok i'm sure I'm missing something simple. I have completely upgraded my computer. it's a custom AMD Ryzen2 all water cooled but I saved all my tunes reinstalled romraider because I'm been running Wayno's v124 E85 tune all summer and I was about to change back to 93oct gas I got my tablet out i took almost 30 min to undate it when I hooked it up to my computer decided I was going to run a different tune than before and it just won't upload to the tablet. I have the v124 e85 tune in the 3rd position and 93oct tune in the 5th position I was going to go to a 91oct tune and it WILL NOT UPLOAD. It jst says invalid check sum.
oldgunfan is offline   Reply With Quote
Old 09-28-2018, 11:52 PM   #2
steve99
Drives: FT86
sounds strange
just check vehicle selected is brz/86
make sure the tune your trying to upload is same calid as your original tune stored in oft, also make sure in not zipped, it should be 1.2mbytes and be a .bin file
oldgunfan (09-29-2018)
Old 09-29-2018, 12:27 AM   #3
oldgunfan
oldgunfan's Avatar
Ok i have reinstalled openflash manager 1.35 nothing changed. when I tell it what file I wan't in say the 4th position and say ok. a box opens up that says C:\openflash\dll\dev121.dll I can only say ok than a box opens up and just says 1 and all I can do is say ok. then it gives me the invalid check sum message.
Old 09-29-2018, 12:38 AM   #4
oldgunfan
oldgunfan's Avatar
sounds strange
The tablet says CaL ZA1JB01C and i'm using b01c tunes.
Old 09-29-2018, 07:21 AM   #5
steve99
Drives: FT86
Ok last shot
Try turning off antiviruis while uploading tunes if still no go
Go to fhe C:\openclash directory and delete it and all files under that directory.
Make sure you move or save any tine files you may jave somewgere different first.
Then go to the openflash support site and manually downlod the openfladh manger softwsre and ibstall again
https://support.openflashtablet.com/...Hux6CfB4xlw%3D
https://support.openflashtablet.com/...ted-9-19-2018-
Old 09-29-2018, 11:15 AM   #6
oldgunfan
oldgunfan's Avatar
Ok last shot
Ok so I did everything you suggested, I even cleaned windows I still get a box with CKTRL than below that it says C:\openflash\dll\dev121.dll then an ok button then you get invalid checksum message.
Old 09-29-2018, 12:14 PM   #7
elBarto
elBarto's Avatar
Drives: Toyota GT86
Ah yes, the good old DEV121.dll error, still in existence.
I had the same problem, I was lucky that a big update fixed the problem for me.
Other option is reflash to stock, wipe the tablet and restart from scratch
http://www.ft86club.com/forums/showthread.php?t=127456
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following User Says Thank You to elBarto For This Useful Post:
Old 09-29-2018, 02:28 PM   #8
oldgunfan
oldgunfan's Avatar
my oft shows HW-2.35 FW-1.53 So I guess i need to flash the stock tune and unmarry the oft than wipe it??
Old 11-01-2018, 05:16 PM   #9
AP756
Drives: GT86 Toyota
Life can be hard . The procedure is quite easy (thanks elBarto to link to the old thread) and best of all it works- Good luck
Bye for now Fred (AP756)
AP756 is offline   Reply With Quote
openflash tablet vs ecutek tune brz23 Software Tuning 104 07-28-2020 05:36 PM
tune not uploading TooFRSh Software Tuning 18 12-18-2017 04:32 AM
Local tuning shops who will tune with OpenFlash Tablet? Silver Ignition NY / NJ / CT / PA 24 02-20-2015 08:08 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
