Old 09-25-2018, 12:44 PM   #19643
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
So clean & shiny.
Sent from my SM-G892A using Tapatalk
FRS13_ is offline   Reply With Quote
The Following User Says Thank You to FRS13_ For This Useful Post:
humfrz (09-25-2018)
Old 09-25-2018, 02:32 PM   #19644
Originally Posted by FRS13_ View Post
So clean & shiny. Sent from my SM-G892A using Tapatalk
The red line tires are an interesting touch -
FRS13_ (09-25-2018)
Old 09-25-2018, 02:47 PM   #19645
FRS13_
FRS13_'s Avatar
Thanks.
The red line is actually on the wheels.
humfrz (09-25-2018)
Old 09-25-2018, 04:59 PM   #19646
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
Cleaned up my shed full of Nissan S14 parts. Threw away spare parts that were water damaged beyond repair.
Compared the OE exhaust from 2014 and the one from a canadian manual 2017.
Except for the flanges and tips being different everything else is exactly the same.
mrderp is offline   Reply With Quote
Old 09-25-2018, 06:46 PM   #19647
Old 09-25-2018, 09:10 PM   #19648
So clean & shiny.
Looks like the original Hot Wheels cars!
FRS13_ (09-26-2018)
Old 09-26-2018, 12:30 PM   #19649
mrderp
ಠ_ಠ
mrderp's Avatar
Yeah I know, I wasn't clear in the post. the flanges are at the same location and are the same size but built differently. A picture is worth a thousand words
I recalled reading the 2017 had a revised design.
If that's the case, I guess my car didn't get the memo.
The Following User Says Thank You to mrderp For This Useful Post:
humfrz (09-26-2018)
Old 09-27-2018, 11:54 AM   #19650
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
I did a bunch of stuff to my 86 this summer, but as far as exterior mods go, here's the following:
- Valenti Tail Lights Smoked
- Remark/GReddy Titanium Double Walled Tip Muffler Delete
- OEM rear diffuser
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
The Following 2 Users Say Thank You to itsAlex For This Useful Post:
carsebuco (09-27-2018), jflogerzi (09-27-2018)
Old 09-27-2018, 12:49 PM   #19651
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
- OEM rear diffuser
Looks like Passenger side tip is hanging lower
SuperTom is offline   Reply With Quote
Old 09-27-2018, 12:55 PM   #19652
itsAlex
itsAlex's Avatar
It is aha, I've tried adjusting the rubber things that hold the hangar hooks but it still stays slightly crooked, idk why... I believe the exhaust pipe may be bent?
Old 09-27-2018, 01:53 PM   #19653
Axis2011KR
Drives: 2JZ 2015 FR-S, 2015 F250 on 40's
OEM rear diffuser
How much did this run you and do you have a part #? Dig the setup!
Just picked up my FR-S a few weeks back and thus far done:
FT-86 Speed Factory muffler delete
K&N Drop In Filter
Cut out the mesh in the Fog Light Bezels
Motul 600 Brake Fluid
Motul 300 Gear and Diff Fluid
Diode Dynamics 6000K HID/LED's in headlights, fogs, and DRL's
Diode Dynamics License Plate LED's
Diode Dynamics Interior Plate LED's
Drift Armor Front Bumper Beam ordered but not installed yet
Tein Flex Z Coilovers ordered but not installed yet
Last night installed my Perrin Brake Master Cylinder Brace. De-badging it over the weekend.
Next up is some Work CR2P 18x9.5 rims and some Dunlop Direzza ZIII 265-35-18's hopefully before year end
Axis2011KR is offline   Reply With Quote
The Following User Says Thank You to Axis2011KR For This Useful Post:
itsAlex (09-28-2018)
Old 09-27-2018, 02:13 PM   #19654
Yep, Bubba suggests sticking a piece of pipe in the right exhaust, lift up while heating the last bend in the tail pipe with a torch.
Be advised, keep the pipe and torch handy - because it will always look crooked, depending upon what angle you look at it -
humfrz for Bubba
Old 09-28-2018, 09:26 AM   #19655
itsAlex
itsAlex's Avatar
Wow that's quite a list of things you've accomplished considering its only been a few weeks! And thanks! I should have worded my previous post differently as it's actually an "OEM-style diffuser" and not an actual OEM diffuser.
My diffuser is basically a replica of the OEM diffuser, minus the carbon-fiber pattern as I believe the actual OEM diffuser has a carbon fiber look to it. Here in Ontario I managed to pick it up at a local shop for ~$100.
Old 09-28-2018, 09:29 AM   #19656
itsAlex
itsAlex's Avatar
humfrz for Bubba
I might actually give this a try, I have one of those bernzomatic propane torch kits:
You think that should be sufficient?
