Old 09-27-2018, 08:44 AM   #48805
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Thanks and it was just the stock tire that came with the car.
Relevant: https://jalopnik.com/i-just-got-the-...ife-1829064103
Note that going to Jalopnik, or any Kinja site, without adblock on is... annoying. Almost weather.com bad.
Edit: Might as well just quote the relevant part to save everyone the hassle.
The pictures and description you provided are consistent with the damage seen from a radial tire that has been operating in an underinflated state for an extended period of time. When a tire is being run at low or zero inflation, the added deflection in the sidewall causes heat buildup which, over time, can damage and weaken the tire. If the pressure is low enough, the outside rim of the wheel can even make contact with the sidewall and shoulder of the tire, damaging it even faster. In your case, the nail likely caused a slow leak that went undetected. Detection of low inflation pressures can be difficult to eyeball, which is why frequent pressure checks are always recommended. So while your tire may have never been completely flat before the event, it was likely low enough for the damage to occur.
ScoobsMcGee is offline
The Following 3 Users Say Thank You to ScoobsMcGee For This Useful Post:
humfrz (09-27-2018), Spuds (09-27-2018), Ultramaroon (09-27-2018)
Old 09-27-2018, 08:55 AM   #48806
p1l0t
p1l0t's Avatar
NYC roads are the worst! They are in a constant state of repair and it's still never enough.
p1l0t is offline
Old 09-27-2018, 09:43 AM   #48807
Roads didn't do that. Low pressure did. I have had it happen before on another car. It happened with my boat trailer tire just two weeks ago.
Tcoat is offline
Old 09-27-2018, 09:48 AM   #48808
p1l0t
p1l0t's Avatar
I guess my idiot light doesn't come on soon enough
p1l0t is offline
Tcoat (09-27-2018)
Old 09-27-2018, 09:53 AM   #48809
Ya. I never trusted those things much. When I got deer bones in my tire once the light didn't come on until well after the tire was slapping the asphalt but get a 20 degree drop in temperature and it will come on as soon as I start the car. Not real helpful in the long run.
Tcoat is offline
Clipdat (09-27-2018), p1l0t (09-27-2018)
Old 09-27-2018, 10:02 AM   #48810
ScoobsMcGee
That's what the article said.
The Following 2 Users Say Thank You to ScoobsMcGee For This Useful Post:
p1l0t (09-27-2018), Tcoat (09-27-2018)
Old 09-27-2018, 10:06 AM   #48811
I know that is why I quoted you.
Tcoat is offline
Old 09-27-2018, 10:18 AM   #48812
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Sounds like a good psa for the tire section lol.
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
Old 09-27-2018, 10:27 AM   #48813
p1l0t
p1l0t's Avatar
Oh you guys read entire things in one shot. Didn't realize I was so out classed...
So I bought my winter tires... too soon?
p1l0t is offline
Tcoat (09-27-2018)
Old 09-27-2018, 10:28 AM   #48814
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What makes you believe that your car NEEDS any of those pieces - ??
Seriously.
What makes you think I think my car NEEDS them?
I want the parts for my own enjoyment, because my car is my hobby, and because turning a wrench is good "therepy" for my brain.
I NEED more information to make sure I'm getting all the correct "bits and peices"
I LIKE TIRES!
Leonardo is offline
Old 09-27-2018, 10:34 AM   #48815
ScoobsMcGee
Don't mind me, then. I guess having a rough day at work is bleeding into the forum. Maybe I should be working more or something.
Not out classed, our tires are just significantly more attached to our wheels than yours. On a more serious note, glad you weren't hurt.
I bought winter wheels and tires for the WRX two weeks ago, which have been sitting in the basement next to the new wheels and tires for the BRZ I bought a month ago but haven't installed yet. Could be worse?
p1l0t (09-27-2018)
Old 09-27-2018, 10:46 AM   #48816
p1l0t
p1l0t's Avatar
Hey nobody died so there's that..
p1l0t is offline
Old 09-27-2018, 10:54 AM   #48817
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Did not crash?
Sapphireho is offline
Spuds (09-27-2018)
Old 09-27-2018, 11:00 AM   #48818
p1l0t
p1l0t's Avatar
Did not crash?
FTMFW!
p1l0t is offline
The Following 3 Users Say Thank You to p1l0t For This Useful Post:
Sapphireho (09-27-2018), Spuds (09-27-2018), Ultramaroon (09-27-2018)
